Swapping Parts
RSKBDK
04-26-2005, 10:11 PM
I Have 4 Questions :
#1 Where Is The [ Pcm ] Powertrain Control Module And The Canister Purge Solenoid Located On A 1992 Sl2 With Automatic Tranny ? ? ?
#2 Can I Use Either Of The Above Parts From A 1993 Sl2 With A 5 Speed To Replace The Bad Ones On My 1992 ? ? ?
#3 What Year Pcm's And Canister Purge Solenoid's Can I Use On My 1992 Sl2 With Auto Tranny ? ? ?
#4 Where On Line Can I Find Spec's On 1992 Sl2 Saturn's Diagrams , Torque Spec's Etc. ? ? ?
Thanks Bob
sierrap615
04-26-2005, 10:51 PM
1. PCM - under dash, look behind the hood release, ABS module is also mounted here, CCPS - on top of the throttle body, you will see three vaccum lines, one going to the EGR, one to the FPR, and one running under the intake manifold, the CCPS is connected to this line bolted to the intake manifold(you may need to reach it from underneth) - http://www.saturnfans.com/photos/showphoto.php/photo/14837/
2. PCM - no, CC yes
3. a PCM from a 91 or 92 with DOHC engine and auto trans. a saturn dealership may need to reflash it if the donor car has different options.
4. http://www.saturnfans.com/forums/showthread.php?t=44221
RSKBDK
04-29-2005, 08:39 PM
thanks for the help , bob
