View Full Version : Avenger
Pages : 1 [2] 3
  1. looking for an air suspension kit...
  2. shake when accelerating
  3. 97 avanger... 4000.00 good deal??
  4. New engine for 98 need feedback
  5. Avenger Alternate Keyless Entry Fob
  6. speedometer dead
  7. motor mounts
  8. 99 Avenger check engine after oil change
  9. 1999 Dodge Avenger es
  10. To all Avenger and Sebring Owners...
  11. 97 Avngr - Headlight Question
  12. New Avenger Owner
  13. Strange Sound On Shifting Gears
  14. 2000 to 1995 trans swap/avenger
  15. window in door shakes - 97 avenger
  16. Ignition Locked up
  17. Replacing Oil Pan
  18. Dode Avenger
  19. 97 Dodge Avenger tranny nightmare
  20. Avenger Console
  21. Trans Not Shifting
  22. Code P0736
  23. Rack Pinion???
  24. Knocking on Bumps
  25. 99 Avenger Es V6 Timing Belt Woes
  26. Lost Fuse block cover. Can anyone help?
  27. Ball Joints
  28. Door Sensors
  29. Water Leak
  30. 1996 dodge avenger 2.5 v-6
  31. Factory alarm keeps going off
  32. Wanting faster shifting
  33. 98 Dodge Avenger 4 sale!!! air bag suspension on 18"chrome rims
  34. Might be ridiculously stupid, BUT...
  35. Might be riduculously stupid, BUT....
  36. Engine Replacement Questions
  37. Ignition Coil Wires
  38. 1997 Dodge Avenger ... PS/Alternator Belts ... HELP!!!!
  39. 99 Avenger, replaced power steering pump, foam coming out of reservoir?
  40. engine cuts on and off when cold outside
  41. Grinding Noise, Power Steering Pump or Pulley
  42. Getting Power Steering Pulley Off
  43. Dodge Avenger Door Speakers Replace = Rewiring? URGENT
  44. ~!HELP ME PLEASE!~ white face gauges install
  45. i f-ed up
  46. 97 Avenger dieing
  47. Avenger wins
  48. '99 Avenger - Parting out??
  49. trunk light
  50. 96 Avenger 2.5???
  51. more help
  52. 85k miles.. timing belt needs replacement.. should i replace other stuff to ?
  53. Help Findin Motor Parts
  54. No Spark
  55. i dont know what this light means
  56. Auto Tranny plus a turbo. Good or bad?
  57. instrument panel dimmer switch-Avenger96
  58. When should i change my timing belt ?
  59. power steering pump
  60. clicking popping in steering linkage
  61. '99 Avenger body parts needed.
  62. Radio Color Codes
  63. keyless remote/ alarm
  64. Stock Alternator
  65. 97 avenger v6
  66. Just bought an Avenger..couple probs
  67. What kind of oil should i use ?
  68. Timing belt opinion
  69. Which o2 sensor to change?
  70. 95-96 VS 97-00 Body part differences
  71. 99 avnger starting problems....
  72. auto Transmition shifting problem
  73. Engine Light Comes On and Off
  74. New Sunroof for My ES
  75. Crankwalk Ahhhhhhhhhh!
  76. Help.. i need a scematic..
  77. I got an avenger
  78. Need Exhaust Tips
  79. Buzzing when Shifting Into Gear??
  80. 98 Avenger ES Headlight Assembly Replcmnt
  81. Cf door inserts
  82. How hard is it to convert a auto to a manual?
  83. How To Remove A 1997 Dodge Avenger Headlight???
  84. Bumper repair!
  85. paintin my car?
  86. avenger, CAI? AEM or ICEMAN
  87. Intercooler
  88. Axle seals?
  89. 98 Avenger for sale on air struts!
  90. 96 Dodge Avenger Transmission trouble
  91. painting door handle
  92. Any Websites?
  93. where is this particular relay related to ABS Brakes in the car so i can replace it
  94. Just Had A Diagonists done help me understand these problems
  95. Overhaulin'!!!!!!!
  96. Motor Swap
  97. For Sale: 97 Avenger 2.0
  98. Decoding your VIN
  99. Smoke and grinding
  100. Base or ES?
  101. Replacing Belts and Pulley, Where's Tensioner?
  102. Windshield Wipers
  103. 95 Avenger ES front end "rattle"
  104. Where is the sending unit located for the ECT Light on Dashboard
  105. Somebody with a manual please check what this light is! URGENT
  106. front end "rattle" under acceleration
  107. Over Heated
  108. bad wiring
  109. DSM3D v1.0.0.1a Released! 420a
  110. Avenger Bumpers
  111. V6 Engine
  112. Finnaly done w/ my paint job
  113. need more horse for a 420a motor
  114. Help With 96 Avenger.. Just Bought.. No Manual PLEASE!!! Many Problems
  115. Intro
  116. Does anyone know...
  117. Freaking timing belt
  118. Stupid Evil Cam '97 Avenger
  119. aside from the turbo
  120. 420a swap to 4G63
  121. 97-98 Dodge Avenger How Do You Guys Like it?
