View Full Version : Nova
Pages : 1 [2] 3 4
  1. 1/4 opinions
  2. Rear end change
  3. Need Clock for 70-74 dash with knob
  4. 73 Nova Exhaust Headers?
  5. neutral safety switch wiring
  6. Rear Axle Gear Ratio
  7. whats a good raditor
  8. 72 nova with reverse problems?
  9. Looking for opinions on brakes
  10. My 70 Nova does not have reverse???
  11. is chevy 250 tranny interchangeable with 350
  12. I Need Help
  13. backspacing on wheels
  14. vapor lock
  15. wheel sizes
  16. 66 Nova's got the shakes
  17. Backfire through carb
  18. Dwell and carb idle problems...
  19. I need a nova
  20. Need help finding 73/74 hatch
  21. th350 wont go into gear
  22. 72 nova
  23. 63chevyIISS
  24. Nee a 77 Nova throttle cable
  25. My Nova 87 has lots of problems...
  26. beginning of total resto-mod
  27. Super Chevy Epping,Nh
  28. Wiring Up Tach?
  29. Nova Ignition Hardware inside steering column
  30. 373 posie rear end
  31. Parts wanted
  32. holy crap
  33. 73nova original paint removal
  34. BB crank pulley info
  35. just got my first nova
  36. Turbocharger Help!
  37. rear impact bumper strip
  38. Sagging SS
  39. BBC header interferance
  40. frame mount replacement
  41. Noisy Voltage Regulator -71 Ventura
  42. New here
  43. Steering Hub Qusetion??
  44. Converting from column shift to Hurst promatic 2
  45. Leaf Spring Clips
  46. Ford 9 Inch Conversion - 68-72 Nova
  47. 70 BB Nova P/S hoses location?
  48. The Ultimate Nova ???
  49. In need of 73 Nova VIN tag and Title
  50. 71 Quarter window trim
  51. Transbrake Help
  52. '86 tpi 305 into '69 w/ 250-6 & powerglide?
  53. 66 chevy nova
  54. 62 nova center link
  55. tranny issue
  56. 75 Nova.....need body parts
  57. '66 nova / mustang II front suspension??
  58. Tire size, rim size, how big is your limit?
  59. What brand of shocks?
  60. Chrome spray paint- cheap fix or big no-no??
  61. kickback
  62. 74 Nova - Lookin for...
  63. Rearend/suspension on 77
  64. replacing shocks
  65. New to Novas- '77 with 406, rearend has major problem
  66. rear windows.
  67. 350SBC to 454BBC
  68. starting issue needs resolution
  69. CHROME rear quarter window trim
  70. brake shoes!!
  71. stupid enterior question
  72. Restoring 71 Nova SS - graduation project
  73. 1964 Nova headers
  74. for sale
  75. flat black paint
  76. Front End
  77. 1968 SuperNova
  78. why novas?
  79. 77 nova
  80. 73 nova steering part needed (wanted)
  81. Ring and Pinion info
  82. 1969 Nova Rear End housing code?
  83. Rear end transfer
  84. Need help with '79 Nova
  85. nova subframes
  86. Best of the Best
  87. Should I put on a higher ratio rear axle?
  88. Powerglide
  89. Need some NOVA parts?
  90. Bucket seats for a 71 Nova
  91. need help w/ 74' nova wiring.
  92. tubbing out my fender wells ???
  93. question on window channel clips
  94. 74' need help
  95. '75 Nova Parts (wrecked car)
  96. floor mount shifter
  97. window molding clip question plz help
  98. Problems with my 71
  99. Owner of 78 Nova RS
  100. real SS or Clone
  101. battling rust :(
  102. console
  103. 63 Nova Rear end
  104. can i afford to make a 1975 nova fast?
  105. electric fuel pumo advantages
  106. Power Drain in 77 Nova - HELP!
  107. dash trim
  108. Crashed Nova parts lot
  109. subframes
  110. need help!!88 chevy nova
  111. tranny cover
  112. Engine and Tranny
  113. Auto to manual tranny
  114. 63 nova starter problem
  115. mount coming through the floor
  116. 88 Nova fuel filter
  117. Crashed 71 Nova-Pictures
  118. Disc Brake conversion
  119. Transmission linkage
  120. PS Crashed 71 Nova parts...
  121. 71 Nova totalled, parting out
  122. 63 nova ss for sale!!!!
