View Full Version : Century
Pages : 1 2 [3] 4 5 6 7 8 9
  1. Stiffest replacement strut ? 95 Century
  2. I Give Up on 89 Century No Start- Need Expert !
  3. Brakes: Having to mash the pedal
  4. 1988 buick century <starters>
  5. 1999 century code p0141
  6. 1998 Biuck Century Window Problems
  7. Wheel Cover Noises
  8. 89 Buick Century wont start if warmed up
  9. 98 century tranny/torque converter problems
  10. 2nd opinion on Climate Control Module
  11. 1987 Buick Century problems
  12. Terminology
  13. A/C Gas-type / Gaskets on 1996 Century 3.1
  14. 00 Century headlights acting weird
  15. 1990 century motor mounts
  16. speaker specs?
  17. eletrical problem and anti freeze
  18. 1999 Century Power Window Problem
  19. Where is ECM located?
  20. No power to radiator fan on..
  21. 2000 Century Speedometer
  22. Sprayed Refrigerent in Wrong Tube - PLEASE HELP
  23. 00' Century window stays up-been repaired
  24. Urgent!!!!
  25. Replacing spark plug wires??
  26. door lock problem
  27. overheating
  28. Acceleration Wobble
  29. 1994 centurty please help me someone
  30. Radiator Drain Valve in 1988 Century
  31. A couple electrical problems 99 century
  32. Fan Level Problem
  33. power antenna problems..
  34. 05 fuel pump
  35. 2001 Buick Century keyless remote programming
  36. 2000 Buick Century shifter lighting dims
  37. a crunching like sound
  38. 1991 century 3.3l misfire???
  39. 99 Century hard to start
  40. 2000 Buick Century 3.1L - Steering Hard Left, Easy Right
  41. Dropping oil pan
  42. 1992 buick century
  43. car won't start after head gasket change
  44. Trunk opens when starting car at night once dark
  45. coolant and steering probs. w/ my 97 century custom 3.1
  46. 2002 Buick Century ABS light on all the time
  47. 92 buick century audio
  48. 91 century struts
  49. temp control/tire pressure sensor
  50. 00' Buick Century Transmission Hard Shifting
  51. Is DexCool bad?
  52. Low Coolant Light
  53. Turn Signal Flasher
  54. White Smoke, Rubber Smell
  55. 1997 Buick Century Radio Swap
  56. 2000 Century: Guage cluster compatibility?
  57. 99 Century Fuel Gauge Reading Empty
  58. firing order for buick 3100
  59. Anyone Know about the different fuel modes
  60. Performance VS Luxury?
  61. AC Problems, Also Transmission.
  62. Tapping noise while idling.
  63. GM Linerat where are you? Motor no crank
  64. broken sway bar
  65. 1993 century window problems
  66. Code PO131
  67. Spark Plug Wires
  68. 99 Century Problems,
  69. 91 Buick Century 3.3 Stalling
  70. Blower fan stopped working
  71. 1988 Buick Century 3.8
  72. Buicks :(
  73. 1994 buick spark plug wire dia gram needed!!!!
  74. stalling problem
  75. Starting Problems?????
  76. P0446 on 2001 Buick Century
  77. Break Light Not Turning OFF
  78. Help: Drifting out of the straight line when I steer in the middle
  79. Where to download the Owner Manual of 2000 Buick Century
  80. 2003 Buick Century Blower Motor Problems
  81. Hesitation problem 93 century 3.3
  82. Rocker Arm Torque Specs. For "M" Engine
  83. Help: 2000 Century shaking in idle/low speed
  84. My 89 century overheated,how to fix?
  85. 2000 Buick Century Re-programming Keyless entry fob
  86. Wiper Motor / pulse board
  87. 98 Buick Turn Signal
  88. Head Gasket Installation
  89. Gasket Surface How clean Is Clean?
  90. Using Torque Angle Gauge
  91. Knocking noise in rear and sometimes front
  92. Whirring/grinding noise under hood
  93. 90 century wagon 3.3 rough idle & shifting
  94. 89 century seats....
  95. '96 Cent. tcc prob.
  96. 89 buick can go faster?
  97. 1999 Buick Century Custom with Low beams problem
  98. 93 Century 3.3L Transmission Mount Replacment Questions
  99. Code P0480
  100. '89 Century Poor Fuel Mileage
  101. speedometer
  102. Dimmer light for mileage
  103. power windows
  104. woodruff key
  105. Fast shifting
  106. squeeling brakes
  107. '86 Buick Century, torque converter not locking up
  108. 89 Century 3.3 Cooling Fan Problems
  109. Grinding Noise Under By Air Filter
  110. How to disable automatic locking
  111. General A/C Questions
  112. 93 Buick Centruy A/c Clutch Bearing Replacement?
  113. 93 Century light switch
  114. 87' century cutting out
  115. Torque question
  116. 98 Buick Century Heat Problem
  117. No Heat with 2001 Century
  118. 97 abs problem
  119. 1989 Century complete tail light assembly question
  120. Misfire code P0302
  121. Door hinge pins
  122. Antifreeze leak 3.1, 94Century
  123. 89 Radio Suggestion
  124. Buick century 2000: remote entry not working
  125. Search Function Century Forum
  126. Window lift motors
  127. boxed vs carded inner door handles?
