warning!! BRAINFART QUESTION
74NovaNick
11-02-2005, 12:16 PM
where does the negative terminal go from the car battery? Thanks
- Nick
nova68
11-02-2005, 04:16 PM
that is the ground. There is probably a hole in the block for it. So you can take a bolt and bolt it to the block
dnice386
11-03-2005, 05:50 PM
If the cable is too short to go to the block, you can also mount it right onto the frame. On my 76 it actually mounts right onto the alternator bracket. Any good ground will do. Just make sure that you have your engine itself grounded well. I ran into a problem not too long ago where my groundstrap was no good and I had power going to everything all the time. Good luck
AlmostStock
11-04-2005, 01:10 PM
The Nova also has a ground strap running from the front subframe to the body.
