View Full Version : Dakota
Pages : 1 2 3 4 5 6 [7]
  1. 93 5.2L OEM fuel lines or plastic connector to fuel rail
  2. 91 dakota fule pump relay
  3. 93 Dodge Dakota Electrical Short
  4. 93 Dodge Dakota 3.9 A/C problems
  5. Decisions, decisions!!!
  6. AC Bypass
  7. 92 Dakota won't start
  8. fuel gauge in a 93 dakota 4x4
  9. Neons almost done
  10. Topper for sale!!
  11. 92 Aerostar trans/ no reverse
  12. Hydrostatic drive
  13. 96 dakota for sale
  14. 89 Dakota quits running
  15. heater blower motor
  16. '95 dakota noise
  17. lift kits?????
  18. factory radio wiring dia. '99 dakota
  19. Need a new engine for Dodge Dakota 99
  20. Swaping 5.2 for newer 3.9 Mag or other in 91 Dakota
  21. What is correct tire size on 92 Dakota ?
  22. Actuator for sale
  23. Electrical Short
  24. Not starting
  25. WTB/ straight undented BED for my 92' Dakota
  26. Transmission problem
  27. lift kits
  28. tonneau cover
  29. A/c expansion valve
  30. lifting my dakota
  31. dakota timing chain noise
  32. 1994 5.2
  33. Flickering Headlights
  34. programing keyless entry to my 03 dakota
  35. Radio Help
  36. 4x4 4hi doesnt work and 4low grinds in?...
  37. 99 Dakota tranny slips from2nd to 3rd
  38. 3.9 Mag Distributor drive bushing
  39. 92 dakota code 42 auto shutdown circuit
  40. No Fire
  41. 93 dakota problem
  42. fuel tank
  43. Gas Mileage
  44. Trouble code
  45. Questions about the 98 Dakota
  46. No power to truck at all!!! Please help
  47. Weird shifting i need help
  48. Dakota V8 Governor
  49. Engine Needed
  50. Update On 98 Dakota.......
  51. vigorous boiling - water lost thro overflow
  52. Gas Tank Size in 99 Dakota R/T?
  53. 2001 Quad-Cab Power Lock Problems
  54. 98 dakota.....
  55. 89 Dakota
  56. 89 High Idle Problems
  57. Caliper Bolt Star or Torx What size?
  58. Strange Alarm-like sound when stereo power is on
  59. ABS & Brake lights are on
  60. Wanting to upgrade to stock 4x4 Suspension
  61. Flowmaster or Gibson
  62. 91 sometimes starting...HELP
  63. 00 should i buy?
  64. 91 dakota pick up
  65. Ignition Recommendations???
  66. power but wont start
  67. 1996 Dakota troubles
  68. ticking sound
  69. 1999 Fog Lights
  70. 4 Cylinder Dakota?
  71. i need stereo help
  72. Thinking of buying one, opinions?
  73. My Fog lights are staying on
  74. Tires
  75. back pressure
  76. 2.5L Upgrades?
  77. Dakota Fuel Problem
  78. Dodge dakota CRUISE
  79. 2001 Dakota remote receiver
  80. 2001 V6 Dakota not starting
  81. Dakota Engine Revs unexpectedly
  82. Coolant Smell
  83. where to buy cheap parts???
  84. need advice and or help!
  85. 1988 V6 idle problem
  86. dodge dakota
  87. 95 dakota no power help please
  88. Overflow Tank Leaking
  89. 93 dakots just wont start
  90. What do you think? I want your opinion...
  91. sticking throttle/ high rpm
  92. door locks/ auto. windows
  93. transmission slip/ odometer clicking
  94. 98 dakota 3.9 liter rocker arms
  95. no oil pressure on 2002 dakota
  96. Removing a water pump an a 94 318
  97. FYI about my old 90 DAKOTA
  98. speed and abs sensors
  99. Heater control.
  100. abs sensor
  101. 2000 dakota, how to adjust bands in transmittion?
  102. 1993 Dakota Cowl
  103. Oil Pump Replacement 99 Dakota
  104. headers for my 93
  105. '93 Dakota - Lo oil press @ idle
  106. 1993 Dakota Questions
  107. fs 97 dakota r/t clone
  108. Crankshaft position sensor???
  109. 1992 cruise control repair
  110. Programing Remote Keyless Entry 97 Dakota
  111. OIL SLUDGE in MOST DODGES
  112. Help w/ Auto Door Locks!!!
  113. 5-speed Conversion
  114. 97 Dakota with funny noise
  115. Need help fixin' a 95 dodge
  116. MTX Custom Speaker Enclosure for Dakota?
  117. Removing oil pan to change oil pump??????
  118. Door handles not functioning
  119. v8 swap????????
