View Full Version : Lumina
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25
  1. 3rd time this week my 97 broke...help!
  2. 1990 Lumina missing/misfire
  3. Removal of a 96 trannie...help
  4. Climate Control Problems
  5. DIY problems, '90 APV, help?
  6. 97 Lumina 3.1 Ticks when 1st cranked
  7. 95 Lumina APV ABS Master cyl replacement?
  8. Security light- 95-.3.1
  9. 92 Lumina 3.1 will not roll over
  10. 2000 theftlock radio code
  11. upper intake manifold
  12. Lumina Instrument Panel Lighting Failure
  13. Z34 stalling
  14. Need replacement door for 95 Lumina
  15. 1992 Chevy Lumina Part Car
  16. Engine power loss
  17. 97 ls or not?
  18. Side marker lamp socket for a 99?
  19. 96 lumina, trannie problems
  20. fuse box diagram
  21. Replacing the exhaust manifold on a 3.1?
  22. 1992 lumina smoking after idle
  23. V8 Lumina?
  24. 1991 Chevy Lumina Euro 3.1
  25. Thanks to A Stranger for fixing my Lumina APV
  26. Thanks to A Stranger for fixing my Lumina APV
  27. 97 3.1 Cooling system Issue........
  28. Intermittent starting...it's the key !!!
  29. See if this sounds familiar....
  30. 1990 APV tbi engine change
  31. 97 Lumina Brakejob/Windshield
  32. Lumina Head Gasket HELP!!!
  33. dash lights
  34. Power steering pump
  35. 1996 chevy lumina apv transmission trouble
  36. speaker size on 97 lumina
  37. 3.1 l Lifters
  38. To Anybody With A Z34 Lumina!! Please Read!!!!!!
  39. question for anyone who knows regarding the 3.1L V6
  40. 95 Lumina van ,dist harness for 3.1
  41. 3.1 to 3.4
  42. 1990 Chevy Lumina Horn
  43. 1999 Lumina Power windows
  44. 1997 Lumina
  45. Where's the fuel pressure regulator please
  46. Trouble Code
  47. Oxygen sensor and brakes
  48. 95 Lumina 3.1- AutoTransmission "thumps at overdrive speeds
  49. 99 lumina multistick mafunction
  50. Lumina 1/4 Mile and 0-60 Times
  51. 95 Lumina- 3.1
  52. cost of intake gasket replacement
  53. '96 Lumina 3.1 - Jumpy shift in OD when hot
  54. 91 lumina transmission
  55. Theftlock GM dealer account #
  56. intake vs. head gasket leak
  57. question about lumina Mods
  58. Tranny codes
  59. 93 lumina drivebelt question
  60. CD changer harness
  61. 95 Lumina APV cracked subframe at rear mount
  62. 1997 Lumina Service Engine Soon ??????
  63. Locked out of my 92 Lumina!!!! Please Help
  64. iridium Plugs?
  65. 1995 Firing order issues
  66. Cooling Fans not working
  67. Trunk Leaking ? - need input please
  68. Wheel Upgrade
  69. Factory Radio for 1996 Lumina
  70. 1990 Lumina Euro Tach and Speedometer Stopped Working
  71. 1992 Lumina APV
  72. Ignition Control Module
  73. Difficult Starting
  74. 96 lumina
  75. 93 lumina not starting right / stalling out
  76. Check engine Chevrolet Trans sport
  77. Car won't start floods out.
  78. Quick disconnect
  79. Starting problem
  80. Blackout Tape?
  81. Lumina Body Kit
  82. 2 problems
  83. richtazz is back!!!
  84. Antifreeze Disappearing From Overflow
  85. annoying squeak
  86. EGR trouble code, where is it??
  87. electrical problems
  88. got the code info
  89. Cold air intake for 3.4 dual twin cam
  90. rattle noise from 97 3.1 lumina
  91. codes, too fast
  92. mannyboy, question for u/ or anyone that can answer it
  93. 91 euro , engine issues
  94. My 1998 Lumina has code PO303
  95. Valve Cover Leaking Oil
  96. 91 3.1 stalls while turning around
  97. Engine Disassembly
  98. Z-34 Rear Calipers
  99. trans prob in z34
  100. 96 Lumina - Clunking noise in suspension
  101. Marvel Mystery Oil
  102. 97 Lumina fast idle, low acceleration
  103. 94 Lumina starts-but stalls out
  104. Try This
  105. Desparate for help.....95 Lumina sedan 3.1L
  106. Please HELP! My 93 Lumina won't start
  107. 96 lumina exhaust leak ?
  108. Need Asst. please
  109. 3.1 L oil filter nippel
  110. Transmission disengaging
  111. 1992 Chevy Lumina wont start
  112. Lumina Police Rim Caps
  113. CEL/Knock Sensor
  114. Transmission Overdrive Slip
  115. Good Tires
  116. Valve Sticking
  117. 93 Lumina Euro Door Handle Installation
  118. 92 Lumina Z34
  119. 1993 Lumina Power Steering
  120. Lumina Hood Release Lever..BROKEN...HELP!!
  121. 1990 lumina wheels
  122. my dad fially retired from gm!
