View Full Version : Century
Pages : 1 [2] 3 4 5 6 7 8 9
  1. Need help with column movement problems!!
  2. Hill hold
  3. 02 Fuel Gauge
  4. Tips on how to install K&N Air Filter ?
  5. '93 3.3 rough idle, stumbles off-idle
  6. trans bangs when hot
  7. 2000 Buick Century question on codes?
  8. 1999 3.1L bad hessitation/bogging on accel
  9. Engine burning coolant
  10. P0302 cylinder 2 Misfire
  11. 1990 Century V6 no power, won't start
  12. 2000 buick century won't start
  13. flashers
  14. 1996 Century 3.1 Intake Gasket
  15. 2000 century-power windows
  16. 88 Buick century stalling problem
  17. 1996 Buick century vacuum hose problems
  18. 1997 buick century how to remove crankshaft pulley
  19. 2000 Buick century ignition switch replacement
  20. Engine sounds like it's going up and down when in idle/park???
  21. 3.1L to 3.8L swap?
  22. Weird problem with climate control
  23. Code P0401
  24. Electrical problem. No power.
  25. ELectrical Problem with the digital odometer
  26. 89 Century-transmission band adjustment
  27. missing when accelerating
  28. Rocker arm torque
  29. 96 Century won't start when cold
  30. New interior dash trim for my Buick check it out!
  31. 96 buick century stalls
  32. odometer reading
  33. Where is power lock relay?
  34. Struggling to install heater core
  35. 99 Century Security Light
  36. power window 1998 century
  37. Will a 93 Century Motor & trans fit in a 94 Century?
  38. 1994 buick century
  39. remote starter question
  40. 99 Buick Century gear noise around Power Steering pump.
  41. Code P0481 on 99 Century
  42. 02 Custom anti-lock + lights on
  43. 1999 Century Headlight Issues
  44. No taillights
  45. '02 Century low coolant light stays on
  46. Clunk when turning left from a stop - 94 buick century
  47. 92 Century Lock issue
  48. '89 Century Wagon - Reverse lights inop... please help.
  49. Service VEHICLE Soon light
  50. 99 Buick Century OBD code P0405
  51. Determining C60 or CJ3 99 Buick Century
  52. 1987 Century 2.5 ECM Trouble
  53. Questions about Buick Century
  54. 02 window switch
  55. 89 Century - kicks while driving
  56. 98 century trans won't engage. No R or D.
  57. Stuck in second
  58. Headlights dont work - Please help an old woman out
  59. 1992 century radiator prob.
  60. stalls out when idling
  61. Century-AC Fuse Blowing
  62. error codes
  63. buick century 2000
  64. rear running lights and dash lights stopped working
  65. Intermittent Speedometer
  66. tranny shift solinoids
  67. 92 Buick Century (changing thermostat)
  68. 2002 LR brake problem
  69. Changing transmision pcs-need expert advice
  70. 95 Century diagnostic tool ?
  71. 1999 century Bushings
  72. How much will it cost to get the windows TINTED on a 98 Buick Century Custom?
  73. torque converter solenoid
  74. OBD1 Codes '95 Buick Century
  75. 96 3.1 in a 98 century???
  76. 98 century will not start
  77. 1997 Buick Century radio code loc
  78. 2002 codes po446 po452 po453 ????
  79. parking brake adjustment
  80. 1995 Century radiator flush issue
  81. Horn has low volume when activated.
  82. ABS lights
  83. 92 Buick no spark
  84. How much fuel is left in tank when fuel warning light goes on in a 98 buick century?
  85. Rattling noise coming from left side of car by the wheel when driving
  86. Something is inside the oil pan of a 1988 Buick Century, 4cyl, 2.5L
  87. Just bought a 98 Buick Century Custom. How is this ride overall?
  88. sometimes rough idle on start then dies
  89. Blower motor not working
  90. 1996 Buick Century Problem
  91. 1995 buick runs hot
  92. '04 alternator torque spec's
  93. Dash LCD problem on 2000 Buick Centry
  94. 03 Buick Century Stalling w/ A/C on
  95. 2002 century abs problem
  96. 2001 Century Backup Lights
  97. 1999 crankshaft position sensor
  98. '96 Buick Century
  99. 96 Century, problem areas?
  100. 2000 century custom battery drain
  101. how do I get down pipe bolts out?
  102. Intake gasket or head gasket??
  103. What would a 'slip' feel like while driving?
  104. Two Primary Issues
  105. Brake trouble
  106. 1998 century air problem
  107. Letting my car sit for 2 yrs.
  108. '95 Buick Century Custom Battery light and overheating.
  109. 2002 speedometer consistantly reading fast...
  110. remove turn signal lever 95 century
  111. 94 Century timing problems
  112. 1990 buick century 3.3 water leak
  113. repair or replace '95 3.1L?
  114. 88 buick century water pump 2.8L
  115. All the Dash lights going off and on
  116. 95 Century ABS light on. Cruise not working thermostat gauge not working.