  120. how do i take a tank off to change fuel tank
  121. 2000 dakota quad 4x4 replacing fuel pump
  122. mark III parts
  123. Engine Ideas
  124. heater core removal on 95 dakota
  125. no spark at coil
  126. dakota odometer
  127. Bug Sheild 4 Sale
  128. factory alum.wheel center cap.
  129. 1990 2.5 Dakota will not start
  130. 2000 Dakota fan blade question
  131. Performance Suggestions
  132. Where can I find
  133. Seat Belt stuck in Latch
  134. 2000 Dodge Dakota
  135. Banks Sidewinder
  136. 93 Dakota 3.9 running prob
  137. Northeast Dakota Sites?
  138. Rebuilt or slightly used transmission.
  139. ac/heater blower fan regulator?
  140. Removing the starter
  141. Viper Seats For Sale! (look if you're willing to spend $$$$)
  142. 98 Dakota cooling system
  143. Next-Gen 4.7 or 3.7/3.9?
  144. 94 Dakota wierd vibe
  145. traction issues with r/t
  146. good deal or bad r/t
  147. Wiring Troubles
  148. Looking for bad points
  149. Difference between 03 and 04
  150. Looking for a set of Dakota Sport Wheels
  151. dakota ?probs?
  152. is this a good deal?
  153. Anti-lock breaks
  154. Stock 360 V8 intake manifold for sale
  155. '91 5.2 stumbles
  156. routing diagram for drive belt
  157. 1993 Dodge Dakota Trouble
  158. Just bought me a 2002 Club Cab
  159. Motor Madness 10/18/03
  160. 02 5.9L R/T AutoTrans trouble
  161. Carseat in extended cab?
  162. just bought a R/T can i get some opinion from longer owners
  163. 4.7L...Are the 2000-2003's all the same??
  164. 1988 Dakota differential parts
  165. Stalling
  166. stupid question. Where is my fuel pump?
  167. 1999 Dakota 4x4 crew cab V8
  168. Battery or Alternator?
  169. 1988 Dakota rear end
  170. Dakota decals
  171. 92-96 engine swap
  172. 3.9L V6 - Cracked Heads
  173. Cracked Cylinder Heads
  174. 2002 Dakota 5.9L dyno Plots
  175. Dash Panels
  176. Used Dakota
  177. intakes, exhaust, and lifts
  178. Straight Pipes
  179. 01 dodge dakota problem
  180. supercharger / ignition / boost retard etc.
  181. high idle after spark plug/cable/distributor cap change
  182. billet grill
  183. Rough Idle
  184. need advice
  185. turbo r/t
  186. 1989 Dakota Sport convertible for sale
  187. Gas Mileage
  188. Spark Plug Failures?
  189. shaking around 40kmh??? 89 Dakota Sport 4wd
  190. Need some mods advice
  191. Buying a 97 Dakota 4x4 xtended cab
  192. No Power!!!!!???
  193. Just bought a new 2002 Quadcab
  194. 99 Dakota Sport Rattle
  195. 2001 Keyless Entry
  196. transmission problems?
  197. Gas tank leaking
  198. for sale
  199. Any good sites?
  200. Code 34
  201. '95 dakota v-6 3.9
  202. engine miss
  203. corrosion keeps Dakota from starting
  204. 4.7L Headers
  205. Dodge Dakota- Need to bulid a hood extension latch due to new installed grills
  206. question about convertor
  207. Dakota Wreck Pictures!
  208. 3.9 and 5.2 reliablity? and other q's
  209. Need a seat for a 93 Dakota
  210. 3.9L headers
  211. 92 V6 Dakota Maintenance Headaches
  212. 1993 Dodge Dakota Problems
  213. Sub-Enclosure
  214. Dodge Dakota Quad Cab offers the best of both worlds
  215. Blue Lights
  216. 1999
  217. 1999 Dodge Dakota R/t V8 Sport
  218. nice custom Durango/Dakota 97 and up rims/tires
  219. New style
