Just Had A Diagonists done help me understand these problems
vMoNeY
08-30-2005, 04:19 PM
ABS Light On Cause : (53) Motor Relay Error... how do i fix this?? and how much
Also P Code 0134 Rear Bank Upstream O2 Sensor Stays At Center.. waht does this mean and how do I fix it.. and how much ?
Also should this of cost money??? For them to plug it into the computer.. I live in Canada
fiberglasscivic
08-31-2005, 12:26 AM
I can tell you that the second error you had means that you need to either clean your rear O2 sensor or replace it (probably replace itA). Replacement will cost a good amount of money (around $100-$200 american). I'll get back to you on the first error and no, you shouldn't have had to pay someone to hook up an OBD II reader to your car. You should have been able to go to an automotive store and had them check your engine codes. They could have told you what the code numbers were and we could have told you what they meant.
Sitruc_bc
09-01-2005, 12:20 AM
Code 53 means there is an internal Powertrain Control Module error.
