View Full Version : Century
Pages : 1 2 3 4 5 6 [7] 8 9
  1. Slight Rust spot
  2. OK, now I am confused, and angry
  3. 98 century - oil change frequency
  4. My fan only blows on the highest setting
  5. 1990 Century Flasher?
  6. 2 questions about my new 93 century.
  7. Turn Signals Quit
  8. 2001 Cent *cold* slips in R and thunks ONCE into 1st
  9. 2000 Century rough shift to 3rd and overdrive
  10. 94 Buick Century Electrical Problems
  11. Light help with century 3.3
  12. drive axle retaining clip
  13. Replacement belt for '89 Century with 3.3
  14. Engine Swap? 3.1V6 to a ??V8?
  15. 3.1 Ignition Coils
  16. no instrument panel lights
  17. 3.1 Help!!!
  18. OBD computer
  19. Dual Exhaust
  20. Tie rod lubrication
  21. wiper stuck in an upright postion
  22. chang oil on 98 Century
  23. No Heat
  24. 1996 Buick Lemon (Century)
  25. Oil leak
  26. How to check if my 93 Century has remote entry installed?
  27. 89 century, check engine light-loosing some power
  28. 1998 Century is a rough ride....
  29. Door Wiring
  30. 98 Century AC system
  31. body work buick century
  32. '85 century, can seem to get it right
  33. 1996 Buick Century
  34. 1996 buick century
  35. How's it work--A/C condensor fan
  36. 1990 buick century won't start
  37. 1997 Century ABS
  38. 1992 Century Electrical Problem
  39. Error Message 2002 Buick Rendezvous
  40. Power brake booster leak
  41. New Century owner with questions
  42. 94 Wagon - Alternator overcharging, front power windows broken, now won't start.
  43. Recall
  44. abs light on, cruise & back dash brake lts inop
  45. Water on rear passenger floorboard
  46. 1989 Buick Century Won't start in the cold
  47. 93 Century V6 water pump pulley
  48. 95 Lesabre Missing Severly
  49. Need help with steering column dissasembly please
  50. weird clay / rust in radiator
  51. My engine refused working while i was driving
  52. 1994 Buick Century needs flasher fuses
  53. need help with a 1993 century stalling
  54. Changing fuel injectors
  55. 89 Buick Century won't start
  56. 1996-Century Programming remote entry
  57. Need speedometer cable for 1985
  58. service engine soon light (yellow)
  59. 90 century limited rear deck speakers
  60. ignition wire
  61. OEM radio replacement question
  62. On the road, But still more Problems
  63. Concert sound rear speakers don't work
  64. 2000 Century Auto Transmission
  65. I am currently looking at a 96 Buick Centery
  66. "e13" error messeage on tape player
  67. Sun visor needed
  68. Buick Century 2000 No low / High Beam lights
  69. online manual for a 86'er
  70. 2004 century stereo rumble
  71. 1989 Century hard shift on first shift only
  72. Man! this was STUPID!
  73. 96 Buick Century - "Anti Lock" light on Dash
  74. eratic downshift when at cruise speeds
  75. Back door windows
  76. Carpets (front - floor) carpets wet.
  77. 1993 Buick Century HELP ME
  78. front ends
  79. 1992 buick century 3.3, won't start
  80. 1998 Cam position sensor location?
  81. Check Engine Light...Please help
  82. Front Ashtray Needed, Century Custom 1998
  83. 1993 buick century problems starting
  84. Freaky warning lights!
  85. Brakes are crappy
  86. trany slips wen i accelerate, why?
  87. I Have A 1992 Buick Century And Won't Stay On
  88. Where's the fuel pump fuse/relay/killswitch for a 1993 Century
  89. How big of a job is replacing heater box on 98 Century
  90. Head Gasket redux?
  91. 2003 Buick Century Keyless Remote programming?? Anyone??
  92. 95 century stuttering
  93. Oil change question
  94. stupid wires!
  95. Replacing the Transmission Modulator Vavle
  96. 2002 Headlamp Short?
  97. Thermostat
  98. New Starter Question
  99. 1993 Buick Century Wagon 3.3L v6 Fuel pressure problems.
  100. 89 Century Rotors Stuck
  101. Good website
  102. 2nd Post
  103. 98 Century - Where is HVAC air intake?
  104. Help! Problem with warning lights on 2000 Century
  105. Lifters tapping 3.3 liter
  106. Performance Info
  107. 98 Buick Century Good, Bad, and Ugly
  108. Heater Core
  109. Need body color number for 1995
  110. 97 Buick Century surges while applying power
  111. Anti lock light on after changing plugs?
  112. Thermostat
  113. Replacing serpentine belt
  114. Damn vacuum system
  115. High NOx emission
  116. 91 Century 3.3 Mystery Leak
  117. 4T65E Transaxle Recall?
  118. 2000 Century Oxygen sensor(s)
  119. 1985 Century Blower motor & Speedo not working
  120. Code Questions
  121. Lack of power
  122. no spark from 3 plugs on 88 century
  123. 1989 buick century blower motor
  124. 98 heater only works on Med/Hi & Hi
  125. 97 century EGR flow insufficient code problem
  126. 1993 century transaxel problem
  127. problems on 91 3.3l with 273,000 miles....
