instrument panel 95 ex
chriswatt
10-17-2005, 03:08 PM
How do I remove the instrument panel in a 95 ex? I need to replace the speedometer. Besides the 2 screws you can see I am not sure if there are clips or hidden screws.
Thanks
Thanks
CivicSpoon
10-17-2005, 03:52 PM
You will also need to carefully pry up the hazard button, unhook the plug for it, and remove the screw behind it. After that it's all clips to remove the panel. Then there are 4 screws holding the cluster in. Here's what I found in the manual: http://img.photobucket.com/albums/v473/CivicSpoon/clusterremoval.jpg
