Our Community is 662,000 Strong. Join Us.
View Full Version : Legacy / Liberty / Baja
Pages : [1] 2 3
  1. 93 legacy wagon
  2. 2000 Subaru Legacy L transmission problems
  3. Head Gasket?
  4. Very Bad grinding noise, Video inside please help
  5. broken lower control arm
  6. Sticking rear break 1990 legacy
  7. park lights come on when brakes applied
  8. 2011 Legacy Headlights & Homelink
  9. Instrument Cluster stopped working...
  10. 95 sedan brake lockup
  11. can a dual din stereo fit in a 1996 Legacy?
  12. 1999 Legacy Troubles.
  13. AT Oil Temp Light Flashes: 97 Subaru Legacy LSi
  14. 90-94 2.2l with sudden valve clatter
  15. Possibly buying a 1991 legacy AWD
  16. Brake Shift Interlock
  17. re: seats for a 1996 Legacy Wagon
  18. Trans troubles - 5MT AWD
  19. 2010 - 2011 Legacy 2.5 with CVT. Opinions?
  20. 1999 Legacy B4 RSK twin turbo manual - clutch issues
  21. New to Subaru - R they good for a DIYer ?
  22. 98 Legacy "P0325 Knock Sensor 1.."
  23. Subaru Legacy Ignition Problems
  24. '94 Subaru Legacy-something draining battery
  25. 01 legacy 2.5l ; 5w20 vs 5w30; piston slap
  26. car won't start-just clicks-has new starter. any ideas?
  27. Legacy -06
  28. 2.2L compatibility
  29. Help '93 Legacy 5sp won't start after checking OBD1 Codes
  30. oil problem?
  31. 99 Legacy signal light problem
  32. Coolant/Over heating problem
  33. 97 2.2 fuel problem
  34. WTB: 99 Legacy 2.5L pulley
  35. 2003 Baja Parts
  36. 93 legacy front cv shaft lost roll pin
  37. 05 LGT Clean For Sale
  38. 99 Legacy WRX Brake Swap
  39. 2005 Legacy GT-What are your favorite tires?
  40. 2002 Subaru Legacy L 2.5
  41. overheating--91 legacy--non turbo
  42. 1991 Subaru Legacy 16 valve, car dies after startup
  43. 94 Legacy DLC/OBD ?
  44. Alternator
  45. Where to buy parts for older Subaru's, 1993 Legacy
  46. Legacy B4 trouble (not really)
  47. How to get A/C compressor to engage.
  48. Considering buying a 91 Legacy LS 4wd wagon
  49. speed sensor 2 97 legacy postal wagon
  50. !995 subaru legacy 2.2 starting
  51. Help Please!!!!!!!!!Overheating
  52. 03 Legacy valve tap
  53. 92 Legacy runs rough when warmed up.
  54. ABS MANUAL CODES 95 Legacy
  55. Trunk Latch, 93 Legacy
  56. speedo cable
  57. overheating help
  58. snow
  59. CV Boot
  60. 98 subaru
  61. 98 Legacy GT sending unit question
  62. oilll!!! fire? help!
  63. Once again Single turbo conversion help needed.
  64. Legacy GTB front mount intercooler
  65. 1992 Subaru Legacy Wagon
  66. 97 legacy - wiring keyless entry expertise needed
  67. Cabin Filter
  68. Subaru Wireing
  69. 90 legacy dies while driving
  70. 93 Legacy CKS and CMS troubleshooting
  71. 2005 Legacy GT Intake and Exhaust
  72. Tuner on a budget
  73. 91 Legacy L Fwd - transmission or electrical?
  74. 93 Legacy starting issue
  75. brake pedal pressure
  76. 1996 Legacy Power Antenna
  77. Problems with my legacy, need help please!
  78. 92 legacy wont start after big bump
  79. '91 legacy sluggish
  80. 99 Legacy brake issue?
  81. should i replace the rear driveshafts?
  82. 96 legacy stalling
  83. What size fuse do I use for FWD slot?
  84. 1996 legacy sedan
  85. 2000 GT Gas Milage/ Misc ?s
  86. timing belt idlers
  87. Legacy 95 Code P0420
  88. Intermittent Hard Shifting. HELP!!!
  89. Legacy Suspension Trouble shooting
  90. Subaru Legacy 95 Keyless Remote
  91. 1990 subaru legacy
  92. P0130 code problem for 1998 Legacy Outback
  93. Legacy GT Mid pipe
  94. Hesitation in to 1st Gear from engine-off stop.
  95. Converting a Twin turbo to Single...
  96. Removing factory stereo
  97. 1998 Legacy GT Wagon heater blender linkage
  98. keyless entry problem
  99. FS IL:2005 subaru legacy GT
  100. Help with converters
  101. 95 legacy at oil temp light
  102. 91 liberty awd wagon air suspension problems
  103. 92 Legacy Wagon
  104. Banging in turn ... 2001 Legacy GT
  105. Got a P0420 DTC code right after new Fuel Filter.
  106. Best Suspension components for legacy
  107. ABS light 1990 legacy
  108. Legacy Gt 1990 Problem
  109. Torque Convert Input Shaft retention spring
  110. 2006 Subaru Legacy Spec B limited #159/500! For sale
  111. defrost problem 1995 legacy
  112. leaky tranny
  113. leagacy parts interchange.
  114. Legacy 95 (Leaky Water Pump)
  115. p0105 map sensor
  116. 96 Legacy Wagon Oil Pump & Sensor ?'s
  117. 2006 Legacy odometer error???
  118. starnge sound coming from back of car 91' legacy
  119. 91' legacy sun roof opens only when it feels like
  120. rerweel drive legacy ????
