AIR DRIED BEEF DOG FOOD
Lift Kits 2WD?
S-10Rookie
07-18-2005, 02:28 AM
Is there anybody out there making a decent lift kit (body or suspention) for a 98-04 2WD. I already have a lowered truck i want to see what these lifted rigs are all about
Thx
PS I couldnt find a 4WD that hadnt been beat to crap. thats why i'm stuck with the 2WD
whitetrash982
07-19-2005, 12:30 AM
2wd s-10 aer easy , 3" lift spindles and 3" lift springs , so0metimes new upper controls arms are needed if you cant get the alightment straight , and for the back you need just do an axle flip , all s-10 are spring under from the factory , and if you want its an even 6\6 lift , put in some lifted shackles - done.
and yes , i understand about the 4x4 s-10 , specially new ones , i spent over 2 months looking for mine , theres just not that many out there
and yeah , body lifts are never good , and many will agree with that , i would never use then simply because they screw with all you linakges that mount to the frame from the body , and if its manual , itll lower your shifter that many inches as well - my oponion - never do a body lift
brightdim03
07-30-2005, 06:10 PM
just a info note... the ZR2 suspension system will go on a 2wd quite easy and they arent hard to find in good shape at a junkyard or used parts site, all the mounts are the same the only problem are the wheel wells and you might have to replace your front sway bars, but if you put a lift on larger tires and sway bars are usualy in order anyways
S-10Rookie
08-01-2005, 08:14 PM
Well I did the math........this motor isnt going to turn the 31's i want to stick under this truck =(...........I'm just gonna wait until I've dumped the 2.2 and fitted the 4.3. Its just not worth it with all these hills I drive thru daily......
thanx anyway
