ignition system...
WunNOnly
07-22-2005, 01:02 AM
I was currently having problems with my '95 saturn sl2 auto, my battery seemed to be draining quite fast (1-2 days), n after testing the battery n alternator everything seemed to b workin fine, so i decided it was a short draning the battery...well after a few test with a circuit tester n a few fuse pullouts i found that there was a short in the ignition system...now i need help on this, should i take it somewhere to fix the short, or can it be easy enough for me to do it myself???...any advice will be greatly appreciated...even better if any1 can walk me through the ignition system to check it myself...much luv thnx
WunNOnly
07-22-2005, 10:49 PM
what can be the main reason for a short in my ignition system???...hope some1 can help me out with this one, i've been searchin everywhere...
WunNOnly
07-23-2005, 01:45 AM
ok, one more question...would it be bad for the car if i just took off the fuse from where the short comes from when the car is off(keeping my battery plugged), n just puttin it back on whenever i want to drive my car... would my battery still drain?..please help...i really need any suggestions...i need my car...gettin the bus n walkin to work really sux...
sierrap615
07-23-2005, 05:32 PM
do you know which circuit is draining the battery? in general, as long as its not the PCM B fuse or the CHIME fuse, it should be ok to pull while the car is siting
WunNOnly
07-23-2005, 06:10 PM
good to know, thnx
