trasmission modulator how to hook it up
abadassbowtie
09-13-2005, 11:28 AM
i have a th350 and i need to hook up the tranny modulator and i don't know were to run the vaccum line to. I am running a elderbrook victor jr intake and there is now were to hook it to and on the holley 750 carb i have two ports one on the back is the big one that my pcv valve is hooked to and the one on the passagner side is hooked to the vaccum modulator on my msd distributor. Were to runthe tranny modulator to.
bobss396
09-13-2005, 11:36 AM
I would just add a T fitting where the vacuum advance line is. Probably cost you a total of $5 at any decent parts store for the T and a short piece of hose.
Bob
brian70
09-13-2005, 08:17 PM
The advance on your distributor should be hooked to ported vacuum you are going to want to find a manifold vacuum source look around your manifold for plugs that may be hiding vacuum sources
nova68
09-13-2005, 08:40 PM
the only thing will he have enough vaccum to run both?
bobss396
09-15-2005, 06:54 AM
The vacuum should be just fine.
nova68
09-15-2005, 06:45 PM
then just t it!
