View Full Version : Stratus
Pages : 1 2 [3] 4 5
  1. Check engine and battery ligth
  2. Easy question any 1998 Stratus owner. Please answer!
  3. Problems with my 2000 Dodge Stratus SE
  4. 98 stock radio/cd player.....
  5. Blower Problems
  6. 96 stratus turns over by itself
  7. Feul Pump
  8. 98 stratus 4 cyl check engine light
  9. Stratus wheel ready to fall off
  10. Dodge Stratus ES 2.5 6 cyl
  11. Blower Motor - Plymouth Breeze
  12. brakes
  13. Growling noise
  14. Vibration
  15. Which 02 sensor do I replace?
  16. manual tranny swap--96 stratus
  17. Transmission Fluids
  18. Heater blower only works on high speed
  19. Rear Brakes
  20. car wont start, sputtered like crazy when it did last run -- have 6 trouble codes
  21. Aftermarket
  22. 99 stratus check engine light.
  23. stratus cooling fan
  24. mirror help
  25. Headlights Clarity Problem
  26. 02 stratus 2.7L HGelp Please
  27. 1995 tranny problem
  28. speakers
  29. One side of windshield washer nozzle not working
  30. transmission fluid leak
  31. 99 stratus stalling and not starting
  32. i never thought id say this
  33. Pimping my ride White Marsh Style
  34. O2 Sensors are expensive!!!
  35. transmission limp mode p0700 and p1787
  36. 1997 Dodge Stratus ES
  37. Dodge stratus fuse problems
  38. Parting out '96 Stratus
  39. left head light and tail light out
  40. replace back dash speakers
  41. Power Steering Pressure Hose
  42. 01 Stratus CD Player not working
  43. Check Engine Light, and tink sound
  44. # 20 yellow Fuse Keeps Blowing 99 Stratus
  45. 1997 Stratus Codes
  46. 96 Stratus stalling problems
  47. 96 Stratus stalling problems
  48. horrible noise when i switch from park to drive on my 2000 stratus v6 when its cold??
  49. Yet again.
  50. Vertical headlite adj 2003 Stratus
  51. Egr
  52. 2001 r/t computer?
  53. 2003 stratus wiring diagrams
  54. '98 Stratus oil light
  55. Is it posible to ......
  56. 98 stratus se
  57. never worked on a stratus
  58. oil sensor?
  59. Bleeding Fual Inj. System after elec. pump install HELP
  60. Quick question
  61. Opinions any 1 ???
  62. 02 stratus w/2.4l
  63. trouble codes
  64. fsm for 2004 status
  65. code p0456 control system evap
  66. 1996 Dodge Stratus
  67. body kit for 01 stratus sedan
  68. Anyone have this problem before???
  69. 2001 dodge stratus fuse block
  70. parting out a 97 breeze
  71. 2002 R/T has Noise at Pass. Front End...
  72. 97 dodge stratus check engine light
  73. 2000 Stratus -no heat
  74. Tranny problems?
  75. tune up 2.4L stratus
  76. 97 Stratus Leaking water
  77. Sway bar
  78. 97 Stratus- PCM
  79. 2002 Stratus No Power
  80. '97 Stratus Won't Start
  81. stalling problems-help
  82. has this been done befor
  83. speakers, dash problem!!
  84. Guage cluster/electronics problems
  85. head gasket
  86. Motor Mount
  87. Fuse blowing
  88. whats wrong with my cluster?
  89. Performance question on an '03 Dodge Stratus
  90. low oil pressure and white smoke
  91. Bad Tranny???
  92. Various intermitent problems
  93. location of the input turbine speed sensor
  94. check engine light
  95. Failed Emissions Test - Help!
  96. 97 Stratus Tranny trouble
  97. Does a 2.0 liter SOHC 96 Neon have a non-interference engine?
  98. C O 2 Censors
  99. Changing the light bulbs in a 99 Stratus
  100. Changing Breaks?
  101. my airbag light pops on and the steering wheel is clickin??? help!!!
  102. What changed?
  103. would you buy one twice?
  104. power seat
  105. bleeding the brakes did not work!!!
  106. Touch-Up Paint
  107. 97 stratus rough idling/stall after timing belt change
  108. 99 stratus problem
  109. Cylinder 1 Misfire 1999 Stratus
  110. performance parts
  111. not sure whats wrong with brakes
  112. performance for 2.4L
  113. performance help
  114. How reliable is the 2001 R/T? (3.0L)
  115. Loose Engine Rod!! HELP
  116. Help...i luv my Stratus but it has an annoying low key thumping sound in the back
  117. Is this where the AA meeting is J/k.
  118. Stopping while driving
  119. performance
  120. 1998 Dodge Stratus will not start
  121. 98 Stratus won't start 2.4L
  122. pcm
  123. 1998 Stratus 2.4 Cylinder 1 misfire problem
  124. timing belt help
  125. keyless entry
  126. DSM3D v1.0.0.1a Released! 420a
  127. What kind of Fluids for 2003????
  128. 97 dodge stratus
  129. Another question
  130. no engine check light, no spark no fuel pump
  131. 1995-2000 Haynes repair manual for sale
  132. Horn just clicks on 2005 stratus
  133. timing belt 98 dodge, is it a non interference engine?
