Automotive Forums Car Chat
Honda
> Wheels/Tires/Suspension
View Full Version :
Pages :
1
2
3
4
5
tire and rim ?
please help suspension on ef
Looking for coilover advice
5 lug conversion 96 accord??
camber kit
Snow Tire Recommendations?
Sway bars on a 95 LS integra
17" wheels
DULL gsr rims
civic lowering springs need suggestions
EG front swaybar ?s
Spring questions
18's on a 94 teg?
PLZ HELP *Suspension Problem*
anyone ever heard of this company?
rim weather protection...
Need advice for '00 Civic
Suspension for 1994 Civic
Please Identify these Rims
Lower COntrol Arm Problem
sqweeking suspension after oil change
Very lost!!!
Ahh! Freaking front end! Help
Just Lowered 2.5inch. Need HELP
Any 15" OEM wheels fit a 4th gen Civic?
4 lug hubs to a 5 lug pattern
Tein Height Adjustment-Need Some Help
96 civic eibach pro kit intall???
Beaks Products?
Rims and Tires for Auto X??
Lower Control Arm ???
what is the diamater of a 92 accord spring?
Are the Ingalls Camber kits worth the money?
94 up integra with si rims
Really bad noise
Tein suspension
18in Rims and Tires
Swaybar Questions
air ride suspension-worth the $$$?
Front end creaking under heavy braking in the rain
Are these the only 2 parts i need to lower my car?
5 spoke rims
springs and struts for my CRV
rims for 1992 civic sedan
lowering a civic
best suspension set up?
rear disc on civic cx
whats the best buy
TANABE Sustec Pro GF-Coilover ?
Almost there! 17s or 18s!
OmniPower or Tein?
suspension problems
wheel blanks
5 Lug Brake Setups
205/55 or 215/50 on 5.5" rim?
tie bars and strut bars
Honda OEm wheels
Shopping for 17's
stiff turns
suspension help?
anyone have air springs? need comments..
lowering my teg
Are Fuzion Tires The Real Deal??
creaking, clunking noise when turning, HELP!
Skunk2 Adjustable Pro Series Coilover
can someone identify these rims?!
91 civic camber upper arm vs. 92
15" street/track tires
Suspension
prelude si rotors vs vtec rotors
need help
How much is too much????
Swaybar ?s
Any Ideas?????
Motegi MR7?!?!
Front 12kg,Rear 8kg spring for 94 Accord Ex very bounce or not?~thank you~
cv joint stuck
question
can't take the lowered car anymore
Suspension issues.
Vibrations
Lowered Now Grinding?!?!?!?
15" 4 stud wheels
Camber Question??//??
bolt stuck on shock piston rod
Camber kit squeeking
ALbA rims
Car rear driver side lower than other side...
Wheel Bearing Help...??//??
H22 civic suspension help
Matching shocks for my springs..
motegi ff15
Spring Compressor?
15" tires
well thats never good...
Buying rims for the first time
Exel Wheels from Wheelmax
Motegi Rims
Need help on wich rims to buy!
Tein Springs
Lowering Car
Springs with Stock Height??
Man I got dooped!!!
Koni Sport (yellow) W/ Stock Springs ?!?!
Better Handling
Eibach springs instead of skunk2 coilover?
Rear LCA Bolt Sizes
Wheels for my Civic
really happy with H&R sport
Lowering Your Car W/out Getting New Springs
88-91 crx hf axles in 92 civic dx possible?
**When did coilovers come out?**
Need Suspension help
should i listen to them?
new Suspension to handle motor
91 teg b16a launching problems
best tires for 205/40 17"s? your input please?
Koni reds and skunk2's bottoming out!!!!!
ride height issues after swap
Riax?
old tires to new tires???? HELP
Wheel Opinion...
Wheels
8 point lugs
Which Ingall Camber Kit?
your INPUT regarding low tire..
help with air ride install
Q? about wheel w/ camber wear & Replacement center cap Q?
Possible Problem
AutoX suggestions?
