my running fault
jason261270
06-03-2004, 05:53 PM
boschman,regarding the maf sensor.sorry i forgot to say i changed my air flow sensor 3 months ago.i actually run a motor factors and we sell sheds loads of these sensors.your are also spot on regarding the parameter readings read on a code reader.when my air flow sensor failed it was still within the limits not to detect a fault.what i've found when these fail,the vehicle idles fine and runs smoothly,you've just lost a massive amount of power.going back to my fault,mechanics i,ve spoke to today have suggested either a diesel injector going down,or a possibility of some deposits from the bottom of my fuel tank entering the fuel filter.sorry i forgot to mention prior to my car stalling , i'd driven around 20-25 miles with the refuel light on.i did not think that could be the cause, but some say so.as always, and help is greatly appreciated.
boschmann
06-06-2004, 05:25 PM
As you may know we in the US don't get Passats w/TDI's, therefore I may be missing something that may differ from the US Diesels. I believe they are supplied in Canada. I will suggest going to this site as there are a couple of really good Diesel guys that moderate.
http://tech.bentleypublishers.com/forum.jspa?forumID=55
