'99 SL2 idle speed
glennco1
05-02-2005, 09:11 AM
Quick question:
What is the idle speed of a '99 SL2, specifically the fast idle? The fast idle on my wife's SL2 is around 1900 according to the tach, that seems pretty fast to me.
thanks,
mysatilac
05-02-2005, 11:43 AM
How long does it stay there?
Id expect it to be around 1300, but under 2K isn't that bad, as long as it evens out fairly quick, say within 10 seconds
glennco1
05-02-2005, 11:51 AM
I figure it takes about 3-4 mins before it begins to slow down to standard idle, which appears to be around 600-800 rpm.
mysatilac
05-02-2005, 12:14 PM
Whats the temperture outside like?
Does it diesel when you cut it off? (kinda chug along for an extra couple of seconds)
The normal things to look at are the ECTS (Engine Coolant Temp. Sensor), and the IAC (Idle Air Control Valve) and TB (Throttle Body)
Clean the IAC and TB, and replace the ECTS with a brass tip one from saturnparts.com or a saturn dealership
sierrap615
05-03-2005, 12:45 AM
a few things factior into high idle. is this a manual or auto trans? when is the high idle only at start-up?
glennco1
05-03-2005, 08:43 AM
My wife parks in a heated garage, and we see the problem whenever we start it after it has been parked for quite a while.
It is an auto.
I guess I expect the high idle to only last for 30 secs or so at around 60 degrees, but it can last for 4 mins. I also wouldn't expect it to be so high.
I'm going to try the initial idea of cleaning the Throttle Body/Air Control Valve this week sometime to see if that helps.
sierrap615
05-03-2005, 12:03 PM
I'm going to go with a bad ECT, it possible its a bad thermostat, but not as likely
glennco1
05-09-2005, 12:10 PM
Hey all, last weekend I cleaned the throttle body, and things seem to be better. The current functionality I'm observis is.
At start the vehicle idles at approx 1300rmp, the idle speed then slowly starts decreasing until it reaches operating temp, and at that time it idles at around 800rpm.
Does this sound like proper functionality for the system?
mysatilac
05-09-2005, 01:03 PM
Perfect!
Thats exactly right,
glennco1
05-09-2005, 01:10 PM
Great, thanks for all the help
fretese
06-08-2005, 08:17 PM
I am having problem with the idle speed (too high). I would like
to start by cleaning Throttle Body/Air Control Valve.
My problem is were is located the 'Throttle Body/Air Control Valve'
and please give me an idea of how is suppose to look.
Thanks and regards,
Edgar in NY
mysatilac
06-08-2005, 09:09 PM
http://files.automotiveforums.com/gallery/watermark.php?file=/503/278444Image_826_-med.jpg
http://files.automotiveforums.com/gallery/watermark.php?file=/503/278444Image_827_-med.jpg
Both pics are with the TB top up, the arrow points to the IAC, remove it to clean the pintle (the part with the spring wrapped around it)
It should be clean and dull silver, not black, you'll notice very quickly when you start spraying it with carb cleaner, its pretty self explanatory
http://files.automotiveforums.com/gallery/watermark.php?file=/500/278444Image_836_.jpg
The TB would be attatched to the end of the tubing in the top of this photo (obviously not installed) (never mind the circle and arrow they were for the intake resonator thread)
sierrap615
06-09-2005, 01:58 AM
also start the engine right away after you clean it, you want the carbon to be burned off by the engine before it can settle again.
mysatilac
06-09-2005, 10:37 AM
Or better yet, remove the TB and IAC to clean them,
fretese
06-09-2005, 09:53 PM
Thank you very much for all the info. I already order the
ECT and I am also ordering a PCV valve.
As soon as I received them from saturnparts.net i will change
and let you guys know of the outcome.
Regards and thanks for the very useful pictures.
Edgar
fretese
06-09-2005, 09:56 PM
I forgot to tell you that my Saturn is a 97 SL SOHC manual trany with
207000 miles and running strong.
Regards, Edgar in NY
fretese
06-09-2005, 10:02 PM
I forgot to let you know that my Saturn is a 97 SL SOHC manual trans. with 207330 miles and running strong. So I really need to do all of these
maintenance jobs.
