View Full Version : Dakota
Pages : 1 2 3 4 [5] 6 7
  1. Cylinder No.7 Misfire
  2. 2001 dakota engine/tranny replacement anyone???
  3. 97 dakota 5.2 starts, idles fine,but...
  4. Code 36 1992 Dakota stalls then restarts
  5. 3.9 computer
  6. Tranny Problem (?)
  7. what will i need to swap 3.9 for 5.2
  8. few questions
  9. 95 blower motor switch
  10. 2002 dakota code p0306
  11. Does fully synthetic plus a little Lucas oil stabilizer work well in the 3.9L?
  12. Looking at buting a 97 3.9L V6 with 300,000kms
  13. Help!!!
  14. mopar pcm
  15. Engine Light
  16. dakota windows
  17. 97 Dakota overheating
  18. coolant loss/no heat
  19. 2004 Dakota 4.7L
  20. replace heater core 93 dakota
  21. Busted output speed sensor
  22. nitrous on 02 4.7
  23. 98 Dakota Electrical Schematic
  24. 00 v6 3.9 will not start
  25. 92 Dakota Lift Kit
  26. Backwards fuel filter ?
  27. nitrous kit on 318 ('96 bodystyle)
  28. 95 4x4 won't shift
  29. electrical/brake problems
  30. 1999 Dakota No Start.. Baffling!
  31. dakota wont start
  32. Automatic light
  33. 2001 dakota headlights
  34. Fuel filter
  35. Interior ac/heater vents
  36. bushings in lower control arm(1998 4x4 v8)
  37. 318 install
  38. 2006 Dakota R/T
  39. Replacing Coolant
  40. 97 Dakota wont start
  41. repair to computer ECM
  42. 95 dakota 3.9 no spark
  43. Dropping out of overdrive ?
  44. 1993 Dakota Blower motor wiring
  45. I want More Power!!!
  46. New DAKOTA questions
  47. 01 Dakota Code Problems
  48. Tire Sizes
  49. dakota needs gas pedal
  50. headlights not working 93 dakota
  51. 95 dakota no spark
  52. strips
  53. Need help finding transmission
  54. 99 Dakota - stalling problems
  55. 2001 Dakota SLT Club Cab
  56. Starting problems
  57. Rear Main seal
  58. Its not xmas yet, but I have lights on!
  59. check this out
  60. mil icon
  61. 4CYL. boost
  62. air bag/heater fan
  63. RPM Surge
  64. BBK 1723 70mm TB
  65. HELP Can't remember how to change headlights 88 dakota
  66. "Updating" 3.9 V-6
  67. front suspension knock on 98 dakota 4x4
  68. 93 Dakota Woes
  69. 2002 Questions
  70. Not starting 97 Dakota Sport, 5.2l (318)
  71. '89 dakota bogging down
  72. 01 dakota headlights
  73. dakota brakes
  74. problem with brake lights
  75. Pull to the right.
  76. 400 horse 318 build
  77. can't figure out overheating
  78. Bypassing A/C pully. Will I still have heat?
  79. When to use overdrive in my Dakota Sport?
  80. AC problems
  81. 1989 Dakota Surges Code 55
  82. 01 Dakota 4x4 squeaks in 4wd
  83. 4.7L TB, Intake Manifold, and Cams
  84. parking brake
  85. dakota takes off w/o me
  86. When I hit the accelerator the truck barely moves
  87. Speedometer not working
  88. 92 Dakota windshield wipers come on and engine stalls
  89. 92 Dakota stalls and has trouble restarting
  90. Netural Safty switch location
  91. Performance exhaust
  92. 95 Dakota No Brake Lights
  93. 2000 Dakota SLT cold start...dies
  94. Performance air intake
  95. factory amp?
  96. Air-Vent selector not working right. (Vacumm Issue?) Help!
  97. Best exhaust for my Dakota
  98. 1995 dakota no spark at coil no fuel 3.9
  99. 97 3.9L Dakota keeps blowing relays?
  100. 1995 ABS & Brake light on
  101. Performance chip
  102. high idle
  103. AMI billet fuel door/nozzle snag?
  104. Lookin to purchase A Dakota
  105. 92 Dakota Maintenance light reset?
  106. CAD slow to engage, '89 4x4
  107. wanting to buy Uhaul type box to fit on dodge dakota
  108. 87 Dakota engine issue
  109. 90 dodge dakota failed emmissions.high nox
  110. '90 Dakota AT won't pull when engine's warm
  111. Neutral safety switch
  112. Tire noise?........
  113. '90 Dak Won't Start when Engine is Warm
  114. '89 High idle when warmed up........
  115. 1993 dakota ignition question
  116. 1992 dodge dakota 4x4 v6 5 speed ?'s
  117. 96 Dakota, small engine, need the 1st. part of the air intake.
  118. 96 Dakota, 2.2L Fuel Injected, no codes no spark, etc.
  119. 90 dodge 3.9 no power at coil
  120. Dakota 6cyl 4x4 battery drained but charged
  121. AC only blows out defrost vents
  122. 2001 Dakota Blower Motor
  123. 2003 Dogde dakoda sport p0456 fault code
  124. 20" rims and tires 4x4
  125. Dodge Dakota P0455
  126. 2001 Dakota 3.9 hesitation and missfire
  127. '98 Dakota Air Conditioning
  128. 95 dakota overdrive
  129. soft brakes
  130. 1997 dakota 2 wheel drive ????
