Steering Wheel Allignment???
jhong1226
11-28-2006, 09:46 AM
The steering wheel is not alligned properly on my 94 civic. its a bit off to the right when the car is going straight.
Is it possible to all align the steering wheel by taking it off and adjusting it? or youll have to adjust the tie rods?
Thanks!
Thanks!
fiberglasscivic
11-28-2006, 11:04 AM
If the actuall steering is properly aligned so that you can let go of the wheel on a flat road and not drift to one side or another then yes you should be able to take off the steering wheels and center it.
jhong1226
11-28-2006, 12:40 PM
Yup! My car does not wander if i let go of the steering while driving.
So is there any tricks or tips out there to pull the steering wheel off???
fiberglasscivic
12-01-2006, 01:31 AM
It would be wise of you to disconnect the battery first so the airbag doesn't deploy in your face, other than that though theres no real trick too it, just be carefull when removing the column covers because the clips tend to break if your too rough. I believe there are four bolts behind the steering wheel that release the airbag, after that everything else is pretty simple. If you have a haynes, or helms manual, it will explain the process.
jhong1226
12-01-2006, 12:17 PM
thanks! will try to do the job today!!
Pavlo
12-09-2006, 11:56 PM
Actually it is the alignment, the shop should center the steering wheel if it is not too bad. If it is really off, then you need to adjust the actual steering wheel.
BullShifter
12-16-2006, 06:07 PM
Your better off doing it the right way, which is adjusting the toe. Since the steering wheel is off to the right you want to move the wheels to the right. Right side get's toed out while left gets toed in. Make sure to move each side equal distances.
