Passat Coolant Leak
murraymac
05-14-2004, 03:43 PM
I have a W-reg 1.9TDI (115bhp - chipped to 130bhp). It has started losing coolant - fairly quickly. It only leaks when running - i.e. can be left for two days without dropping at all.
The garage have tried a couple of seals - but had no luck. There's no visible signs of leakage - possibly because it's hidden under a plastic cover somewhere.
Has anyone seen this problem before? Any advice would be very much appriciated!
Cheers,
Murray
boschmann
05-14-2004, 08:22 PM
I've had trouble spotting the leaks at the plastic flanges where the radiator & heater hoses join the cylinder head. They tend to get small cracks thay you can't see until you remove them.
hjdcool
05-14-2004, 08:27 PM
I have had the same problem and finally find it is the water pump broken
mindbeats
05-18-2004, 01:20 PM
dude, that sucks,
I had the same problem with my car and when i got it fixed they said it was the housing for the thermostat. It costs like $180 to get it fixed, but i havent had the problem since then. The price sucks to get it fixed but unless u wanna pay $10 every 2 weeks on coolant its not bad at alll.
ksm1213
10-28-2004, 11:08 AM
dude, that sucks,
Hi, pay also attention to possible heater matrix to be replaced. good luck.
