99 xlt front washer relay
corndrunk
11-25-2007, 08:53 PM
Ive found the auxillary relay box but don't have any info on which relays are which of the 6 in there. Anyone know which one controls the front washer? Any help is greatly appreciated!!
Aaron
Aaron
shorod
11-26-2007, 01:16 PM
Do you have the owner's manual? If so, it's probably in there. I'm surprised it's not molded or stuck to the underside of the relay center cover.
If you don't have a copy of the owner's manual, you can view/download a PDF copy from Fleet Ford (https://www.fleet.ford.com/maintenance/owners_manuals/default.asp).
-Rod
-Rod
corndrunk
11-26-2007, 06:19 PM
I have the original owners manual but it only has the fuse layout from inside the cab and the the fuse/relay layout from the power distribution box on the left side of the engine compartment. They don't list the relays in the auxilary box located on the right side of the engine compartment.
Aaron
Aaron
shorod
11-26-2007, 07:38 PM
I guess you can resort to checking for the relay that has ground on terminal 2 when the washer button is pushed. Or, pull one relay at a time and see which one seems to have no effect. The other relays control the high speed blower, fog lights (looks like 2 relays for fog lights), rear washer, and air suspension if equipped.
-Rod
-Rod
