2.5 head gasket
crewdawg692
12-13-2007, 07:28 PM
It's been awhile since I tour a motor apart I just installed a new head gasket on a 85 2.5 buick after installing before startup whats the best? a shot of oil in sp.plug holes and turn over or any other Ideas thank you!!
GTP Dad
12-14-2007, 07:00 AM
You should be fine without doing anything especially if you just changed the head. If you can disable the ignition in order to pump a little oil first that will work but otherwise just start it up. Allow it to idle for a couple of minutes before reving the engine just so that oil gets to the upper parts of the engine.
crewdawg692
12-14-2007, 08:21 PM
Appreciate the help should finish it tommorow What I should be doing is rebuilding the 70 ' 350 instead that I have! Just need a body of something use to have a 1967 R/S Camaro with a punched out 327 baby came on like gang busters!!!!!!!!!!