  128. century keeps dying
  129. 90 century wont start!
  130. 91 2.8L celeb trans in 94 3.8L century
  131. 95 Century blazing through oil!!
  132. Tranny Service Flush
  133. 89 century wont start?????
  134. ABS Light
  135. keyless entry
  136. No ABS or Cruise. 95 Century,everything else works
  137. Removing door panel
  138. '94 Transmission Problems
  139. 91 clunking noise
  140. Check engine light
  141. 1993 3.3 stalling issue. Help needed badly
  142. A 1993 Buick Century
  143. Code 29
  144. Performance
  145. Very Wierd problem
  146. Tie Rod and plastic rear bumper
  147. 96buick runs rough and dies out
  148. 87 buick no spark
  149. 1990 Buick will crank but not start
  150. My Car Keeps Stalling
  151. 1995 Century Problems
  152. 1995 Buick Century Seat Question
  153. trunk leaks
  154. '91 Century starter motor removal
  155. 98 Buick Tranny
  156. Is THis Normal?
  157. Worn 'Tie Rod' at 49.000 km ?!
  158. Injector Control Cicuit
  159. Wire Hub Cap Lock Removal Tool
  160. WTF is this?
  161. driver side window electric
  162. 87century starts cold but not hot
  163. 97 Buick Century ..?Heater Core?
  164. Need part for 1998
  165. 1989 Century heater problem
  166. 75 Gran Sport
  167. PCV Location 3.3L Engine?
  168. Pimp Centuries
  169. Torque Settings?
  170. Buick Century 1995 Skips all the time
  171. 98 Century blower motor
  172. Duel Automatic Comfor Temp Climate Control. HELP
  173. newbie needs help.Please!
  174. HELP, 89CENTURY 3.3 STALLS intermittenly
  175. 95 Century-Engine Won't Shut Off
  176. update on the trunk lighting problem
  177. 2001 Buick Century Limited Radio Problem
  178. cold weather starting
  179. 92 Buick Century Having 2 Problems
  180. 86 century custom stalling problem
  181. Electrical Phantom!
  182. Automatic Headlights
  183. O.K. it's official. My car's annoying!
  184. 1987 Stalls, need help please
  185. Tail Light Assembly 2001 Century
  186. Raising Springs
  187. Need wiring schematics for 81 Buick Century
  188. 81 Buick Century coil pack problem,HELP!
  189. Where's the TCC plug?
  190. Water sloshing in dash
  191. Cruse Indicator Lamp
  192. Brake Drums off How? buick century 92
  193. Lots of Problems!!!88'Buick Century
  194. auto. trans prob
  195. 1998 3.1 missing-
  196. Shifting problems
  197. Need Some Help Please 1995 Buick Century
  198. I call it quits!
  199. driver side heater doesn't work
  200. buick century wagon brakes
  201. 97 Buick Century Driver Side Airbag Installation
  202. Need code discriptions
  203. driver window and driver seat issue
  204. 3.3L V6 QuEsTiOnS
  205. Cruise Control
  206. 95 Century transmission problem (?)
  207. Power window problem
  208. Where's my Heater Blower?
  209. Rack and Pinion Going
  210. 99 buick centry probs
  211. 92 century antenna?
  212. 2000 Century TCC issue
  213. defroster turning off after 3 minutes
  214. need help with starter
  215. My century interior
  216. 91 Century Head/Tail Lens
  217. 91 buick century jerking/overloading gas help!!
  218. Dual Exaust Possible?
  219. High Beams Shut off while driving
  220. Buick Century Lowering springs!!!!!
  221. front wheel bearings whine
  222. 89' 3.3 V6 Starter!!!!!!
  223. im new here and have a question
  224. Power Window dead, 96 Century
  225. 91 Century trunk
  226. 89 Century - Belts and Power Steering Fluid
  227. HELP check engine light!!!!
  228. Automatic HVAC Controls on Limited Edition
  229. Headlight relay for 93 Century (and other 1988 and newer GM)
  230. '93 Century 3.3 service engine soon light
  231. New recall info: 99 Regals/Century's
  232. BUick Century
  233. 93 buick centry exhost gasket insrtallaiton
  234. Check Engine Light and Clicking
  235. Brakes Screeeem
  236. 1989 century, a/c stuck in vent position
  237. 1995 century....rev limiter kicks in when passing
  238. 2004 Century knobs
  239. 1992 Century - Antenna issues
  240. '95 century transmission
  241. 1997 Buick Century security
  242. 1990 Century Sudden Death
  243. Hub-bearing and anti-lock brake light
  244. 97 century air flow problem in HEAT position
  245. Help want to do a manual swap into 1991 century custom 3.3
  246. need to disable
  247. Cheap ways to diagnose Sensors
  248. 2000 Buick Century hard start/stalling
  249. 1995 century 3.1, runs when it wants to
  250. how much fuel pressure is a 93 century.....
