94 Ford Exlorer Electrical
deadman1474
11-18-2007, 07:10 PM
I have a 94 ford explorer and I was coming home and it just rained and I had just turned off the wiper blades and I smelt electrical smoke and saw a puff of smoke for about 5 seconds and then I't was gone. Then later on I relised the aftermath that my door and sunroof windows do not work. The speed gauge is out the four wheel drive indercator light is out. Four wheel will not engage. The interior lights do not work. The windsheld wiper does not work. I checked on the windowsheld wiper washer pump to see if it was missing the ground or the positive and I seems to be the positive. If anyone has any ideas of what I can try then let me know or if you have any wiring diagrams it would be apricated. Thanks
shorod
11-21-2007, 07:03 AM
Did you check the fuses to see which one blew? It seems like if you had smoke, then so many devices stopped working, you should have a blown fuse. Once you determine which fuse is blown, wiring diagrams will help you follow the circuit and determine which wire got too pinched or chaffed and shorted to ground.
-Rod
-Rod
