Automotive Forums Car Chat
Chevrolet
> Lumina
View Full Version :
Lumina
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
Coolant???? Going where????
Pulley noise?
"granny cars"
Another head question(s)
head gasket cost?
head bolt(s)
Radio removal '99 lumina
Seedometer 2x actual speed?
Lumina hesitation when warm
1993 Lumina leaking yellow ooze
92 Lumina 3.1 Corroded Quick Connect Cooling Fitting
1998 Chevy Lumina stalls while driving...
1992 Z34 wont start
alternator
New here with prob (go figure huh)
rear strut
heater core bleeder valve
dexcool and electricty
Oil in plenum
ramps
98 int.manifold job update=
Budsocks
Did back brakes problems still
rear-end creaking
Low Trac Light!
1992 Z34 Lumina stalling
HELP ME PLZ. Need to replace inner tie-rod
95 Lumina, Need advice about tranny + Dimmer light
Window falling off track...
Changing my -96 Lumina to -96 Lumina LS?
Any tips? 91 "Parts Car" to 90 dead engine car
91 Lumina Oil Problem
92 Lumina rough idle at first,then surges.
96 lumina throwing code 306
Lumina 93, 3.1 starting mystery.
1998 lumina electrical problems
security light on dash
2001 Lumina Oil Filter Question
unknown warning light
Brakes 93 Lumina
Motor mounts or tranny?
3.1 vs 3.4
1990 lumina no spark 3.1
follow up on no voltage to fuel pump
1998 Lumina Heater Not blowing hot air
Lumina stalled out multiple times tonight
temp
Head Gasket Kit Question
Loud Chirping/Squeak Sound
95 Lumina will not start
egr question
Lumina Issues Ugh...
SES light 93
Service Engine Soon - #2 Cylinder
Defrost button
can't open driver door
98 lumina transmission question
Trans jerk BOOO
timing chain
Clacking noise when brakes are initally applied in morning
crankshaft position sensor
NEw to Luminas
Engine Removal
91 Lumina 3.1 "T" will not start
95 Lumina Heater
Got rid of Lumina - thanks - off to F Body Camaro
Belt tensioner question
93 Lumina not smooth.......
transmission on 92 Z34
what goes here?
3.1 swap update
Flywheel breaks on 1996 3.1 Lumina
3.8 Supercharger engine swap
Rack & Pinion Problems
engine revs on its own
wheel bearing
'90-92 3.1 swap
How to fix a short circuit?
97 lumina oil pump
98 Lumina 3.1 Lights Flickering
Parting out 91 Lumina Euro 3.1L
Questions about replacing rear strut mount
1992 Lumina Euro 3.1L won't crank
1995 lumina has thick gunk in engine ...
98 lumina stalls at operating temp! help plz
tranny leak
best 93 Lowering Spring???
dimmer switch?
how to set camshaft in timing?
Overheating or bad temp gage?
97 lumina dash lights-ON then OFF??? HELP!!
92 After start, Lumina dies from standstill
Lumina Z34 '92 wont crank
Turn signal wand
fixing a manifold coolant leak
1998 LTZ Sputters While Driving
91 chevy lumina z34 engine swap
1998 Lumina Exhaust? Problems HELP
90 Lumina Euor 3.1L Passing Gear Problems
97 lumina steering rack?
anyone parting out there 97 lumina
MAP sensor 95 lumina
whining noise from middle/rear of 98 3.1L
96 Lumina 3.1 NO FUEL PRESSURE AT ALL HELP, please!!
Changing the radio
96 Lumina remove door panel?
94 Lumina Euro overheating
94 3.1 euro tranny problems?
Brake routing diagram? (93)
gas mileage question
stupid wiper question
need help w/ stalling
Rear brakes rub when first starting out
Tranny replacement
Excessive air pressure when removing 1992 Lumina gas cap
How to tell if inner or outer tie rod bad
How to tell if muffler bad in 1992 Lumina
any helpful hints on tranny filter change ?
What should I do part it or sell it whole?