  134. engine codes
  135. 2001 Status Please HELP!!!!
  136. Engine whining in 05 stratus
  137. pulling engine from 99 stratus
  138. 2000 Stratus intermittent cruise control
  139. 95-99 recall
  140. Need some help with a 96 Dodge Stratus
  141. 2004 status a/c water drains on passenger floor
  142. Stratus wont turn over - Fuses keep blowing
  143. Brakes.
  144. Car doesn't start or turn over
  145. help with cold air intake
  146. Serpentine Belt Runs On This Part... Help me find out what part?
  147. 2000 Stratus SE
  148. Spoiler
  149. 04 stratus
  150. 2005 r/t radio upgrade
  151. Is the newer 2.7L V6 any good?
  152. Code 34
  153. Stratus pcm/asd fuse
  154. Drivetrain problem
  155. 2000 Stratus with Oil in the radiator
  156. 1998 dodge stratus overheating
  157. Looking for help
  158. Rear main seal
  159. '03 Dodge Stratus
  160. A/C Blower
  161. 02 Stratus 2.7L Gas Problem...Maybe
  162. 2004 Dodge Stratus
  163. More Power
  164. Accelerator Problem: 1999 Dodge Stratus ES
  165. 2001 Stratus R/T radio 17" rims
  166. 2003 Stratus knocking noise
  167. Power Seats
  168. 2001 Stratus sedan
  169. cigarette lighter fuse
  170. 1996 Dosdge Stratus Horn location
  171. PCV Vlave Replacement
  172. aftermarket help for 2003 stratus rt
  173. slower than death!!!
  174. 2000 Dodge Stratus - Need your help!
  175. Electrical Trouble
  176. Carfax?
  177. 2.0 L 96'
  178. buy it or dont buy?
  179. fuel pressure 2.5L V6
  180. 97 stratus keyless remote
  181. wheres the oxygen sensor?
  182. oil level sensor?
  183. 2001 dodge Stratus R/T
  184. Need input from stratus owners
  185. oil gauge
  186. I need a Carfax on this 98 stratus i want really bad!!!
  187. 2004 dodge stratus
  188. rims and tires
  189. How do you disable pass. airbag on '99 stratus?
  190. 18" KONIG APPEALS with TIRES 4 Sale
  191. 95 Stratus sensors
  192. turbonator
  193. 2001 se parts?
  194. Several problems with '99, please help!!
  195. Timing Belt
  196. whats the deal with stratus r/t insurance?
  197. '95 Stratus Factory Radio
  198. 2003 Stratus R/T
  199. Car Died
  200. Engine Codes
  201. 2001 stratus r/t keyless remote programming
  202. front end noise
  203. windshield speaker size
  204. ignition/door locks
  205. 97 stratus wont start no spark
  206. Low gas notifier
  207. 04 stratus coupe
  208. 98 dodge stratus will not start
  209. new head gaskit-engine lights on
  210. engine
  211. 2002 Stratus SE 2.7L
  212. 00 Stratus w/ Smoking Steering Wheel
  213. 98 stratus 2.4 HELP
  214. 96 stratus, epileptic seizures
  215. Body Kit Question
  216. Stratus ES 2.4L Knocking Noise (literally)
  217. Engine sputtering
  218. never buy a 98 status-head gasket
  219. 04' Stratus
  220. Idle Problems 2000 Stratus V-6
  221. New Head--No Spark
  222. 98 Stratus ES NO START
  223. 2000 Stratus price
  224. Stratus 96 starting problems
  225. Rattle in 2.4L Engine
  226. How to tell which transmission you have?
  227. A little help, please
  228. do the parts fit look
  229. 1998 stratus es
  230. high pitched engine noise on 05
  231. car starts when it wants to.
  232. 1996 Dodge stratus 2.4 Engine Specs???
  233. strange overheating and engine noise
  234. 2.4L engine Clicking Noise
  235. 99 Stratus ES no start
  236. 96 stratus wont start 1 cylinder no spark
  237. head gaskets abd distributor
  238. water noise
  239. seat covers needed - please help me
  240. 98 stratus parts interchange help?
  241. 97 Stratus - Sat a while...what to expect?
  242. Guide Pins on 2001 stratus
  243. Noise
  244. 2001 stratus starter problems
  245. Ignition Coil
  246. how to drain radiator.
  247. excessive brake pressure to stop 96 Stratus
  248. 96 Stratus O2 sensor replacement
  249. 02 R\T maybe 4 Sale...
  250. 2001 Stratus tag light question (help!!)
