jdm d16z6...
Kuntry_Boi06
10-18-2005, 08:48 AM
is the jdm d16z6 and older engine than in my 95 civic ex and will it bolt right up? does anyone know the specs??? is there a lot of aftermarket support for it?
Ace$nyper
10-18-2005, 03:48 PM
same as USDM
blue92HB
10-18-2005, 05:07 PM
I have never heard of a JDM haveing a digit at the end of the engine code. I always thought that it was something like D15B not D15B7 like the USDM engines. Also I was unaware that Honda had a JDM 1.6 single cam engine I thought they ony had 1.5 like the D15B.
CivicSpoon
10-18-2005, 05:58 PM
Correct, there were only 1.5L sohc models. And for the most part there were only engine codes without numbers after.
(hopefully this will work) http://translate.google.com/translate?sourceid=navclient-menuext&hl=en&u=http%3A%2F%2Fwww%2Ehonda%2Eco%2Ejp%2FHOT%2FModel Data%2Fcivic%2F92cv%2Dk%2D109a%2Fline%5Fup%2Ehtml
Ace$nyper
10-18-2005, 06:21 PM
Both you are right.
I should have expaned more on my post.
They did have a 1.6L sohc vtec they called it the ZC *yes they had more then 1 kind of ZC*
But other motors that kept a long code the JDM ones drop the last digit.
CivicSpoon
10-18-2005, 07:50 PM
I believe the ZC's came in the Integras, but I could very well be wrong. But I knew what you ment Ace.
Kuntry_Boi06
10-19-2005, 03:04 AM
ohh-k ty
hany
10-19-2005, 06:45 AM
all these advices is right the jdm have no diget after the last code but to know what is older look the black cover is the oldest it incloce at word VTEC and the newer is the metal ( silver cover) is the new and it include also at VTEC word . this for the 92 to 95 model but for the 96 and above model the silver cover and not incude at vtec word but it is vtec and you can check that by the vtec sensor
blue92HB
10-19-2005, 07:49 PM
I always thought that ZC's were DOHC 1.6 non-vtec. That is the only ZC I know of and yes they were in the 1st gen Teg
CivicSpoon
10-19-2005, 08:51 PM
There are also SOHC versions (vtec and non-vtec). I did a little more searching and they were also in 1 or 2 '92-'95 4dr models.
AudioGuy93DelSol
10-21-2005, 04:25 PM
To answer the question, the D16z6's Japenese cousin is the D15B. Identical output ratings, but the only difference, besides displacement, is the D15B has a single wire 02 sensor and the Z6 has the 4-wire.