  131. 91 Dakota no spark
  132. Running lights wont shut off
  133. '89 won't start when hot..............
  134. P0505
  135. blown engine
  136. transmission swap?
  137. 87 dakota vapour lock
  138. starter problems
  139. Torque converter/Throttle position sensor
  140. Camshaft position sensor on 00' Dakota
  141. 99' 5.2 v8 wants to overheat
  142. 2000 Dakota wont start.. filter problems?
  143. A/C Problems - '00 Sport
  144. Brake trouble
  145. Just in the morning
  146. Don't know where thermostat is located
  147. missing vacuum hose?
  148. 2002 R/t 5.9
  149. 3.9L Backfiring problem
  150. 1999 Dakota
  151. '89 now working great with "new" ECM but............
  152. Dakota V-6 improvements
  153. v8 swap for my 98 dakota
  154. rear seats
  155. 96-Dakota-Not Getting Spark
  156. 93 dakota radiator problems
  157. a\c compressor jump start
  158. 86 supra wiring diagram
  159. Temp Rising on 00 4.7 Dakota Help!
  160. 89 Starting Problems
  161. 91-96 dakota lift kits
  162. Which gear oil for 03 Dakota V6 4wd 5sp
  163. Dakota Questions
  164. Dakota mileage
  165. carbs
  166. Dakota ???
  167. Radiator ???
  168. 96 Dakota driver door replacement ?
  169. Any 05 Dakota Owners Having Luck Finding Mods?
  170. My New 3mos Old `05 Dakota CC.
  171. Carbon fiber cold air intake
  172. air bags to increase load/ride height?
  173. 93 Dakota intermitent restart problem
  174. need throttle cable for v8
  175. electrical 1999
  176. Hub Assembly Needed!!
  177. Knocking in Front Suspension/RPM Surge
  178. 97 Dakota Heater Core Replacement NEED HELP!!!
  179. Sratring problem bad relay
  180. Brake/Suspension Issues
  181. speed correction
  182. What Motor Oil Should I Use?
  183. Can i fit a 440 in my 1992 Dakota
  184. fuel injectors not working
  185. Power steering oil
  186. Timing chain?
  187. 93 Dakota Heater Fan
  188. Power Outlet Problem '00 3.9L SLT 2Dr
  189. Please .... location of voltage regulator.......
  190. I put in another computer.................
  191. Brake Lights not working
  192. Stalling 1995 Dakota
  193. 2001 dakota electrical problem
  194. Electrical Problem on Dakota 1994
  195. hot after 20 miles or so
  196. Dakota Inner axle shaft seal replacement
  197. 1994 Dodge dakota rebuild
  198. 2000 dakota SLT
  199. No Headlights/Dome light
  200. Motor mount kits?
  201. dakota box swap
  202. Want to sawp my NEW dakota v6.... info on compatible engines...
  203. 97 died now wont start
  204. 92 Dakota.signals Wont Blink-flasher Ok.
  205. just a quick motor question
  206. Squeak in front; Rubbing sound in back
  207. 96 dakota running problem
  208. 1989 V-6 Dakota Won't Start
  209. 04 Dakota Steering noise
  210. Gen 1 engine swaps
  211. Need 2005 Dakota Topper
  212. 2001 dodge dakota air conditon fan contol
  213. Tail gate handle assembly
  214. 1995 Dakota questions
  215. PO 442A Evap Cntr small leek dedected
  216. Help with fuel pump problem
  217. Computer bad?..............
  218. Dakota engine
  219. Reverse tranny skip Dakota SLT 5.9
  220. 97 Dakota dies when first started
  221. 99 dakota blinkers quit
  222. weird problem with warm start and wipers on a 90
  223. 1997 keyless entry troubles
  224. 04 Dakota overdrive problem
  225. raced a ram.....dead even
  226. Vibrations at higher speeds.
  227. Hemi, is it for real?
  228. Key less Entry
  229. inside door handle on 98 Dakota
  230. 94 dakota wheel swap
  231. lift kits
  232. 04 dakota quad/4.7v8 gas
  233. electric fan question on 4.7
  234. Radiator not pulling from reserve tank
  235. Dakota as a daily driver?
  236. My new 05 Dodge Dakota v8 4.8l Limited Edition Special
  237. 2000 Dakota Radiator drain plug location?
  238. What is the best Cat-Back Exhaust for an 01' Ext. Cab 4x4 4.7
  239. 93 Dakota problem
  240. where is the oil sending unit on my 3.9 ??
  241. Will headers hurt anything?
  242. More efficient fan clutch 01'Dakota 4.7
  243. Dodge Dakota '94 Cranks but won't Start
  244. 93 dodge
  245. Coolant leak
  246. oil pressure..or.. no oil pressure
  247. Where is the fuse for the dash Power Outlet? 01' Dakota
  248. Front axel seals
  249. 1992 Hazard Light Malfunction
  250. 1999 RT heater leak
