3 cylinders
CIVICLX93
01-06-2006, 02:47 PM
hey guys my car right now is running on three cylinders the power is very lackluster any idea how long i can drive on it for plus my power locks work only when it rains, power windows have nothing o do with engine
i_a_n112784
01-07-2006, 03:55 AM
Well, it all depends on why the one cylinder isn't working. Is it missing compression? No fuel or spark? In theory, it can run for a normal life span on only 3 cylinders, but in reality, you need to address the problem. Do a compression check, and also make sure it is getting fuel and spark, then I can help you with suggestions on how to fix it.
As for your power lock problems, check for shorts in the electrical system, specifically, problems with the ground(s).
superbluecivicsi
01-08-2006, 12:15 AM
if you are running only on three cylinders, then, you should be misfiring. CELs are? you should not run on 3 cylinders. as mentioned above, fuel? spark?