  117. 2000 Century Front Struts
  118. 92 Century manual seats
  119. Steering column at tilt lever loose '88Century
  120. 98 buick low fan switch not working
  121. 1995 buick century gas cap
  122. 2001 Power Steering presssure buildup
  123. 2000 Century Vibration
  124. Car revs itself and shuts off when stopped
  125. Problem w/ tranny
  126. 95 century with 3.1 engine quits running
  127. Supercharger
  128. BNaylor Buick Century trans ?
  129. Chewed off spark plug wires 1999 Century V6
  130. 99 Century Security Ligh
  131. 1998 Buick Century Hesitation/Stumbling
  132. Holding First; sometimes not going in at all
  133. 1995 Buick century overheating
  134. 2000 Century shifting hard
  135. Brake shoes sticking?
  136. Popping sound and roaring on 99 Century
  137. ABS and trac off lights on
  138. '91 Century gets broken by shop
  139. weird charging/alternator problem
  140. 02 Century AUTO Door Locks
  141. 92 century still not starting in the morning
  142. 1990 6cyl Buick Century Muffler Help
  143. 1999 Century Trac Off and ABS lights
  144. Rotating 3.1 v6 engine questions
  145. 94 century, no headlights,brakelights,radio,doorlocks
  146. 02 Century transmission problems
  147. Buick Century 2001 Cruise control issue
  148. 1999 Buick Century LIM bolts - torque & sequence?
  149. anti lock brake light
  150. 1990 Buick Century Tranny Lever Adjust
  151. 88 Buick Century rear shocks
  152. 2000 ABS sensor/wheel hub assembly
  153. 92 century Ignition control
  154. TV Cable Adjustment
  155. 94 Century window problem
  156. 1999 Buicky Century Custom parts list?
  157. 1999 Buick Century Custom
  158. 2002 buick century "slight thud and moaning" sound
  159. '91 Century 3.1L won't start on hot
  160. 94 Century Fuel Line
  161. 92 Century wont start
  162. '94 Century rim interchange?
  163. 94 Buick Century
  164. coolant level
  165. 89 Century 4 cyl - no spark
  166. auto headlights
  167. Changing spark plugs on a 99 Century
  168. Weird Electrical Problems
  169. 2004 Century Headlights
  170. Century 2001 Headlight voltage drop.
  171. Code reader
  172. 1996 Century Ticking & Sluggish
  173. 03' century leather seats ??
  174. Any issues with 2005 Century?
  175. 03 Century Remove Back Seat
  176. Inoperative Cooling Fans
  177. stalling and back firing problem
  178. 97 Buick problems
  179. 99 century weird brake noise
  180. 2002 Buick Century transaxle problem
  181. 1994 buick century stalling-please help
  182. 1998 century weird
  183. 1991 3.3L Won't start when cold
  184. no power buick
  185. Great Solution to 4T65E Hard Shift, P1811 DTC
  186. 99 Turn Signal
  187. 94 Buick Century losing coolant
  188. 2001 Heater blower stopped working
  189. brake lights staying on
  190. 1994 buick
  191. Climate Control Stopped Working
  192. 2001 Wipers stop in wrong area
  193. 92 century stalling
  194. Regal bumper cover for century
  195. 1994 3.1L Century Electrical Problem
  196. 89' Buick Century running funny
  197. heatercore flush procedure
  198. Seat Belt Replacement
  199. Speedometer just quit, But..
  200. Century 3.1L won't spin when hot
  201. 1994 buick
  202. New A.I.R. pump doesn't solve P0410 code issue
  203. 2001 rear speaker removal?????
  204. 1996 Century Radio Light
  205. 1996 Century Torsional Popping
  206. 99 Century Wipers Overdriving
  207. 1988 Century stuck in Park
  208. Buick door buttons trunk release problem
  209. 95 century runs hot
  210. `03 Century rear brakes Squeal
  211. Speedometer Going Crazy and Battery Light On
  212. High beams not working.
  213. 2001 Buick Century, just bought used, any thing to watch for?
  214. Coolant leak chain case gasket?
  215. 1990 buick centuy, 3.3L V6 custom
  216. icm
  217. cam sensor
  218. Intake Gasket Replacement
  219. cooling fan question
  220. 2004 Century
  221. 95 buick century stalled won't start
  222. 96 Century starts funny
  223. loud A$$ noise when breaking!!!
  224. turn signals just wont work!
  225. 2002 Buick Century Auto Headlights going off
  226. 2000 Buick Century Cylinder 2 Misfire
  227. 1996 Century 3.1: Speedometer calibration
  228. 1996 Century 3.1 ABS brake diagnosis
  229. 1996 Century 3.1: Operating Temp
  230. Steering - lower arms bushings on 2000 Century
  231. 95 buick century shuts off
  232. '95 Century-Fixing Defrost?
  233. Climate Control Problem
  234. 1999 C custom climate control issue
  235. 'Service Engine Soon' Warning light
  236. Transmission filter and fluid change
  237. 95 Century Coil problem
  238. New owner of a 2002 Century
  239. Head Gasket or Water Pump?
  240. brake issues
  241. Crankshaft Position Sensor How to Change? '92 V6
  242. Headlight delay
  243. 1998 Buick Century Fan Noise
  244. Tilt-Steering column has a little play in it.
  245. Squealing Noise
  246. Temp gauge close to 'C'
  247. 89' Buick Century Fuel Problems?
  248. Anti-Lock Brake Light
  249. Emergency Brake Light
  250. Turn signals don't work