  128. '92 Century Radio Problems
  129. tranny problems
  130. 91 century 3.3 trouble
  131. removing dash on 98 century for blower motor
  132. R/r Ignition Switch And Cable
  133. 96 Buick Century Stalling Problem
  134. heater issues with my buick centruy 1999
  135. Collapsed!
  136. 1998 Century - Broken Stabilizer Bar
  137. 99 buick century problem with power?
  138. 92 century fuel leak
  139. 93 Century Rear Axle/Carrier Replacment
  140. intake manifold gasket - leaking antifreeze
  141. 88 buick century radio removal
  142. 98 Buick Century digital temp control
  143. 2.5 head gasket
  144. 2002 century dash light question
  145. '92 Century starter removal
  146. 96 Buick Century No Forward Gears
  147. 94 Century blowing cold air
  148. 1991 Century 3.3 Hesitation
  149. 93 Antenna Problem
  150. Fuel leak 99 3.1
  151. 91' Buick Century stereo advice
  152. climate control 2000 buick Century
  153. '03 Buick Century heater/defroster
  154. Spark plugs
  155. AMP Install help
  156. 91 century power windows
  157. 98 Century Transmission Question - No Reverse
  158. trunk release button
  159. 1995 3.1 SFI Century MASS AIR FLOW NUMBERS
  160. 94 century stalling
  161. '90 3.3 into '95 3.1 V6 swap?
  162. 96 Buick Century Power Cable
  163. 97 buick century day time driving lights
  164. transmission question, rattling at startup
  165. 90 century stalls when cooling fan comes on
  166. Dead electrical 95 Century
  167. headlight dimmer switch problem
  168. 1990 Century Possible Fuel Pump Problem
  169. 1990 stalls when taken out of netural
  170. keyless program for 1996century
  171. 1994 Buick Century 3.1 Idle problem
  172. 3.3 buick century
  173. Help, century shuts off even with cps replaced!
  174. 93 Century 3.3L No Start
  175. keyless remote program 1997 century, help?
  176. front signals not working - 98 Century
  177. Dual Climate Control Panel Light Problem
  178. banging noise
  179. power windows
  180. 1993 buick century valve lash adjustment
  181. 94 buick century help
  182. Cd player in 2003 century
  183. 1993 century wont start
  184. Century 2000 power window switch
  185. 1990 Buick Century misses
  186. Interior,exterior lights lights slow dim, go out
  187. 1990 Buick Century nes fuel pump and filter
  188. 1989 Century Cooling fan won't come on
  189. 1993 buick century timing
  190. parts interchange
  191. 98 Century, brake *clunk* when I shift from P to D.
  192. Reprogram Odometer
  193. 94 century vibration under load
  194. 1994 Buick Century stalls at stop
  195. Dead
  196. Need some help with 1998 Buick Century, any input appreciated.
  197. fuel pump fuse
  198. 2003 C Custom - replace radio/cassette unit?
  199. anti lock brake light
  200. 1984 Buick Century Cowl Install
  201. 1993 buick century 3.3 timing chain replacement
  202. Lights out?
  203. 1994 Buick Overheating, stalling
  204. 1988 Century stereo installation problem
  205. random engine misfire - P0300
  206. radiator
  207. pressure switch a/c
  208. Dash Lights
  209. wheel speed sensor
  210. Coolant probs 2001 century
  211. 88 Buick Century
  212. 1994 buick century TCC troubles
  213. your new moderator
  214. 1999 Buick electric windows
  215. 1993 Century - climate control $.02 clip broke!
  216. 94 century 2.2L engine misses
  217. 96 Century not sparking after a rebuild
  218. 98 Buick Century cooling system
  219. 2003 Buick Century Gas Guage
  220. '87 Buick Century 2.8 Cooling Fan
  221. rotating tires
  222. Where Is Turn Signal Flasher???
  223. 2003 century remote programming
  224. 92 Century ft left caliper lockup
  225. Check engine light
  226. 98 century split zone AC not working right
  227. 98 Century Hard Starting when cold
  228. HELP! Car adding miles all by its self...IN PARK
  229. Service engine light and gas tank
  230. 1994 century no TCC lockup when hot
  231. Electrical, Crank bolt, CPS
  232. Please help,tell me where the cps sensor is in my engine I have pics inside!!
  233. checking codes??
  234. please help transmission won't down shift??????????
  235. 1991 Buick Century Check engine light
  236. 89 Century shuts off in the middle of driving please help!!!!!
  237. 00 3.1 Code P0410
  238. 98 A/C comp knocking
  239. Supercharger for 97 century?
  240. Service Engine Soon Light-Need ideas
  241. Buick Century 2003 Air Condition Does Not Work
  242. 1998 Buick Century issues
  243. A/T shifting very hard into 2nd gear
  244. 3.1 Liter Idle Problem
  245. What oil do you use?
  246. 1993 Buick Century Tranmission automatic
  247. Weird fan problem
  248. Need help on Changing a thermostate on a 89 Centruy w/3.3 V6
  249. considering 93 Century- 6cyl engine questions
  250. transmission question
