View Full Version : CR-V
Pages : 1 [2] 3
  1. Replace Headlight
  2. Checking Altenator/battery
  3. 2004 CRV able to drive to mt. whitney?
  4. 2001 CRV Brake light issue
  5. CRV 2001 Check
  6. 1998 CR-V wind noise / steering wheel vibration
  7. 2006 CRV Leak
  8. Rear Strut's
  9. 1998 CR-V cruise control doesn't work
  10. '06 Bumper grill replacement
  11. Rear door stuck CR-V
  12. 97 crv door locks
  13. 1999 CR-V SRS Light On and Horn Not Working
  14. How many quarts
  15. Replacing front blinker bulb
  16. Crv 2007 " ! " won't go away
  17. VTEC System Malfunction Honda CR-V 2005
  18. 2004 Honda CRV Surging
  19. How do I change the turn-signal bulb on my 1999 Honda CR-V???
  20. sticky brake piston
  21. Clunk noise when slowing down...??
  22. Clock not working
  23. 2000 CRV intermittently running rough and check engine light coming on.coming on
  24. E Brake light problem
  25. CRV 2004 Transmission
  26. '03 CRV driveline vibration
  27. 2000 Keyless Entry
  28. "rear End Noise" Answers
  29. 2003 Honda CRV EX Ignition Switch Safety Issue
  30. Honda Body Parts -- Corrosion Protection
  31. any one done suspension work?
  32. '02 Crv A/C instantly stopped getting cold
  33. steering noise
  34. "D" Gear Indicator Light Flashing
  35. Radio in 2000 CRV
  36. transmission filter?
  37. Door Lock Noise
  38. Changing belts in a 97??
  39. 2002 Knocking noise
  40. Transmission Problems
  41. timing belt and new AC problem
  42. too many miles?
  43. 2006 Ex AWD Auto
  44. 2006 CRV EX 5 speed manual
  45. how can i change my license plate light?
  46. CR-V performance parts?
  47. K& N Cold Air Kit
  48. 2005 Crv Key Fob
  49. No Clock on Radio?!
  50. 98 crv howling in front
  51. Halogen replacement woes - 98 CRV
  52. Front seat upgrade??
  53. replacing 2004 EX OEM wheels
  54. Vibration
  55. V-Tech malfunction?
  56. daytime running lights
  57. replacing radiator on 2002 Honda CRV
  58. 2001 Sway Bar Links
  59. 2004 Crv
  60. 2003 CRV SRS light comes on occasionally
  61. 97 CR-V front end shaking
  62. 97 CR-V Lockup Torque Converter Problem
  63. ignition key light
  64. 2000 CRV towing
  65. Power door locks
  66. Sway Bar Links
  67. Air filter
  68. CRV Fuel Filter
  69. 1997 CRV Brake springing
  70. CRV 2006 Gas Mileage Problems
  71. 1999 CRV clutch pedal adjustment
  72. Brake warning light when accelerating from stop
  73. 2001 Wind Noise
  74. 2005 CRV - rear knocking/rattle near passenger-side wheel-well area???
  75. Gauges removing in 2002 CR-V
  76. can anyone verify this info from honda
  77. Back windshield washer nozzle broke
  78. Window shudder on '97 CR-V
  79. 1gen crv rear end questions
  80. 2001 CRV buzzing while shifting
  81. dual pump fluid
  82. 98 CRV err-03 on radio/CD player
  83. '94 sunroof problem
  84. '99 CRV misfire (P300, P1399, P303, P304) engine codes
  85. erratic idling
  86. FS:97-01 CR-V Headlight Right Side HONDA PART
  87. CR-V rear differential pump assembly
  88. Armrests 06 EX man. trans
  89. Illustrated repair guide
  90. CR-V transmission downshifts with thunk
  91. Water Pump
  92. catalytic converter head shield
  93. CR-V keyless entry install
  94. 2000 CRV Clock + Radio won't get power
  95. Heater Core
  96. 2002 honda crv surges @ about 2600 rpm,s
  97. 1997 Honda Crv turn signal problems
  98. check engine, emissions light on AGAIN! 01 CRV
  99. Engine temperature spikes at idle
  100. Alloy Rims
  101. 97 CRV - Possible CV Joint Problem
  102. 2006 CR-V purchase
  103. Sell me your CRV (CR-V)
  104. Yokohama tires????
  105. loud sound from the rear
  106. Low Fuel Indicator to No Fuel Reality
  107. All 2001 CRV Owners that have had stalling, rough idle, cold start problems!!!!
  108. 97 crv cold starting problems
  109. Turn key and nothing....well sometimes......
  110. 1997 Honda CRV
  111. New Tires For CRV 2002
  112. headlight warning
  113. 2002 Honda CRV front seats
  114. 2005 CR-V front end clunking noise
  115. CR-V Transmission Replacement
  116. CR-V Inner Tie Rod Replacement
  117. Supercharged and VTEC B20?
  118. Paint problem with '05
  119. anyone put HID's on their CRV?
