speedometer
Ridleyj329
08-02-2005, 06:52 AM
i have a 92 sc2 dohc and im having a lil trouble with my speedo. everything seems to be workin but when i get up to about 60mph my needle starts to jump up and down slow at first but the faster i appear to go my faster and wider range my needls moves. what cold the problem be and could it be an easy fix? thanx
sierrap615
08-02-2005, 11:52 PM
possible problems
1. vehicle speed sensor
2. PCM
3. gauge cluster
4. wiring
most likey the gauge cluster IMHO, but diagnosis require special tools(scantool at a minium). sorry i can't be more of a help
2. PCM
3. gauge cluster
4. wiring
Ridleyj329
08-03-2005, 12:28 AM
so theres basicaly nothin i can do w/o a scan tool? if i had one would it read any error codes or would any even be present if there are no warning lights on?
sierrap615
08-03-2005, 01:26 AM
no codes, you would watch the live data stream to determind what the PCM reads for speed, then use a osilioscope to confirm. you could just use the osilioscope but it would be a little harder. in cases like this, the gauge cluster is the most common problem IMO. if diagonsis is to much, you might be able to find a cheap cluster at a local junk yard.
vettpiper
09-17-2005, 10:41 AM
Hello! I'm looking for info about changing a speedo signal from a 92 Chevy 1500 4x4 w/ a 4.3 & auto tranny to a 98 LS1 computer
