Our Community is 662,000 Strong. Join Us.
View Full Version : Integra
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. AF's news video: 2
  2. AF's new youtube newsfeed
  3. Valvetrain noise when engine is cold
  4. 88 acura integra won't start from time to time
  5. tailight fuse blowling
  6. is the clutch the culprit?
  7. Coolant Problems
  8. remove alternator 90 Integra
  9. 96 acura integ losing spark
  10. 96 integra ABS problem
  11. 88 integra coolant temp sensor???
  12. My headlight bulb runs out quick.. Dishonesty by auto-repair???
  13. Swapping Motors
  14. ebay exhaust?
  15. 94 Teg Surging Throttle Problem
  16. Hard to Start
  17. 95 Integra LS with B18 A1 VSS location?
  18. what can i swap my zc engine of integra 1994
  19. Head Gasket
  20. what should i do make it faster?
  21. valves ticking bad
  22. What's wrong with my battery?
  23. GSR vs. LS/VTEC
  24. 95 Integra with VSS problems + more...need help!
  25. 96 teg radiator replacement
  26. 91 integra manual steering.
  27. weird light on dash!!
  28. car is over heating
  29. windshield
  30. How do you fix a bouncy windshield wiper?
  31. How much does a windshield repair coast?
  32. 96 integra help
  33. 95 Integra dash question?
  34. is my teg ready for a tune?
  35. p0103 code thrown.. what gives 96 integ.. 4 cyl.. 160,000 miles.. maintained well.
  36. stay nonvtec go go vtech
  37. swapping b18a1 for b18b1
  38. Fuel and Spark, but no start
  39. injectors.......
  40. Integra GSR Crankshaft
  41. 1991 intergra
  42. Rough Idle 1987
  43. 97 integra viabration
  44. Witch Integra???
  45. 1997 Integra weird sound from brake or??
  46. 1990 integra starting problems
  47. brake bleeding problem
  48. Need help!!
  49. Integra 94 SHAKING PROBLEM
  50. Window Help
  51. how to replace ignition lock cylinder on 2001 Acura Integra
  52. Headlight Removal
  53. Wiring Help
  54. 90 integra ls gauges dont work
  55. Rev limit/wont start
  56. 1999 Integra SE alternator/electrical problem
  57. Oil light
  58. B18A1 motor!! nice shape
  59. itr front end
  60. Stainless Steel Cat-back or axle back??
  61. 97 integra 4dr 1.8 gas gauge problem
  62. couple questions on 1990 integra
  63. Rear Defogger + More!
  64. cold temperature gauge
  65. clutch problem
  66. no lights in needles of all gauges
  67. 2000 teg front end noise
  68. Honda racers
  69. 2000 Honda S2000 for Sale
  70. what do you think of this car
  71. Help Me Buy The Right Silencer
  72. GSR question
  73. starting problem
  74. 94 integra cams
  75. 91 Integra LS Auto
  76. Buying a teg...
  77. HP diffrence
  78. Engine Runs Rough after Cleaning
  79. Off Idle
  80. whats the difference in weight between a 2 and a 4 door?
  81. valves ticking bad
  82. WANTING carbon fiber Type R center console complete
  83. just to clear somethnig up, (help)
  84. P0430 code
  85. B18A fuel injector ticking
  86. 95 accura integra gsr crank but not starting....
  87. What's wrong with my battery?
  88. integry tranny probs
  89. common repairs times : 96 Acura Integra 1.8 PFI auto
  90. common issues 96 Acura Integra 1.8 PFI auto
  91. Overheating only during stop-and-go traffic AND long freeway drives
  92. Distributor Help
  93. Blown head gasket
  94. 96 integra need help no start issue
  95. 93 Integra Starting problems
  96. crank but no start
  97. 87' Teg Starting Issue and PGM-FI light Please Help
  98. How to tell if motor is obd1 or obd2?
  99. problem starting
  100. Eating up O2 Sensors -- Running Rich
  101. 92 integra suddenly stopped runnning *please read*
  102. Tried everything to eliminate exhaust drone... any ideas?
  103. 98 Integra LS AT, Shifting problem
  104. Winter Rims
  105. GSR vs. LS/VTEC
  106. Rhino Ramps for Integra?
  107. B18B1 OBD2 to OBD1
  108. 1997 GS oil leaking
  109. Need help please major question
  110. 92 Integra LS major problems, please read!
  111. 95' no eng,trans
  112. Engine shutdown right after starting up.
  113. I need a t4 not a t3/t4 turbo manifold. b16 b18
  114. Newbie Upgrades 98 Integra GS-R STOCK
  115. Integra '94
  116. Rough Acceleration problems
  117. need answers fast,vtec wont work cause speeometer wont work ??? help
  118. need answers fast,vtec work cause speeometer wont work ??? help
  119. 94 GS-R V-TEC problems
  120. GSR (b18c) Cat problems - heads up.
  121. 96 JDM Integra Type R? Anyone?
