View Full Version : Dakota
Pages : 1 2 [3] 4 5 6 7
  1. tranny p1762
  2. same old
  3. weak motor
  4. 98 dakota starting issues
  5. 97 Dakota Power Steering problem?
  6. 1992 dakota not charging
  7. engine rattle after oil change
  8. 5.2 to 5.9
  9. Upper ball joints
  10. fuse block description
  11. 93 3.9 regulator
  12. 2.5L dakota idle problems Please Help
  13. 2000 Dakota Thermostat
  14. 2nd Gen Dakota air hat
  15. Changing Oil
  16. Ignition timing for '97 3.9L
  17. 2000 Dakota / Remote Start
  18. '90 dakota injector not firing
  19. 3.9 to a 5.2
  20. dakota with no spark
  21. front end popping noise, AC quits when accelerating
  22. Dakota Driveline Whine
  23. v6 govenor
  24. 93 V8 318, can't get power to anything
  25. how to check starter/engine ground
  26. Hard shift/Cooler Weather
  27. '04 Dak: Replacement of instrument cluster light bulb
  28. 1996 Dakota V8 4WD won't start
  29. Rear tire slant
  30. rear diff 2000 dakota
  31. Clutch adjustment on '04 4x4 4.7L
  32. 3.9 magnum parts
  33. 2003 4.7L 4 wheel drive Tranny problem
  34. Aftermarket Headlights for 94
  35. 2001 Dakota Problems
  36. Oxygen sensers on 1996 dakota
  37. 1999 Dodge Dakota
  38. WANTED 88 dakota
  39. intake manifolds
  40. 1998 dakota heater resistor pack location??
  41. Weird transmission behavior: Should I buy this truck?
  42. 2003 Dodge Dakota 4x4 4.7 liter engine
  43. '90 Dakota sputters after sitting
  44. Radio Out
  45. truck quits running
  46. 91` dakota V8 charging problems
  47. NO Brake Lights
  48. 2001 dakota truck
  49. 1987 dakota oil pressure
  50. Data logger
  51. Belt Diagram
  52. 1994 dodge dakota motor swap...help
  53. Adding horsepower
  54. tranny troubles
  55. dakoto motor swap (bad issues)
  56. 91 to 95 motor swap
  57. Dakota Losing Power
  58. 318 engine
  59. 91 Dakota no lights
  60. Dodge 2001 pickup truck coding
  61. Dodge 2001 pickup truck with need's a translation for this coding
  62. 89 dakota wont crank
  63. 4 or 5 quarts of oil?
  64. 4 Or 5 Quarts of Oil?
  65. Blinking 4 lo light
  66. 1989 Dakota dash,park light, fuel and speedo gauge
  67. wining noise slight when making right turn what is it tire noise or something more
  68. Anti spin differential
  69. Tonneau Cover
  70. Knocking issues 91 5.2
  71. 2001 Dodge Quadcab stuck in drive
  72. Tonneau Troubles
  73. Dealer recommended services
  74. 91 dakota, drivers rear abs valve?
  75. Custom exhaust system...throwing check engine light
  76. chattering brakes
  77. 1998 Dakota, override shutdown problem
  78. AC and other problems
  79. 1995 Dakota 4x4 318 no spark at coil
  80. 3.7L 2WD Quad Cab Gas Mileage
  81. HO 4.7L or NOT?
  82. 97 dakota water pump
  83. 2003 Dakota, P1604
  84. 99 dakota....
  85. 01 dakota trany prob?
  86. Overheating
  87. Overheating Problems
  88. what kind of transmission do i have????
  89. 1998 Dodge Dakota SLT thoughts?
  90. 1999 dakota r/t running bad
  91. 90 Dakota starting problem
  92. quest for firmer shifts
  93. 92 dakota fuses
  94. 2004 Crankshaft Sensor
  95. 91' 318 with fluctuationg idle and hesitation.
  96. Transmission Overdrive / Lockup Wiring
  97. Changed cams to HO and now P0016
  98. U-Joint trouble
  99. Need More ooomph
  100. 95 dakota 3.9 auto
  101. 92 dakota
  102. 3.9 V6 Backfire/power Loss
  103. 90 Dakota Headliner
  104. 92 wiper in low speed not working nor is off spot right
  105. 99 Dakota 2.5L light tapping noise from eng
  106. 91 Dakota Cowl panel removal
  107. 93 dakota "knocking" sound?
  108. problems starting a 93 v6 auto
  109. 03 Dakota with cat converter problems.....
  110. 93 4 cyl dies restarts cold
  111. Wipers don't work?
  112. teapot sound behind dash
  113. Mysterious CEL -- 2001 Quad Cab 4X4 4.7L
  114. 1993 dodge dakota 318 hesitation probms
  115. 1988 Dodge Dakota 2.2 timing information.
  116. 1995 Dakota Radiator Fan
  117. 91 dodge dokota..knockin sound
  118. 93 dakota 5.2L tranny shifts at high rpms
  119. 87 Dakota problems.
  120. Dakota R/T SPECS 0-60 1/4M????
  121. interchange 1995 dodge dakota
  122. Leaking water
  123. Dome light and light around key ignition
  124. A few questions about a friend's '97 3.9L Dakota
  125. 1997 extended cab - Towing - Opinions please
  126. Complete Stereo Revamp
  127. stumped! 92 3.9 stalling and backfiring
  128. Bucket Seats in 91
  129. 1991 dodge dakota wiring and fuel tank
  130. 360 into V6 dakota???
