just 6 questions
Johnanna
03-30-2006, 10:35 PM
Hello, everyone
Please refer to the following diagram and answer the question using the following statements:
1. with the headlights on and the dome light on, you crank the engine over with the ignition. the dome light stays bright but engine cranks slowly. this condition indicates _______:
A. low battery
B. Frozen motor
C. Open in the load circuit
D. Good battery
E. bad armature in the starter
2. with the headlights on and the dome light on, you crank the engine over with the ignition. the dome light stays bright but engine does not crank, there is no noise from under the hood. The problem most likely lies in the ________:
A. control circuit
B. Load circuit
C. Relay
D. battery
3. with the headlights on and the dome light on, you crank the engine over with the ignition. the dome dims stays bright but engine cranks slowly. this condition indicates _________:
A. low battery
B. Frozen motor
D. Good battery
4. When testing the amperage draw of a starter motor on a four cylinder engine you get 325 amps @ 9.6 volts with slow cranking. what would you do next?
A. pull the start motor
B. test the battery
C. perform the cranking circuit resistance tests
D. clean and or replace the battery cables
e. not enough information given
5. When testing the amperage draw of a starter motor on a eight cylinder engine you get 87 amps @ 9.6 volts with slow cranking. what would you do next?
B. test the battery
6. When testing the amperage draw of a starter motor on a eight cylinder engine you get 87 amps @ 10.2 volts with slow cranking. what would you do next?
B. test the battery
thank you for much
J.H.W
hany
03-31-2006, 03:09 AM
is this your homework and no one to help you today to do it. and you need us who help you.
exman98
03-31-2006, 01:25 PM
i have a belly button
johnb16a2
03-31-2006, 02:25 PM
:rofl: :rofl:
Shinobi_jak
06-14-2006, 02:55 PM
I know this post is from march but I'm still looking for "the following" diagram.
lorunner
06-14-2006, 08:13 PM
Wtf