  122. Front Wheel Bearing 95 avenger
  123. $$$money!!!$$$ what should i do?!!!!
  124. Delecasies of Timing
  125. Clicking sound
  126. 1/4 mile drag
  127. A30 ENGINE FUSE question
  128. Help - Front Hub Replacement
  129. Swapping Engines!!!
  130. Crank pulley replacement
  131. Rear Wheel Drive Or Front Wheel Drive?
  132. I'm Confussed
  133. Anyone parting out a 98 es
  134. V6 Pulley and Lights
  135. Dodge Avenger Maintenance
  136. 95 avenger i-4
  137. Serious No BS question (no smartalic bull here)
  138. Shaking in front end on 97 ES
  139. 96 dode avenger es question??
  140. Programming door lock remote
  141. 95 avenger
  142. Suspension
  143. Anti Lock Brake Prob.
  144. My new car....
  145. Tweeter replacement, What fits?
  146. 18" KONIG APPEALS with TIRES 4 SALE
  147. dear god please help...98 2.0 I4 5sp.
  148. Problems I should be aware of?
  149. AWD Avenger
  150. stereo
  151. Quick Question
  152. stock infinity amp
  153. removing the dash
  154. Help with car improvements
  155. Turbo help <<<<<<<
  156. 97 dodge avenger head gasket replacment
  157. 97 v6
  158. Reverse Glow Gauges
  159. need more power, help!!!
  160. 2.5 headers?
  161. Hooking up a 2nd amp
  162. 97 2.5 v6 engine and trans
  163. dodge dakota
  164. need immediate help!
  165. Motor Swap
  166. DIY trans flush?
  167. Fuse diagram?
  168. want to buy a 97 avenger
  169. turbo
  170. will it work
  171. 1995 avenger antenna
  172. 18" Chromes for SALE!!!
  173. Rims
  174. Rims
  175. timing belt
  176. 95 Transmission Rebuild
  177. Need HVAC wiring diagram
  178. opion on type speed aero kit
  179. 99 Avenger I-4, 1990 eagle TSI what to do?
  180. handles
  181. starting problem
  182. no spark!
  183. 2.5 mx6 vs. 2.5 avenger
  184. 97 v6 mods???
  185. Needs help w 96 Avenger
  186. rough idle!! dies upon starting!! help?
  187. engine light
  188. Painting the Brakes
  189. Fs 95 Avenger Parts
  190. Rotten Egg Smell
  191. Mid to late 70s Dodge Avengers from England
  192. '97 Cig. lighter housing....
  193. Speakers.......
  194. UPDATE on 97 ES....Couple Questions
  195. Tire size
  196. 1997 Avenger ES for less than $3,000
  197. noise? wheel bearings?
  198. Please Help!!!!
  199. want to see the awd avenger?
  200. bent valve?
  201. Compatible Turbo
  202. Rear Hub Assembly
  203. 1999 dodge avenger with 3.0 engine
  204. targa top avenger
  205. 17" Avenger wheels
  206. Is there ECU codes on Avengers??
  207. Entire Engine
  208. Speaker sizes for a 97 avenger?
  209. drivetrain swaps???
  210. i have a 98 avenger v6 parts car
  211. EGR valve
  212. Engine parts
  213. 95 avenger engines
  214. In need of a manual 420! Avenger
  215. Need Help With Avenger Fuel System...
  216. 1995 Avenger ES for Sale Excellant Cond.
  217. 95 Avenger Transmission
  218. Key FOB Programming
  219. Should I get it???
  220. 1995 Avenger ES for Sale Excellant Cond.
  221. '97 Avenger for $500.00
  222. Quick Question
  223. 95 Avenger New Move
  224. Best/fastest engine for 96 avenger
  225. AWD avenger
  226. low budget
  227. 97 Avenger Question
  228. Specs
  229. Eclipse center console will fit in Avenger
  230. Third Brake light
  231. Avenger Hood
  232. need ideas for engine mods on 98 venge
  233. Subwoofers for sale!!
  234. 1996 Avenger For Sale!!
  235. Just got my 1996 Avenger
  236. My Avenger
  237. New Rack and Pinion Steering
  238. Problem with the heating system
  239. Modifications for stock 99 avenger es
  240. Wanting to Buy
  241. Avenger stock stereo system
  242. ...A little help...
  243. Stupid question here, but I'm not too sure of the answer...
  244. Big Bad Engine...
  245. Waxed the car with...
  246. Struts
  247. Exhaust/wheels
  248. 3000 GT VR-4 power train for avenger?
  249. Manual Transmission
  250. whats up