  121. B4 RSK Engine conversion
  122. 2000 B4 RSK Legacy Help
  123. 95 Legacy, Power Steering Pump Leak
  124. 1995 Subaru Legacy L 4door 2.2 L Flat 4... Help!!!!!
  125. '92 Legacy spare tire placement
  126. Engine will only idle for 5-8 seconds..Help me!
  127. 04 legacy cruise out???
  128. getting a 97 legacy gt sedan
  129. Legacy 95 (Bad CV Joint boot)
  130. 91 legacy abs problem 160,000 miles
  131. Scan tools
  132. 91 lagacy wagon
  133. 91 Liberty powerless?
  134. Knock Sensor
  135. 99 Legacy: takes a few seconds to go into Drive
  136. 99 Legacy; slight front vibration when braking...
  137. Removing Torque converter from Drive Plate?
  138. Pine Cone in Exhaust :S
  139. 93 Legacy issues: Should I buy?
  140. 06 Legacy
  141. 2004 Subaru Legacy Outback 3.0L VDC...Would you buy?
  142. help! 93 subaru legacy wont start
  143. 92 Legacy turbo thumps when driving???
  144. 89 Legacy, Know any place to get Body parts
  145. 92 legacy ej22t problems
  146. air flow meter problems
  147. Help with codes P0171 and P0130
  148. Help!!! Thermostat install problem.
  149. 91 awd turbo sport sedan starting problem
  150. 97 passenger wheel vibration
  151. 1996 subaru legacy dash lights
  152. GM to Subaru
  153. 96 2.5 LSI Legacy wagon shield vibration?
  154. "91 Legacy Electrical Problems...
  155. 2003 subaru baja
  156. Legacy Transmission Trouble
  157. Do all 2003 Legacy 2.5 (auto/manual) have a rear LSD?
  158. 99 Legacy-vibrating, check engine light blinks, cyln. #4 misfire
  159. 98 Subaru Legacy GT - Wagon
  160. 98 Subaru Legacy GT
  161. Gas Tank for 1991 Legacy
  162. Can't Downshift to First.
  163. 95 Legacy Wagon Trouble code
  164. 95 Legacy Wagon Trouble code
  165. 1990 Legacy Heat Blowers Stopped
  166. 97 Legacy Wagon AUTo wagon CEL HELP
  167. 96 liberty(legacy) starting + stalling +
  168. 91 Legacy Sport Sedan Electrical Questions
  169. 98 Legacy L Wagon
  170. Thinking of buying a 2006 Baja. Thoughts?
  171. Subaru Legacy Vibration
  172. moniters not ready
  173. Subaru Transmission Problem
  174. 1994 Legacy Wagon Ping noise
  175. 95 Legacy Starting Problem
  176. can this legacy be repaired???
  177. 95 Legacy Starting Problem
  178. 1997 Legacy overheating
  179. '93 Subaru Legacy Wagon cold weather starting problem
  180. fan is not stopping after changing radiator
  181. GTB parallel turbo
  182. 94 subaru legacy code 51
  183. 96 legacy abs problems....
  184. 97 Legacy GT Sedan
  185. 02 Legacy hesitation - any ideas?
  186. 02 Legacy hesitation - any ideas?
  187. 95 Legacy L Wagon ABS Problem
  188. Shift handle position on a 92 legacy
  189. 2003 Legacy maintainance
  190. 1990 subaru cv joint replacement?
  191. Programming Key FOB on 06 Legacy
  192. 2000 Legacy stalls on startup in cold weather
  193. 92 Legacy Help
  194. 96 Legacy Wagon 138K miles
  195. few probs
  196. 91 axles replacement/any special steps?
  197. Brake pad installation problem 96 Legacy wagon
  198. 1992 Subaru Legacy engine knock when warm!
  199. 1990 Legacy service repair manual section 2?
  200. 91 Legacy OIL light
  201. 93 Legacy with 05 WRX Parts?
  202. 96 Legacy wagon - rear speaker install
  203. 92 Subaru, Starter is Good, But Flex Plate Spins freely. ???
  204. knock sensor
  205. dash lights
  206. Fog Light Relay
  207. obd II code #1507 ?? whats it mean?
  208. Legacy tuned by STI
  209. how much play in rear half shafts
  210. 96 legacy looses power, why?
  211. A\C and knock sensor
  212. at what milege should timing belt be changed
  213. MPG for 93 legacy
  214. legacy door lock
  215. air compressor 93 legacy
  216. Bought a 90 Leg L, several questions
  217. 1990 legacy gauges
  218. 95 legacy wagon 2.2 timing belt 92000 mls
  219. 1993 legacy parts
  220. Transmission Filter (external)
  221. where can i buy a fuel gauge from?
  222. 1998 Legacy outback COLOR
  223. any one help
  224. should I buy it?
  225. timing questions...needs to be set...
  226. Is it possible to keep a responsive acceleration at all time for your 05 Legacy GT?
  227. suspension?
  228. Tires?
  229. clunk in the rear
  230. For Sale 95 Legacy LSi
  231. Trans fluid
  232. Legacy/WRX transmission swap?
  233. 91 Legacy, Flashing power light after starting car
  234. Aftermarket Rims
  235. wheel hop?
  236. help! car is ticking when you turn only
  237. 92 legacy parts?
  238. lights, lights, lights
  239. 91 legacy
  240. Overfilled Trans
  241. 92 Idle problems
  242. The old check engine light ?
  243. 1990 Legacy LS needs your help PLEASE
  244. 1998 legacy changing fron seal ???Please Help
  245. Subaru Advice Please
  246. 93 Legacy L Engine wont start in the cold
  247. Quick Question
  248. 2 wheel drive
  249. AWD Solenoid problem
  250. Resetting keyless entry