  122. 92 integra fail safe problem
  123. B18C Identification
  124. No Start
  125. Integra Type-R registry
  126. clock/radio
  127. Finished B20 in integra91 HELP!!
  128. 2000 "LS"=reliability-??
  129. 92 DA wont start
  130. 2000 integra
  131. car wont start...
  132. Car won't start please help me figure this one out!!!
  133. 95 gsr shift problems
  134. 91 integra halo projector head lights and halo tail lights
  135. Where are you
  136. 92 Integra Master Cylinder "how to"
  137. 90 acura integra gs coolant tempature sensor/ driver side window
  138. B18A1 to B18B1
  139. first gen front end conversion
  140. Strange antifreeze leak...
  141. I need help from all of you integra owners
  142. Cams/Cam Gear confusion
  143. How fast can your integra go?
  144. rear caliper issue
  145. boost
  146. car dies.
  147. 1990 integra a/c problem
  148. integra dyin when car is stopped (at a stop light)
  149. Cams
  150. 1990 Integra DRL
  151. code 4 HELP!
  152. injector cleaning
  153. Is a D16a1 engine compatible with a 85 1300 transmission
  154. LS Vtec
  155. Different Size Tires for Acura Inte Gs 99
  156. Integra GS-R, Type-R cams difference
  157. In need of a hood for my 99 integra!
  158. Integra Motor Question.
  159. 1988 Head swap.
  160. smoke and dead spots in rpm
  161. 94 integra ls sport coupe 1.8
  162. Vtec Issues Please Help
  163. help..
  164. vs toyota mr2
  165. GSR question 150kmiles
  166. No Fuel!!
  167. Motor upgrade: ZC to B18c
  168. Engine light comes on when i hit 25-30 mph ?
  169. idle prob?
  170. Wierd noise when car starts??
  171. IAT location 1999 Integra GS-R
  172. main relay wire
  173. mild steel or cermaic coated?
  174. 90 integra, surges at 3000
  175. Oil pan question
  176. 90 integra ls b18b swap
  177. 95 no start starter question
  178. Rattling from under the hood
  179. firing problems
  180. No Heat?
  181. Dashboard Removal
  182. 4-5 Blown in my B18 Tranny.......
  183. full exhaust?
  184. '93 Integra - intermittently will not start, but turns over
  185. noisy speedo cable
  186. 92 gs 4dr auto Key stuck
  187. Best Turbo Kit ofr 94 acura
  188. Just bought 94 Rs integra
  189. Turbo?
  190. Check out my mounts
  191. Can you guys diagnose my spark plugs?
  192. Update (my B18C1 swap)
  193. How do I start this teg without a key?
  194. 96 Integra Car Alarm going off randomly
  195. how to turn engine light off
  196. Integra oil Light comes on
  197. Should i tune a 98 Honda Integra Dc1 SOHC non vtec ?
  198. teg questions
  199. Honda Integra 2001 Quotes
  200. used Integra value
  201. No coolant to lower rad hose
  202. 1991 Integra GS wont start
  203. Quick question.
  204. ABS light
  205. 94 gsr window problem
  206. Acura Aftermarket Steering
  207. B17
  208. Mid to Late 80's Integra Trans Dipstick
  209. After market, or OEM Radiator Replacement?
  210. motor questions
  211. windshield
  212. brake light problem
  213. How to identify engine
  214. gsr cluster gauges not working
  215. have a quick qu.. need help..
  216. car died on highway
  217. legroom
  218. 1993 intregra
  219. 95 gsr p29 ecu????
  220. Help - Clunk noise when hitting bumps
  221. 90 accura integra 4dr for sale good parts
  222. ECU wont give code...limits rpm's to 3,000
  223. bolt size on cat heat shield????
  224. ls/vtech type r turbo?
  225. Do i need to pull the engine
  226. 91 Integra Having Problems Starting
  227. 90 integra b18b1
  228. Battery Light
  229. integra 90-91 not getting spark and fuel pressure
  230. Anybody Need A B18A Motor?
  231. where is the evap canister or hose at on my integra ..please help
  232. 91 Acura Integra STUCK IN S2 ON DASH WONT START???
  233. Clutch on 2001 Gsr?
  234. Integra Rear Hatch Removal
  235. b16a first gen. swap /integra 91
  236. radio code acura 1998 cd player
  237. Tranny problem?
  238. fuse box diagram
  239. Integra 2002
  240. Audio/Speaker Installation + Door Panel Removal Questions
  241. 1994 Manuel Transmission
  242. ecu for type s
  243. Searching for first car... I'm interested in a gsr in my area... Have some questions.
  244. For the love of God help me!
  245. abs light
  246. Integra Reliabilty
  247. engine swap
  248. Need help
  249. A/C compressor replacement help
  250. Windshield & Window Rattling
