Help with Radio Reprogramming!!
Honda94
04-06-2005, 07:44 AM
Hi, I recently had a new battery put in my 1994 Honda Civic EX and the radio 'forgot' its code and needs to be reprogrammed. I have the code but it wont work til the radio is reprogrammed, any ideas on how to do this?!
Thanx!!
Thanx!!
honda_luvr_2000
04-07-2005, 10:11 PM
Thanx!!
if it "forgot" its code, u'r screwed. take it to the dealer. but they'll prolly tell u the same thing. it's actually a anti-theft device. if u try punching in the wrong code too many times, it will lock itself for good. keep u'r fingers crossed. try unhooking it again for a day, and then hook it back up and try the right code again.
Thanx!!
BullShifter
04-08-2005, 01:30 AM
If the radio displays code error then you need to reset the radio by removing the "BACK UP" fuse located in the fuse box under the hood. Pull the fuse for 5 seconds and re-enter the correct code. If it still doesn't take the code, the radio was switched and it will need to be removed in order to gain the correct code from honda.
