Break lights
missy 44
06-27-2007, 03:20 PM
My break lights won't go out i change the break light switch (what a pain that was) and it is still doing the same thing what can i do to fix itrunaround
Oh i am sorry i have a 1992 lumina.
jeffcoslacker
06-28-2007, 03:37 PM
If they won't go out, there is a short in the circuit or something is interfering with pedal return...
So the pedal contacts the switch and pushes it fully as it comes up? Do the lights go out when you disconnect the switch?
missy 44
06-28-2007, 06:22 PM
Yes they go out when i disconnect the switch
jeffcoslacker
06-29-2007, 06:00 AM
Then operating the switch must turn them off as well....so either the switch is not adjusted right, and is not being pushed enough to turn them off, or the pedal isn't coming all the way up, check for interference, weak return spring, etc.
I guess they are on whether the car is running or not? (rarely you'll see one that has a brake booster problem and the lights stay on when the engine is running)
Will the lights go out if you lift up under the pedal is the next question.
