View Full Version : Maintenance
Pages : 1 [2] 3
  1. useful idle info
  2. graphics
  3. 83 cylinder not fireing
  4. Timing Belt
  5. whats this
  6. Knock Sensor
  7. 1987 Overhating problem
  8. 89 supra wont start
  9. Tail lights out
  10. Can't go pass 30mph!
  11. Replacing Speakers/Subs
  12. 89 Idle Problem
  13. new head gasket
  14. Rod Bearing Question
  15. boost leak?
  16. turbo tune?
  17. 1986 toyota Supra No electrical at all!!??
  18. 1987 supra
  19. Bad Head Gasket?
  20. 2jz-ge and turbo??
  21. new turbo
  22. Running/Parking lights dont work. HELP!
  23. 86.5 supra oil pan blues
  24. turbo check
  25. Clutch question
  26. jdm 7mgte swap
  27. general head gasket questions
  28. 2jzgte wiring diagrams
  29. clue to rough idling problem?? (pics)
  30. F&F supra specs
  31. 1984 Toyota Supra Value Lashadjuster
  32. Car will not start. No electrial power
  33. 7M-GE to 7M-GTE
  34. 85 Supra Rear End Clunk
  35. 85 Supra Ignition Timing Check Problem
  36. MKIII Idle problems; CPS?
  37. NEED HELP 94 Supra Kills on IDLE!!!
  38. Wanted turbo supra Project car manual transmission
  39. Wanted turbo supra Project car manual transmission
  40. speedometer cable question
  41. 1987 toyota shakes while driving. Help Please!
  42. HELP! OH, **iT Think its F**ked
  43. just wondering
  44. Problems???
  45. coolant in plug valleys after HG replacement
  46. HELP! Alarm in kill mode & can't bypass alarm or turn off.
  47. 1988 problems
  48. dash lights wont come on
  49. dimensions~need help!!!
  50. ? about exhaust measurments
  51. Help! Water Leaking into Boot/Trunk
  52. New Targa Top
  53. 89 NA Supra engine making bad sounds
  54. My 89 supra turbo has troble starting
  55. Tems
  56. engine problem
  57. intermittant hesitation/rough idle
  58. engine/air cond problem ???? HELP
  59. how do you swap a 7mge to a 7mgte
  60. 1988 Temp gauge short?
  61. Time for a rebuild
  62. fuse
  63. help oil present at turbo inlet??????????
  64. 91 Supra Turbo need serious help!
  65. 1986 Supra MkII Not Firing
  66. Can You Diagnose This?
  67. Rocker Cover Gaskets
  68. 89 Supra Turbo wont start- HELP
  69. 1990 Supra Sound System
  70. oil in spark plugs... is this normal?
  71. '86.5 supra making noise possibly CV joint?
  72. unknown pressure...
  73. replacement engine
  74. Exhaust Smoke
  75. turbo sound
  76. auto tranny fluid, how much to put?
  77. Ring & Pinion Gear change
  78. Front Main Seal + timing belt questions
  79. Turbo pressure
  80. New problem....
  81. mkI supra
  82. Be advised
  83. troubleshoot radiator cooling fans, electric
  84. replacing head gasket?
  85. Horrible Vibration
  86. A/C clutch doesn't engage
  87. Starter relay? 88 N/A
  88. intake cam lobe
  89. Parking brake pads???
  90. No spark
  91. can boosting too much blow powersteering?
  92. 89 Supra, auto tranny, no kickdown, no power mode
  93. Zero Tolerance?
  94. 1990 Turbo,perfect condition,replace HG?
  95. installing cam position sensor
  96. need help on my 86.5 supra ... please
  97. MK3 1986.5 Supra problems...
  98. E-brake adjustment
  99. wont start
  100. electrical problem...trying to locate junction box 1
  101. Open door to start car.
  102. Strange vibration
  103. 86.5 N/A driveshaft and spark plug problem
  104. Help with an 86.
  105. Missing Cylinders
  106. No Shifting~~!
  107. ?car dies while moving?
  108. car color 90 turbo
  109. Oil in the plug valley
  110. 86.5 Supra auto tranny shifts wrong
  111. Sign for BAD GAS!!!
  112. 90 Auto Trans PLEASE PLEASE HELP
  113. cam ?
  114. radio stopped working in my supra turbo
  115. 87 non-Turbo Starting Problem
  116. need instructions for installing a greddy turbo timer
  117. No Belts!!!
  118. Supra cuts out
  119. code 12?
  120. Need Fan
  121. is smoking bad?
  122. boddy trim
  123. mk4: auto to manual.