Spring mounting rubber
Wheel WONT come off?
I found the web site to view custom wheels/tires/drops on your vehicle.
Lug Nuts
Spokey integra Rims price?
91 CRX Dropzone Coilovers. Wont Lower
98 Civic EX Driver Side tire is rubbing
sway bar conversions
Does it need struts?
Front Strut Replacement
Drop Zope Coilovers
Rack and pinion
Camber Kit
ahhhh koni reds or tokico illuminas
Wheel setup
how much TROUBLE am i in...loose lug nuts on rims..
regarding SUPER Pimp WhITE rims..2 quick questions...
Steering wheel wobble in my Integra
no power to pass wheel
SRR instructions on how to INSTALL!!! HELP!!!
CV Joint protection?
Perfect Springs and Shocks?
GSR rear Disc on my 96 civic, will the stock 13's fit?
quick FIRE question on tire pressure? anyone?
lower 98 civ ex H&R?
89 civic hatch rack n' pinion
Rear LCAs
coilover question
New Suspension
sway bar sizing???? HELP PLEASE
Sway Bars!!!!! civic - need some help!!!
Looking for these parts
questions on sespension??
Lowering my civ
Who knows there Koni shocks??
Lowering 94 DX
Bilestien 0r Tokico??
few problems with lower civic
Tein SS or Omni street.
Various suspension problems.
Holy Crap, I need help :)
Tokico Illumina worth the price?
Best shocks for 2002 accord in eibach pro-kit
'99 Civic DX: Drop or upgrade wheel size?
Denting Engine Compartment
Turbo car with no traction
Lowering my Civic HB.... what do I need?
5 zigen wheels
Anyone try the Koni RSK kit?
TOKICO ILLUMINA OR TOKICO HP??? cmon!!!
best springs/shocks for drag racing??
Tein or Omni?
is this a drop?
Rim and Tire Question HELP!
Tenzo R Coil Overs on a `91 Accord
TIRE SIZES who knows this??
Acura RSX rim problem
pic of busted rim
smooth ride
Springs and Shocks who knows this?? 2000 civic 4door
What color rims?
Rim Destroied
strut clocking
camber kit(which one)?
do you have these wheels?
Accord Suspension
wheel color
will 215/45/r17 fit a 98 civic?
Struts vs Coilovers.. Tein/HnR or Koni/Tokico WHATS BETTER
camber kit Question Please help!!!!
car pulls to the right
speed bumps
Will a sway bar help?
Suspension Settings?
GSR coils on a 96' Civic?
What Shocks/Struts should I match with Teins???
Noise from behind/center of rotor HELP!
bought a lowered car and need solution to tire wear
rear sway bar on 2000 ex
rubber or polyurethane bushings
Cuttin my springs!
Sway Bar
AN IDEA FOR THIS FORUM..read and let me know what u think
axels
good or bad idea?
rota subzreo rims
Spring clamp things.
Mismatched Tires Sizes
Suspension combinations
Need advice
TOKICO HP's
H brace or strut bar on CIVIC 00 HELP!!!
advice on lowering
Newb with suspension questions!!!
Question........Broke Plastic PIece That Came with rim
rear suspension HELP
Bent Rim
17s with 1.5 inch drop?
lancer wheels on a civic?
Rims Help Pleaseeeeeeeeee
suspension opinions
Honda Accord 205/50 17 help
are these good? what degree?
98 shaking between 55 and 63 mph
suspension lowering kit
Sway Bars That Clear My Apexi N1
4WS and suspension..
Help me im a suspension virgin!
Rear shocks/boosters for a 2004 Odyssey
3-4 fingers?
suspension problems? helP?
94-98 Integra Gsr Rims
buddy club
Springs Or Coilovers
Question regarding Tokico shocks for '95 Accord EX
KYB GR2 versus Tokico HP
Car jerking to left
Civic rim on GSR
Rim size change, '05 Civic VP 5spd
Wheels for a 97 hatch
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
