View Full Version : Lumina
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. 97 Lumina Starting Problem - Please help!
  2. '96 Lumina Van Won't Idle
  3. No interior electrical
  4. transmission shift problem
  5. 91 3.1 Lumina Starting Problems
  6. 1990 Lumina won't start when hot
  7. Just a quick question.
  8. need a little help with locating tdc
  9. Metal coolant bypass hose
  10. brakes?.. maybe
  11. '92 Z-34 was not enough....
  12. the jerking is back
  13. 91 Lumina 3.4 Injectors Pumping too much gas in chambers
  14. 94 lumina wont shift to 3rd
  15. 93 lumina cranks/no start-computer throwing weird codes
  16. 96 3.1 automatic transmission issues
  17. Need location of
  18. 95 Lumina 3100 Winding Noise Aud/Vid posted Please Help!!!
  19. 91 Lumina ~ Quit Running
  20. Brake light and ABS light stay "ON"
  21. Motor Mounts
  22. 1999 Lumina 3.1 Oil in the coolant system
  23. 97 Lumina flickring lights
  24. driver window
  25. Tranny
  26. 97 Lumina flickring lights
  27. 91 Lumina 3.4 No Go AGain Ugh
  28. wheel noise
  29. 97 Lumina Power steering and flickring lights
  30. Crank Position Sensor - '93 3.1 Euro
  31. 97 Lumina Radio Locked
  32. 95 lumina no hot restart
  33. tired
  34. Turn signal problem
  35. coolant reservoir
  36. Surging
  37. ABS and Brake light
  38. 1993 Lumina wont run right!!
  39. changing tranny oil
  40. 3.4L D.O.H.C Camshaft Carrier Removal with lifters
  41. FIRE in the rim!
  42. Cranking two or three times when warm....
  43. Testing Crank Shaft Sensor on a 1991 Z34 Help Please
  44. Removing A/C compressor on 1993 Z34
  45. 3.8 L in 92 Lumina
  46. 91 Lumina 3.4 Engine Oil Pan Crank Sensor Removal
  47. cooling problem
  48. Lumina 1997 Crank no start
  49. 1994 Chevy Lumina brake lights
  50. I need help PLEASE
  51. 2004 Lumina Headers
  52. Timing Cover Gasket 1997 Lumina
  53. 97 chevy lumina belt problem
  54. Brake Light Warning On - 99 Lumina - HELP!
  55. '97 Lumina strange lack of power---HELP?
  56. 95 lumina transmission od issues I think
  57. Replacement Engine for the Z34
  58. 93 euro tilt steering broken
  59. 94 euro idles high bucks at high speed
  60. 93 euro low coolant light
  61. 93 euro turn signal failure
  62. 1998 Camshaft Positioning Sensor
  63. 91 Lumina z34 Where is Crank Shaft Sensor
  64. 90 lumina stereo wiring diagram
  65. Intake gasket and valve settings
  66. help 98 lumina
  67. parking brake
  68. 91 Lumina 3.4 engine Engine Shut Down at Intersection
  69. 97 lumina - starting problem
  70. Rear caliper
  71. lumina runs great except at idle
  72. 93 lumina
  73. 96 Lumina Hesitation
  74. help with coolant temp sensor
  75. emission questions
  76. 92 lumina
  77. Volts Light AND Power Steering Failure?
  78. Break lights
  79. Power window
  80. AC Blower inop
  81. 1990 lumina, doesn't start/goes out, lights flickering, relay clicking
  82. Fusible links?
  83. Head Removal 3.4L D.O.H.C
  84. Head Gasket
  85. No pressure to rear right brake
  86. no tail lights
  87. Shifting and AC..
  88. replacing heater core
  89. help!! with lumina
  90. Lifter replacement In 96 3.1
  91. 98 lumina power seat
  92. Lumina Electrical Issues
  93. Lumina Hesitates
  94. another brake question
  95. Homelink Mods
  96. '92, Lumina, 3.1L, PCV Location?
  97. Lumina Transmission Swap with GM
  98. Lumina computer problems???
  99. Bleeding Air From Coolant System
  100. Rich, BB, Max, etc, I need serious help
  101. lousy lumi' brakes!
  102. 1991 Lumina died
  103. Headlight Installation
  104. 97 Lumina- check eng light & gas tank
  105. 93 Lumina 3.1L - Hesitation. Injecters? Solution?
  106. 1990 Lumina Acceleration Problems, help!
  107. 90 Lumina..crank no start
  108. 96 lumina evaporator
  109. Evaporative emission control malfuction
  110. 1998 lumina thermostat location???
  111. I need Help Like NOW!!!!
  112. 97 Lumina Intermittant Starting Problems
  113. governor on my 91
  114. Replacing brake lights
  115. 1991 Lumina Speedometer and Low Coolant Light
  116. 94 Lumina, A/C Turned on/blew Pwr dr/wndws
  117. 95 3.4L Lumina Cranks, No Start
  118. 2007 Lumina SS
  119. New heads, still runs hot
  120. 97 3.1 Power Steering Pulley
  121. 97 Lumina shift solenoid
  122. 97 Lumina Speedo
  123. 92 Lumina 3.1L starts and drives but sputters/dies intermittently
  124. 1990 Lumina Problems..
