Page updated on 06-19-2018
Different Size Tires for Acura Inte Gs 99
Smokied
04-18-2008, 08:49 AM
I need new tires for my vehicle but my budget is kinda tight right now. Normally I need 195 55 R15 for my vehicle but i was wondering if there were any other sizes of tires I could use in place for 195 55R15.
my buddy works at a cheap tire place where he can get me cheap tires but unfortunately they dont have the type previously mentioned in stock.
wiseguy01
04-20-2008, 12:50 PM
i know you can play with the middle number 55 but if it is a rim and not stock rims then you would need to check for tire clearance the 55 means the heigth of the tire and the 15 is the size of the rim and and the 195 is the width of the tire in mm
Smokied
04-20-2008, 01:56 PM
what about the numbers 205 50 15 and 195 50 15. would these good?
wiseguy01
04-20-2008, 04:17 PM
205 would make it a wider tire check and make sure you have enough space for it like get one and put it on and turn the wheel both ways and if it does not hit then your good if it hits by hits i mean the inside of the car then it wont work otherwise use it
