new parts still no start
dugg365
02-25-2007, 03:21 PM
i'm sitll on the '93 cherokee sport. new plugs,wires,cap,rotor,battery,and the newly added starter relay. it will not turn over. temp. gauge swings all the way to the right when i turn the key? maybe shorted something out when i put the battery in? dunno! if you do let me know and save me a tow!
fredjacksonsan
02-25-2007, 05:45 PM
Have you checked to make sure that all the new parts you installed are installed properly, and that all connections are correct? Also check to make sure you have the battery + and - hooked up right, some batteries come with the terminals on the opposite side, depending on where you got them.
(I'm taking it that everything was normal before you made the changes?)
AlohaBra
02-25-2007, 09:07 PM
Are you sure the battery is connected properly.
Once again try new positve and negative battery cables.
dugg365
02-26-2007, 07:19 AM
did it
dugg365
02-26-2007, 07:20 AM
battery connected properly.
dugg365
02-26-2007, 07:22 AM
all fuses are good what about fuse links? and where do i find them unda' tha' hood?
AlohaBra
02-26-2007, 11:30 PM
Have you used the voltmeter yet to trace the voltage. Is there voltage at the starter? How many volts?
dugg365
02-27-2007, 06:36 AM
i'll try that today...starter is good had it bench tested already.
dugg365
02-27-2007, 06:21 PM
mucho gratis to alohabra ignition switch is bad.
AlohaBra
02-27-2007, 10:10 PM
Good work...