  124. Shaking/Shimmying 90 turbo NEED HELP PLZ
  125. High Mileage Supra MKIV
  126. More Problems!?
  127. Stripped head stud.
  128. Timing belt for 1983 Supra
  129. alarm wont shut off.
  130. supra gearbox problem
  131. engine running hot
  132. Alarm/Starting problems
  133. torque specs
  134. water leak
  135. Transmission
  136. wiring question
  137. possible blown head gasket
  138. Mk3 Headlights
  139. overheating
  140. ? about windshield washer wires
  141. Turbo guage not working properly
  142. ? about egr problem
  143. Turbo oil cooler
  144. 7m-ge Head gasket
  145. 1987 supra running hot
  146. I need front and suspension parts for Toyota Supra 1997year
  147. tems
  148. 7mgte swap
  149. Targa top bolts
  150. swap or rebuild????
  151. ecu issues
  152. Oil missing?
  153. need help w/ alarm and pwr windows
  154. cylinder head torque settings
  155. air mass flow sensor
  156. 90 turbo wont start
  157. mkIII won't start
  158. radiator light
  159. idle
  160. Iridium Spark Plugs..
  161. 7mge to 7mgte engine swap
  162. Buying advice
  163. Help with my supra
  164. mkIII 40 dollars turbo good
  165. mkIII 40 dollars turbo good
  166. car wont start after bhg repair?
  167. turbo exhaust manifold stay?
  168. Need Help ID Wheels
  169. need help finding harness connector?
  170. transmission
  171. Transmission additives(slipping under load), share your experiences, please help.
  172. in middle of bhg repair
  173. problem with clutch or tranny?Help plz
  174. power steering pump problems
  175. ? about bhg repair
  176. My 1986.5 NA wont fire Across any cylinders
  177. Speed ABS Sensor help
  178. Oil where there shouldnt be oil???
  179. dash lights come on?
  180. Airbag question ??
  181. Headbolts
  182. Clutch interlock switch needed for inspection
  183. Intake manifolds
  184. Oil leak question, please help
  185. 1999 corolla gas mileage drops
  186. head gasket may be starting?
  187. MKiii idle prob
  188. what is the light to the left of the water temperate gauge?
  189. 1jz idle problem
  190. PLeazzzzze i need help for my ?s
  191. Supra Idle
  192. Air Flow Meter???
  193. boost problems
  194. need help with cooling problem
  195. need help about broken stock blow off valve
  196. 7mgte
  197. Speedometer noise
  198. What is the name of this part?
  199. Big question on timing belt
  200. Air Bag Kit.
  201. Turbo and non turbo heads - what's the difference?
  202. Whats the normal oil pressure?
  203. Need to find 1jz performance parts
  204. ? about 5 speed transmission swap to an automatic
  205. Need help with 1jz-gte MAP sensor
  206. ? about swaping motor and transmission
  207. Fastest supra
  208. Engine mount torque specs?
  209. Replacing the Head Gasket
  210. thinking about getting a supra mk2.....
  211. Wiring Diagram
  212. Looking at new pulleys
  213. Exhaust header
  214. PCV Pipe
  215. 88 Auto Tranny help
  216. Please help
  217. Can some 1 please tell me fast in at least 2hrs!!!!!
  218. Crankshaft pulley
  219. how do u know if u have a blown head gasket?
  220. need help, loud knocking sound from engine
  221. Oil leak problem
  222. 84 supra fuel pump
  223. Missing Targa screw
  224. Replace Starter on 89 Turbo
  225. What is that wierd noise??????
  226. 89 turbo engine rebuild
  227. supraracer5689
  228. temp guage up..but not overheating?
  229. Help!!!
  230. Red 89 Supra NA needs parts
  231. need help 89 turbo, cracked piston!
  232. overheating...maybee
  233. Power Steering
  234. 1990 supra turbo
  235. Supra pluus to one side on acceleration
  236. german supra driver needs help with apexi
  237. Anyone fixed wind noise on mk3 supra??
  238. MKIII no-turbo head rebuild issues
  239. lost power
  240. Strutbar problem
  241. Supra Twin Turbo Drilled/slotted Rotors For Sale!
  242. CPS/distributor wire color diagram
  243. Engine Swap....car starts then turns right off
  244. How to remove oil pan? 81 Supra MK1, engine IN.
  245. fast idle at start 2001 toyota corolla
  246. help with gauges?
  247. 5M Tranny on a 7M GTE
  248. idling problems help me out!
  249. 1986.5 starting problems...??
  250. Rebuilding everything
