Smoking Front Left Tire Area
triggert
02-18-2005, 06:50 PM
I noticed a little bit of vibration in my '95 Civic two days ago on the way to work, I didn't think much about it at the time. Then I noticed it again on the way home so I knew it wasn't the road it had to be a problem with my car. I also noticed the other day when I was turning into the drive way I can usually take it out of gear (its a 5-speed) and coast the rest of the way but it felt like the brakes were on. Then today on the way home the shaking started again, this time I was closer to home when I turned it I still felt some resistants coasting. When I got out the front left wheel area was smoking, making popping sounds (I'm assuming it was from the metal cooling back down), and it was hot. Besides that, I also noticed that the boot on the tie-rod end wasn't on properly. Anybody got any ideas what the problem could be?
Trigg
BullShifter
02-19-2005, 02:46 PM
when was the last time the brakes were serviced and inspected?
Brakes require routine maintenance which involves lubing the slide pins to prevent them from freezing up. if a slide is frozen then a brake pad could be making unwanted contact to the rotor.
here are some links from brake servicing:
http://www.binghamtonlife.com/manual/2gsm/images/91-19-6.jpg
http://importnut.net/brakes.htm
jameskersten
02-19-2005, 06:21 PM
sound like your caliper is stuck or seized, either way you better get it checked out.