1997 Lumina wont start
These Wipers Suck!
int manifold torque =-??
1998 3.1 leaking coolant
90 Lumina-dies at light-check engine-over 45 drags
Weird Noise From Rear
service engine soon light
front passenger window motor
91 Lumina ECM issue
Shifting problems
NEED help Fuel problem
how to read codes on 95 lumina
what tranny?
abs light
shift lever difficulty=
1991 Lumina Euro 3.1 Need Some Help
205/70/R15 Stock Size
How High Can They Go?
help with 1991 lumina
Body Parts?!
'92 Lumina 3.1 No forward only reverse
a/c problems
91 Chevy Lumina
Clunk noise
Humming noise around Power steering pump or alternator!!
HELP! fast please
98 lumina LTZ
98 lumina starter?
clunking noise please help
**97' lumina- Question Please Help!!!!!!!!!
Milage per tank for 97 Lumina
A Lumina Story
how to replace master cylinder
Wiper problems
Strut cartridge pulls toward center of 94 lumina.
turn signal arm wont click back...help?
97 lumina wont start
1995 Lumina with 3.4L DOHC + leaking oil distribution cover
92 chevy lumia radio removal
93 Euro Problems.
1998 cool system bleed valves =-
98 rad cap question =-
5 prong trans conecter to 4 prong
gm 3.1 misfire
ABS light on...?
Anti Lock light on Dash
Engine swap
Chevy Decal
have you ever
Typical 90 3.1 Lumina issue
Battery Light on Dash 93 euro
93 Euro fuel pump or starter problem?
Check engine light
95 lumina dead
Frozen Air Compressor
98 lumina hesitation on inclines
changing crank position sensor
I believe it is the starter
Bad Tranny or electrical
cost of these repairs.
Location of ECM
Engine Theft Lock?? Anyone???
95 chevy lumina blows cold air only
PCV valve hose part #?
Replaced Head Gasket - Knocking??
engine computer question
Not starting when warm
oil pressure gauge?
Bulbs
remote starters with keyless entry
Kocking.. Won't Start
wont start on gas
Will not start
90 lumina idle speed
Heater
Top Speed
1996 Lumina Headlights stopped working
Replacing the cigarette lighter in a 1990 Lumina
It's doing it again
exhaust clatter
what is going on??
engine computer
Starting Problems! please read
1992 Lumina Euro 3.1L Quit can't remove the crank sensor for replacement
stupid question
94 apv 3.1 no spark/ no fuel
help lady with loud after market fuel pump
Over heating problem / lumia 97, eng 3100
97 chevy lumina
hard shifting.
Homelink and OnStar
Coolant temp sensor location (where is it?)
Water pump installation
Where's the coolant?
upgrading
could it be?
Please reply fast if you can help
97 Lumina Backfire
1995 Lumina Electrical Nightmare...
anyone ever use this???
help a beginner!
94 3.1 APV Smoke from Tailpipe
96 3.1 Check Engine Blinking
can you tell me if....
90 lumina wants to stall
First time poster needs help w/SES light problem on a 95 Lumina 3.1
WTB Both driver side door for a 1997 Lumina
93 3.1 lumina stalls at idle
Lumina '92 3.1L Overheats???????
help with 91 lumina 3.1 v6
96 Lumina 3.1
93 euro 3.1 auto
4T60-E bang and no more 3rd gear
No timing marks! 1995 Lumina
1991 Lumina 3.1 = No Blower Fan
Looking to buy a 96 Lumina
97 lumina camshaft position sensor
frost plugs
96' Lumina with load of Issues
electrical gurus - need your help - clock radio
no high speed blower fan
interior lighting problem with 93 euro...
minor problems with 93 euro...
oh oh.."volts" on the dash!
Little glitches add charm
91 AVP 3.1 - Tach Hookup?
91 APV 3.1 - Lessons Learned
Front Strut Cartridge Replacement
1998 Lumina Fuel Injector Trouble
97 lumina won't start unless wiggle the key
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