  123. accelerator cable 71
  124. Chevy2 Tpi swap
  125. 63 Nova 2dr Bolt-in X-reference
  126. In Need Of>>>wanted
  127. Gas tank?
  128. 1968 Gauge Instrument Panel
  129. 400 sbc block info needed!
  130. 72 and 73 doors
  131. 65 Nova trim piece
  132. port polish
  133. Original Owner needs help looking for his 69 Nova
  134. TH350 or Powerglide?
  135. need posi rear carrier
  136. Doulble hump camelbacks sb chevy heads for sale
  137. rear swap
  138. Auto to Manual Swap
  139. nova door shell 72
  140. Heat shrinkable vinyl covering
  141. 70 Nova 350 4bbl thottle linkage
  142. engine ground
  143. going ot be looking for a nova in mid february up to $1k
  144. asking price
  145. windows and weather stripping
  146. 70 nova brake problems
  147. How to remove Windshield and Trim?
  148. help with brake lights
  149. needing 68-72 moulding for door around window and back quarter window
  150. Alternator wiring
  151. 1966/67 Chevy II
  152. Roll Cage
  153. tires rubbing...
  154. need 69 nova roof
  155. vapor canister removal
  156. 72 nova windshield
  157. Crate SB or BB?
  158. Replaceing Rocker Panles
  159. carb prob
  160. 70 Nova - blower motor only works on low
  161. 1970 nova wheel limitation
  162. trouble
  163. what is this?
  164. a/c compressor and box for sale
  165. New guy - Frame to body Bushing replacement
  166. parts for a 73, please!
  167. 76 nova i found on craiglist in california $400
  168. Which Heads to use on a SBC
  169. new and looking for this part??? or any help
  170. 62-65 nova rear end swap; HELP!!!!
  171. Door hinge pin replacement
  172. Power steering
  173. tranny help
  174. '73, needing some help
  175. My 68 4 door nova
  176. breaking in my 350
  177. 73 nova overheating no one knows why?plz help
  178. 73 bumper on 72 mounts
  179. Tune up HELP/ emission stickers?
  180. distributor help...
  181. distributor help...
  182. 1962 Pro Street Nova for Sale or trade
  183. powersteering brackets?
  184. freeze plug count...
  185. ' 78 6 Cyl Freeze Plugs
  186. Ping Thing
  187. 73 windshield
  188. 64 Pontiac Acadian power steering
  189. 63 Nova Tubbed
  190. 6 Cyl motor mounts
  191. 77 nova...swaping 6cyl for small 8 will trans mount work?
  192. 1970 Nova Floor Replacement
  193. 73 nova hatchback heater core how to remove?
  194. new guy w a 68 Nova
  195. '64 chevy II manual flywheel
  196. 94 350 in 73 Nova
  197. 72 nova parting out
  198. Tranny kickdown cable
  199. warning!! BRAINFART QUESTION
  200. tranny linkage help
  201. Too Tall
  202. 1977 nova car help
  203. 74 nova body panels
  204. Allignment problems?
  205. 1966 chevy 2 nova big block motor and frame mounts
  206. 73 nova bumpers
  207. rear differential gear ratio
  208. 6cyl to V8 70 Nova, mount ?
  209. Engine Parts
  210. 8.5" rebuild problem
  211. th-350 to 4speed
  212. BB header fitment
  213. chevyII 6cyl headers
  214. BOLT PETTERN on a 73?????
  215. stock wheel backspacing
  216. SMOKe?
  217. Nova Hood??????need Advice
  218. stripped flywhel bolt
  219. SB chevy 400 crank and 400 rods
  220. 350 heads for sale
  221. Block ID??
  222. what size carb
  223. 73 nova airconditioning
  224. 64 nova
  225. ss stripe dimensions
  226. 1964 nova
  227. Front end rebuild kit Nova vs. Camaro
  228. 1969 Nova on Ebay 4579753099
  229. Tilt column swap 75 up into 74 earlier?
  230. Rebuilt 327 for sale
  231. 1969 nova for sale
  232. 70 nova parts
  233. modern frame replacement for 63 nova
  234. Misc SBC parts for Sale
  235. How much horsepower
  236. For Sale: LT1 long block, complete or parts, dirt cheap
  237. motor swap
  238. Poor driveability
  239. undercar appearance questions
  240. 64 nova posi
  241. 70 nova rear suspension
  242. trasmission modulator how to hook it up
  243. 74 nova 454 what exhaust to use
  244. 74 nova doesn't shift
  245. big block swap
  246. Instrument Panel Removal
  247. No Spark
  248. floor sealer
  249. Wiring help
  250. 396 Timing
