Grand Future Human-Grade Air-Dried Beef Dog Food
Automotive Forums Car Chat
Volkswagen
> Passat
View Full Version :
Passat
Pages :
1
2
3
VAG-COM & Digimoto/Scantool
97 Passat GLX ABS light on
broken timing belt
1993 VW Passat shuts off/won't start
Rear brake problem on 2002
1996 VR6 Passat Emissions Code
96 Passat Electrical problems Help!
'95 Passat Wagon 2.8L V6
Radio static w/Rear Window Defroster on
passat 98 1.8 20v wont start.
Speakers..Recommendations?
Passat doors freezing
Electric seat for manual seat replacement
seat removal
96 passat wheel bearings replacement?
passat remote control problems.
What is the Spark Plug Gap for a 2001 Passat, 1.8 turbo?
2000 Passat Wont Start
Window problem 2000 Passat
New VW Passat
Throtle Body Problems
torque spec for 96 Passat VR6 (rear brake)
c link ????
Passat Forum Changes
bearing arm check http://www.automotiveforums.com/vbulletin/images/icons/icon5.gif
Extended warranty
Radio Reception
Fuse Keeps Blowing
Central Locking wont work off Key fob??
Mystery vacuum line
Remove covering for oil change
Frequent lamp burn-out
Engine code P1136?? Eh?
"Brake" light comes on on bump
Passat wont start
ABS light on
stalling in low gear
transmission trouble
Different Idle speeds – FWD & 4Motion?
trunk release
Help with changing Passat headlight bulbs
Passat Wagon GLX reverse problem
This is a Challenge - Gauge and cruise problem
www.clubb5.com
PASSAT - No Turbo till 3000rpm then.... look out!
Boschmann Help
turbo whine ?
Dash Lights
service light on 04passat
headlight fuse keeps blowing
How do you remove faceplate covering switches and radio?
Revs after Starting
rough idle with AC on at stop
No *SparK*
Programming Keys
A/C makes a whining sound
passat window regulator
Engine is completely dead
AC stops working
whats the stick hp for a....
Power Windows Problem
passat auto trans
front passenger electrical window not working
fast Mileage counter
power gain
Fuel Leaking at start up
Passat no start
Airbag on
fitting headlight bulbs
dull light
Low cylinder pressure on rear bank
Stalling 16 valves
Key Fob Tuning?
Problems when accelarating above 60mph
Service Lights
Where does the transmission fluid go?
Turbo trouble
Cam position sensor
Itermittent turbo loss
where does it go
Two service related items
Window Problem
Flooding
Question for Passat owners...
useful info for all VW owners...
Need Blaupunkt radio information
Radio code
Passat TDI real use mpg
Why should I buy a Passat
After-run coolant circulation
How to disable ABS flashing light.
Problems, pricing, opinions
Rear Lid Lock Operation on Passat Wagon
Passat Rear Wheel Alignment
Flickering Lights
OBD II Scanner
How to Unclog Pollen Filter
VR6 not firing on all cylinders?
check engine light
What to do....Broken Tiiming Belt
Dead Starter (help boshman)
roof upholstery
passat shirt
Power Windows
2.0 TDI Towing
replace trim light bulb?
Volkwagen Pics
Clutch Problems
Low Oil Pressure Alarm
Changing Rear Brake Light Bulb
Help Removing Water Distribution Pipe
Wheel and tire advice
Passat Passenger SIde Lock
Need wire assembly for VW Passat ASAp
Tires
Transmission stuck in 3rd ????
Can You Take Badges Emblems Off
What's best?
Engine missing at low RPM
TDI? or Not TDI that is the question!
Rear V6 chrome emblem for Passat
SHOCKING NEWS: VW parts are way overpriced
Startin problem solved
Replace parking light / turn signal
Help My Brake Lights Won't Go Out!
survey-Passat Dealer Service
Are Passats Good Cars
91 vr6 passat wont start?
Throttle body Questions... 2.0 16v
Turbo Kits For 2.8L 30V Engine
RS4 kit for the b5
Rotors
battery change
Passat interior staining
timing belt losing tension
Rough Idle - Occasional Stall
my running fault
passat tdi stalling at idle
vw passat problem
A few problems with my 94 Passat VR6
oil drain plug
2.0 16v Yet again, a problem. Oil in Coolant
cruise control fuse
cuzo H7 for sale
How to change Rear Brakes on 01 Passat?
oem passat wheel/tire package for sale
ABS control module problems
2.0 16V problem
reputable mechanic in rhode island
Passat Coolant Leak
Cruise Control-What part is missing?
w8 performance specs
passat cool air intake
Passat Runaway Revs
disconnecting the odometer on 2002 accent
Sound Damper/Belly Pan came loose
Passat Loosing Revs
P1128 -- "Throttle Control Motor Lock Fault"
The 39 and 23 degree "Ding!"
Interepreting Leak Down Test Results
Replacing Air Filter -- You gotta be kidding.
Some springtime pics with new wheels...
Engine Surge to go with check engine light
Passat quarter mile time?
new owner questions
Good independent or dealer VW repair place in San Deigo??
weird foam thing in my spare tire compartment
W8 Brake Problem !
How hard to replace rear Passat rotors?
Brand new Body kit for Passat :)
40K service a major ripoff!
Our friend, Emissions Workshop
abs/brake light comes on ?????
Problem accelerating and strange sound
Help!My car is locked,doesn't start
Spark Plugs
passat battery problem
about my vw passat
Are VW's crap???
Passet Transmission swap
need to replace water pump, want to do it myself
automatic switches to manual
Windshield replacement
Passat: oil pressure gage malfunctioning
Passat: Heated seat problem
another question about Timing belt
VW Passat Alarm Signal
new vw passat owner, need help & advice!
Passat revving up when shifting
fuel system cleaners?
Mpg
Interior lights stay on?
Cannot get a full tank of gas
Oil Change that Went Wrong! MUST READ!!
high pitch sound
replacing fog lamps
Passat oil pressure light
Emissions workshop
monsoon radio/cass to radio/cass/cd harness adapter?
Passat doesn't like the coolant
Rear driver door won't open
Passat Rear Brakes
Power windows not working
Reiger Complete Body kit for Passat!
high performance exhaust system
Passat OBD code P1296 Help!
smoother running while idle
whining with cold start up
Close to 90-100k miles?
AGAIN! Check Engine & Emissions Workshop Warnings
Passat hesitating
Click & Clack Won't Help!
Loud Ticking Noise When Cold
Novice air filter question
Gas Question
Audio Wiring Diagram Wanted
Gas rating.
Accelerates Spontaniously
Help! - Passat Clutch Pops
TDI turbo query
Acceleration Hesitation?
Service Engine Light
How can you make a Passat faster? Can you?
steering wheel controls
Braking and Downshift Question.
Floor Mats?
Erradic idle when in Drive ...
Passat rear door unlocking problem ....
You Must Use Audi NGK Spark Plugs
reading codes with Creader code reader
Magazine Stuck In CD Changer
First oil change
Smell/Smoke inside?!
engine whine at 25k rpm
2nd Transmission in 3 years : advice?
Clicking when pressing brakes while in park
Wet Floors (locks won't work)
Pollen filter
ABS Speed Sensor Fitting
hazard flasher switch replacement
owners manual...
Random revs after changing the battery
Dashboard lights flicker on/off long periods both ways
won't idle
problem when I put gas into my tank
Passat..ABS light on = headlights quit !
Passat in the cold
Doors/ Ignition Freezing
Passat Wagon read windshield wiper fluid
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