  123. Oil pan on 94 sedan
  124. Wanted: Z34 Mufflers
  125. Panel Lights
  126. Locked Out
  127. Belt squeak when warm
  128. Engine problems Need Help Desperately
  129. sound system wiring on a '98 lumina
  130. Help
  131. 95 Lumina won't run after warmed up?!?!
  132. bigtime trouble-1990 lumina apv
  133. 97 Lumina Vaccume
  134. Starter Removal
  135. Leaking Engine Coolant?
  136. 3.1 engine rebuilding
  137. Intake Manifold Gasket Repair
  138. weird noise from under hood or steering wheel?
  139. vacuum leak in 94 3.1 apv?
  140. 94 Lumina Ecu Problem?
  141. dash lights
  142. smoke at start up.
  143. egr
  144. transmission
  145. transmission noise
  146. Okay, new thread, new topic
  147. Leaking Head gasket
  148. 98 Lumina
  149. 97 Lumina hesitation
  150. Anyone know (fuses)
  151. random misfire #2 cylinder, 97 Lumina
  152. 98 Lumina lacks power
  153. Not kicking into gear... tran probs
  154. Replacing Battery
  155. Leaking oil pan gasket
  156. 92 lumina
  157. P0446 - 1998 Lumina LTZ
  158. Does anyone have programming instructions for the 94-96 Lumina APV remotes?
  159. Cluster
  160. stumble
  161. Euro gagues in a regular sedan?
  162. 1990 Lumina Van wont friggin run
  163. 97 Lumina,3100 fuel injectors
  164. Paint for Hubcaps?? Any ideas?
  165. 97 lumina fuel injector install
  166. velly velly strange
  167. 1997 Lumina Transmission
  168. need help wit engine stalling and jumping
  169. 97' Lumina (Fixed it..) But another Problem..HELP!!
  170. 97' Lumina (Fixed it..) But another Problem..HELP!!
  171. name of body panel?
  172. Transmission is wailing, what now???
  173. '93 Z34 Lumina High Idles when i start it.
  174. Removing Headlights on 93' Lumina
  175. 1990 lumina interior panel clips
  176. 96 Lumina - Speedometer Malfunction
  177. z34 starter removal
  178. hub problem on 1990 Lumina
  179. 2000 Lumina, heat gauge problem or sensor problem
  180. Please help...brake pedal vibration
  181. 1992 Chevy Lumina APV
  182. Rattle noise from steering column
  183. How to replace a drive shaft seal?
  184. 1997 Lumina - Good Head Unit?
  185. tac vs. no tac
  186. heat problem on 3.1l
  187. Side Skirt for Rocker Panel
  188. Engine Stalls Out
  189. Help With Pulling Codes
  190. Replace Rear Signal on 96 Lumina Sedan
  191. 1997 Lumina Problems (Major?/Minor?) Help PLEASE!!
  192. Headlights: hi beams work, low don't
  193. 1995 Lumina problem
  194. Wanting To Learn How To Rebuild 95 lumina Transmission
  195. rough idle
  196. Suspension Problem
  197. Where is the temp gauge sensor at?
  198. '95 Lumina 3.1 Transmission Choppy
  199. changing out an Ilumina 3.1 engine
  200. Trouble Code p0304
  201. 98 getting hot.
  202. Trouble Code p0304
  203. Erratic RPMs
  204. Anti Lock Break Light
  205. 1993 Lumina stalling and bad oil leak
  206. 1997 Lumina 3.1 EGR Code 0401
  207. Crazy ol' cooling problems
  208. hesitation
  209. 1992 Lumina Euro Won't Start
  210. 97 Lumina 3.1 stalls intermittantly
  211. sorry to be rude
  212. No air coming through dash vents
  213. Heater
  214. Airbag replacement?
  215. 3.1 fuel injectors
  216. Will 95 parts bolt up to a 98?
  217. Nearly Impossible
  218. Stumbles on acceleration?
  219. Electrical???
  220. 99 Chevy Lumina - ACCIDENT
  221. Lights in Stock Delco Radio
  222. Raw gas smell / hard starting ??
  223. Back-up Lights And dome light!
  224. finding parts?
  225. Lumina Z34 Rear Spark Plugs
  226. under car neon kit
  227. 1997 Lumina Security Light
  228. Back-up lights won't go off!
  229. rough idle...valves?
  230. 96 Lumina - Heater / Over-heating Problems
  231. '96 Lumina - Have new key, car won't start
  232. starts then dies
  233. One more rack question
  234. righty tighty, lefty loosey?
  235. need a quick answer
  236. wtb pass taillight, rear bumper lense, floor plates
  237. Electrical whine???
  238. '98 Lumina Brake Lights
  239. Taking off the Dash
  240. transmission swap
  241. Brake Lights Being Crazy
  242. 97 Lumina - ACCIDENT now WONT KICK OVER
  243. 3.4 DOHC For Sale
  244. rack question
  245. 94 Lumina Euro 3.4 DOHC fouling plugs in rear bank
  246. 96 lumina p1200 bucking jerking highway speeds
  247. installing different inst. cluster...96 base model
  248. When idling I hear whining noise
  249. 90 Lumina 3.1-Help find TCC solenoid plug
  250. What I get for bragging