  120. factory navagation system
  121. Roof Rack
  122. Engine cuts out - no codes
  123. 2003 CRV has only 41,000 miles & the throttle assembly is SHOT
  124. 97 CRV Intermittent SRS light
  125. 2003 Honda CRV and Throttle Body Problem
  126. check engine light inquiry
  127. low fuel light does not come on
  128. Semi ripped left power mirror....
  129. anyone know how to turn the idiot lite off
  130. 2001 makes noise when clutch is not engaged
  131. Spare tire cover
  132. CRV craps out on the beach aftermarket opt
  133. 98 CRV Poor A/C Performance
  134. CR-V air vents temperature control
  135. What Keyless remotes work with a 2004 CRV EX-L?
  136. Vibration
  137. CRV on the beach
  138. Maintenence required
  139. Oil Leak from 2003 CRV VTECh solenoid
  140. Instrument Panel Lamps
  141. what do you think of my crv kit
  142. "Whoooooo" sound from rear left wheel well?
  143. 2003 CR-V Oil Leak
  144. 97 crv
  145. New purchase - Did I pay too much?
  146. Oil Drain Bolt - Metric or US System?
  147. CRV AC - am I getting ripped off?
  148. Tac jumping
  149. Windshield wipers won't work
  150. DRL module for CR-V
  151. Instrument Cluster 2002 CRV
  152. cabin air filter
  153. D light blinking
  154. D light blinking
  155. Hello 1st time Poster
  156. brakes and road handling
  157. Outside Temperatue Sensor
  158. 1997 CRV door locks, keyless entry
  159. gas mileage is bad...
  160. 2002 CRV Air Filter
  161. 02 CRV EX -won't shift from park
  162. CRV Door Locks
  163. rear window lifters
  164. noise when i turn...
  165. 1999 CRV EX stock rims any bigger?
  166. Damn Air Compressor!
  167. window tint
  168. Shopping for an 02-03 CRV
  169. Instrument Cluster 2002 CRV
  170. Alloy Rims
  171. Side View Mirror
  172. New Tires for 2002 CR-V
  173. trailer lights crv
  174. Intermittent Wipers
  175. Brake rotor runout, pulsating brakes
  176. 2004 CRV rear bumper reflector?
  177. CRV SE marked way up? Price Premium?
  178. Which year to buy?
  179. Repairing scratches
  180. Noise from right rear side
  181. vibration under mild acceleration
  182. valve cover gasket installation
  183. oil on plug
  184. replacing dist.rotor on 97 CR-V
  185. Speed Limit Chime
  186. crv rear brake problem
  187. tire damage => tread separation
  188. 97 crv clutch still available?!
  189. 1998 Crv Cargo Cover
  190. 2001 CR-V Radio Code
  191. CRV near-accident - malfunction?
  192. Iridium spark plugs
  193. 99 CRV timing belt --interference engine?
  194. VTECH Solenoid problem after accident?
  195. Let's go low
  196. Accessory Power Socket
  197. Question about the CR-V
  198. 2001 CRV stalls, unstable idle
  199. New Car purchase Honda CRV EX Help!!
  200. 2005 crv head for sale
  201. rear brake bulb out...
  202. 97 CRV Rattling/Knocking Noise
  203. Synthetic oil for Auto Transmission?
  204. Driver door lock inoperative, 97 CRV
  205. 1999 CRV Rattle
  206. 2005 Honda CRV-EX Drive out price
  207. screeching metal noise
  208. CR-V vs. X-Trail vs. RAV-4
  209. Fog and Frost problem inside car
  210. Keyless entry problem
  211. Temperature guage running too cold
  212. 97 CR-V Ready for Coolant Flush-and-Fill
  213. Brake IDIOT LIGHT goes on and off -- A GREMLIN?
  214. Boosted CRV
  215. 2005 honda cr-v
  216. FORUM RULES AND GUIDELINES - MUST READ!!!
  217. Transmission Problems
  218. '98 CR-V rear differential howling
  219. Dead window.
  220. CR-V Ignition Problem?
  221. Blinker Problem
  222. Manual transmission and AWD
  223. Rattle
  224. Engine keeps cutting out -- help!
  225. A/C clutch repair
  226. 2004 - Help with auto door lock
  227. For Sale **2000 Cr-v Ex 5-speed** Ebp
  228. animalize my vehicle
  229. Broken seat bracket
  230. spare tire cover
  231. CRV Radio
  232. Interior Air Filter
  233. winter tires
  234. Vibration that might be a ghost problem
  235. warning chime on 2003 CRV
  236. vibration vibration vibration
  237. Air Conditioner
  238. looking to purchase a new CR-V
  239. Emissions--throttle/pedal position
  240. A/C Noise Need Help
  241. New tire suggestions?
  242. For Sale: Built B20 Block
  243. *For Sale- 2002 Honda CRV-EX*
  244. CR-V shudder...
  245. SWF ISO: B20b block w/ 5 speed tranny (AWD or 2WD, I don't care)
  246. keyless entry lost remote
  247. lots of strange cr-v problems anyone dare to trouble shoot this one?
  248. "Check Engine" light issues. Solutions?
  249. Removing a Stereo in a '98
  250. turbo charged crv help
