7mge to 7mgte engine swap
87-88 mk111
04-15-2004, 09:31 PM
Hey , im swapping engines i picked up an 88 supra turbo that someone nailed the back end of . Anyway i need to knw if the wiring harness i need I.E the turbo harness is the harness coming from the engine bay through the gromet on the left side and to the speedo head , also what is the bolt pattern and the offset for a 87 supra n/a thanks for looking, keep on truckin !!!
projectsupramk3
04-15-2004, 09:45 PM
Plug and play, bolt-in swap, it's very straight foward. You did the best thing by picking up the whole turbo car, this way you can swap the trans, DS, rear gear & LSD, gauge cluster, the works. Offset is going to be different for every wheel you buy, since some companies seem to measure them slightly different, but general conscensus says anywhere from +35 to +50 depending on size and a few of other variables. Stock sawblade offset is +35 with a 5 x 114.3 bolt pattern.
87-88 mk111
05-04-2004, 08:12 PM
Thanks so much , my motor is in now and im soo impressed the ct26 i had rebuilt and it is insane going from na too turbo , but i have a problem my oil pressure is a little low and oil is dripping i think ouit of the back of the valve covers is this a common problem in theses supras.The whole install was so straight forward all i had to do was change over the power steering hoses and bam it was in then plugs and connectors . thanks for your help . Keep on truckin
MK3
MK3
projectsupramk3
05-04-2004, 09:09 PM
Sweet, now lets see some mods on that thing soon. :) Oil pressure on the 7m is always low, that's just how it is, low pressure high volume. Did you change out the valve cover gaskets? If you did then did you torque them to 22ft/lbs? Change them out, clean the mating surfaces, and don't over torque them, that will solve your leaking problem.
87-88 mk111
05-05-2004, 10:09 PM
can anyone please tell me how to disable the factory alarm it goes off whenever it wants too , and at the worst times its soo embarising , yeah i just got a hks super sequential bov its sweet . thanks guys
projectsupramk3
05-06-2004, 04:37 PM
If your alarm is going off at "random" times then something is broken obviously, it's probably the push switch in the door jamb, could be user error. How are you unlocking it? Arm it by using the key in the door or pushing the lock button, disarm it by using the key in the door, it's that simple. If you want to disable it completely, pop the hood and unplug the push sensor by the latch. My door jamb button was broken along time ago, so I'd have to pull the chinese-firedrill to the passenger side door real quick to shut it off. The switch (the one with the plastic arm, not the rubber button) is the same on most toyota's so it's very easy to find an unbroken one, MKI MR2's, MKIII Supra's, Cressida's I believe also.