  131. Crankshaft bolt
  132. all this input is really great,
  133. removing the AC condenser bracket 99 dakota
  134. ign. sys. fuzlink blowing '93 dakota 3.9
  135. 02 spedometer spiked and locked
  136. Hey, new guy here, Dakota front end whine, 4 wd...?
  137. bypass hose leaking
  138. water leak near thermostate housing??
  139. 99 Dakota V6-V8 Engine Swap Project
  140. how do u get the rear seal out
  141. 2000 Dodge Dakota platinum plugs
  142. Thinking of buying a dodge dakota need advice
  143. help no spark
  144. 87 Dakota fuel guage
  145. 2001 dakota 4.7
  146. Falling apart on me...
  147. 2005 Dakota Quad Cab Advice Needed
  148. 1993 Dodge Dakota Gas Mileage
  149. 2002 dakota no spark
  150. '98 Dakota tranny problem
  151. Dakota 93 lights problem
  152. Dakota 93 lights problem
  153. Dakota 93 lights problem
  154. 1999 Dakota 318 5.2L AUTO "stalling" problem
  155. 88 dakota 4WD broken steering column
  156. 05 Dakota Stalls
  157. 89 Dakota vacuum diagram?
  158. engine noise
  159. 92 Dodge Dakota Backfiring problem
  160. 92 Dodge Dakota Backfiring problem
  161. 1997 Dodge Dakota SLT V6 Magnum 4x4 Automatic-NO OIL PRESSURE
  162. would this work?
  163. 2002 5.9L Dakota Cat-Backs
  164. '01 4.7 with water sludge in oil
  165. 2000 trans?
  166. No Spark 92 3.9 DAKOTA
  167. 94 dakota broken speedometer
  168. For Sale
  169. '89 Dakota heater blower quit working....
  170. Engine Clunking and Oil Pressure 99 dakota
  171. Truck gets hot ,water comes out......
  172. '01 Dakota 4wd Not Working!
  173. hand cranked window open and it broke
  174. 2000 dodge dakota help 4X4 help
  175. 98 dakota rear end noise - ring and pinion?
  176. Transmission swap I HAVE QUESTIONS HELP!
  177. 2002 Dakota remote starter
  178. 2004 Dakota - High pitched whistling in cab when cold
  179. Check guages light when taking turns
  180. 97 Dakota 3.9L transmission slipping
  181. Difficulty shifting to 3rd
  182. No shifting into OD
  183. Brush Guard for an 88` dakota
  184. 1994 Dakota Will not start
  185. 2000 dakota trans problem
  186. Electrical Gremlin
  187. 87 Gas tank sending unit ??????
  188. 94 dodge dakota coolant leak
  189. 91 3.9 Stalling problem
  190. 95 Dakota wont lock
  191. 91 5.2 will not start
  192. help truck wont start
  193. '92 V6 no fuel pressure
  194. updgrading bumper from 99.....
  195. 2000 Dakota 3.9 cold idle issues
  196. how low can i go?
  197. Need 99 / 2000 4.7 Engine
  198. front grille replaced
  199. strange problem with 02' dakota
  200. Radiator fan staying on
  201. seats
  202. 2001 Evap
  203. Intermittent whistling sound
  204. tranny troubles
  205. 1990 Dakota No start...
  206. Odd noise from front end/engine...
  207. question about tail pipe
  208. 45RFE interchangeability
  209. Whinning Noise
  210. 00 Dakota have to hold gas pedal to floor to start.
  211. Setting timing dakota 3.9 1992
  212. 1992 Doge Dakota Gauges
  213. snapped bolt
  214. Radiator V6 & 4cyl the same?
  215. v6 to v8 engine swap?
  216. 90 Dakota driver seat belt
  217. Possible tampons in the gas tank.
  218. tools needed
  219. 1996 dakota asd fuse keeps blowing
  220. Air Pump Question
  221. Dodge PCM replacement
  222. crankshaft oil seal leak
  223. rear wheel shudder
  224. Speaker size for Dakota??
  225. fuel pump
  226. no spark when its cold
  227. 2000 Dakota power plug (in dash)
  228. 1989 Dakota Ignition Switch Problems
  229. 93 dodge dakota makes clunking noise when in reverse
  230. Just bought a 95 Dodge Dakota.. Check it out
  231. K&N intake for 93 v6
  232. intermitant miss/elect. or fuel?
  233. Rear end or tranny
  234. 93 dakoda elec. problems
  235. 98 Dodge Dakota
  236. 2005 window crank
  237. Oil pump
  238. 93 Dodge Dakota Steering
  239. I Need A Little More Clearance
  240. Bad PCM?
  241. transmission swap,will it work?
  242. New Ride!!!
  243. 93 dakota radio/cd wiring...
  244. 98 Dakota Oil Pressure
  245. Please Reply!
  246. Please Reply!
  247. 99 dakota cv axel replacement
  248. 01 dodge dakota,cruise control diagnose
  249. 02 Dakota Quab Cab 4X4 - 4X4 problem!
  250. 02 Dakota Quad Cab 4x4 - brake noise!