  125. 1993 Lumina Driveablilty problems
  126. 98 Chevy Lumina, Low coolant temp
  127. 1999 Lumina LTZ Stalling at will
  128. 1991 No start
  129. 1995 Lumina ABS issue
  130. 93 Lumina won't accelerate
  131. Wheel size question
  132. 91 lumina that thought had a vaccum leak
  133. Need help with a 93 lumina that will crank but won't start
  134. Help on a 2.5L GM engine, please look for just one second :)
  135. Fuel gage not working
  136. 98 Exhaust
  137. size of gas tank? 98 lumina ltz?
  138. Transmission Broken?
  139. 92 Lumina speedometer quits and car stalls
  140. 1991 Euro
  141. part numbers please + surging vehicles
  142. 92 lumina starts then stalls
  143. 95 lumina transmission fluid lines
  144. Mistake on my 1999 LTZ?
  145. 1990 lumina 2.5L 4 cyl wont restart
  146. 96 lumina a/c
  147. 1990 Lumina concerns
  148. more power for my 91
  149. Fuel pump
  150. low gas milage 98 ltz
  151. 3800 series II? whats so special about them?
  152. overheating problems again!!
  153. Strut mount or strut?
  154. Question? 3.4L D.O.H.C
  155. 3.1L Code 171/300 - Loss of power
  156. 95 Lumina problems
  157. Hub assembly Torque
  158. 91 lumina problem?
  159. 91 Lumina 3.1 Tranny Or Stuck Brakes
  160. 1992 Lumina
  161. Please Help. 91 Lumina 3.1 Water Pump replacement
  162. 90 Lumina, please help
  163. 90 Lumina no dash lights.
  164. 1995 lumina wont run after rolling car
  165. 1002 Chevy Lumina Stalls..Help!!!
  166. 93 lumina Z34 3.4 runs tell it is warm and dies
  167. Racing seats
  168. security light on 2001 lumina???
  169. rocker arms
  170. chvyman1?????????
  171. coolant sensor
  172. measurement for lumina?
  173. driver door lock gets stuck
  174. 98 3.1 =16 mpg city-
  175. electric locks and dome light
  176. ReUpholster, Lower trim on door panels.
  177. 98 Lumina LTZ
  178. 1991 Lumina 3.1 No spark...
  179. 1990 Lumina jerks when accelerating
  180. CARFAX Anyone???????
  181. 98 brake problem(non abs)=
  182. Brake job not going smoothly...
  183. Need window help!!!
  184. Mishap with the 1999 LTZ
  185. ABS - 1992 Lumina - Please Help!
  186. Just got a 92' Lumiona Euro 3.1
  187. Proper valve adjustment procedure
  188. Wheel Bearing
  189. Grand Am misfires only in park and neutral
  190. Custom Brakes needed For 93
  191. 98 chevy lumina
  192. Hesitation When Accerlated
  193. Fuel Problem
  194. Help, Me Throw Some Seats on this...
  195. 1993 Z-34,3.4,no Timing Marks!
  196. 93 lumina will not start due to no spark
  197. A/C leak
  198. Stalling and Starting issues.
  199. Replace condensor.. How too?
  200. '98 3.8L With Coolant Leak
  201. Nee Help with Engine
  202. p1870 code
  203. Major Gas Mileage Improvement
  204. Wheel Stud replacement
  205. Internal Engine Parts
  206. Need Help!! 99 Lumina LTZ problems.
  207. Internal engine
  208. Lumina:Window Not Working!
  209. 1990 Chevy Lumina Stalled & Won't Start.
  210. 99 Lumina Break Issues
  211. Lumina door lock dont work...
  212. 1991 lumina 3.1 will crank but no start
  213. Lumina 97 - ABS and BRAKE lights
  214. 93 lumina electrical ??
  215. steering wheel controls
  216. please help! major electrical problem with my van
  217. wierd science question=
  218. 1996 Chev Lumina lost key.....
  219. 1993 Lumina Fuel Problems??
  220. 1998 Lumina Wiring Question
  221. PCV system / purge solenoid
  222. 1994 Lumina Problem - Possibly Fuel Related
  223. 90 Lumina 3.1 no accel
  224. More Help needed PLEASE...95 Lumina still wont run
  225. Engine crossmatch for a 95 Lumina with a 3.1
  226. din size?
  227. Speedo calibration??
  228. Lower Intake Manifold Off. Now What
  229. BAD brakes
  230. '92 front coil replacement Lumina Z-34
  231. Drivers window stuck?
  232. 94 Lumina idle lowers & sometimes stalls at stop signs etc
  233. lighting woos
  234. '98 Lumina LTZ 3.8 - Serp belt
  235. painting question
  236. new to forums having problems with 95
  237. 1996 Lumina is getting Harder to Start
  238. upgrading alternator
  239. Child Proof Windows. Disableing?
  240. LTZ Interior Light Problems
  241. 95 lumina engine temp problem??
  242. Probs with 90 Lumina
  243. big puddle = big problem
  244. 97 Lumina throwing codes...
  245. Car wont start, Gas in Oil...PLEASE HELP???
  246. 98 Lumina with turn signal problems
  247. HVAC - burnt out lights
  248. 1988-1995 Lumina repair manuals
  249. crank position sensor
  250. 95 Lumina Overheating
