View Full Version : Lumina
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25
  1. standard or metric
  2. My '92 Lumina starts,runs, dies.
  3. Body Kit for a '98?
  4. Are luminas back
  5. 2001 Chevrolet Performance Upgrades?
  6. Please respond, I know you guys are looking (trip meter)
  7. Electric door switch not working
  8. mass air flow
  9. 2001 Chevy Lumina Air Pump?
  10. 91 3.1 runs rough at idle sometimes
  11. 94 3.8 Lumina APV miss/surge
  12. 3.1 98 lumina ABS light
  13. 96 lumina a/c
  14. Please help a blonde - stalling 1990 Lumina
  15. 93 Lumina 3.1L Timing Chain or Belt?
  16. Starts good but dies after a little while
  17. 1992 Red Z34 Lumina For Sale
  18. Wrong coolant causes problems?
  19. keyless remote
  20. 91 Euro Jarring miss
  21. 91 Lumina Crank Sensor
  22. Putting power windows and door locks on a car without them
  23. Another Transmission Problem
  24. AC Compressor bypass
  25. 92 lumina van front blower motor
  26. Compatible Parts for a 1992 Chevy Lumina Euro
  27. Bleeding brakes?
  28. key stuck in igniton
  29. 2001 Lumina Brakes Squeeking
  30. 96 lumina no start/run
  31. EGR cleaning
  32. manual transmission
  33. can not pop the hood
  34. 93 Lumina APV Radiator (cost?)
  35. a/c help
  36. Low Coolant Light On
  37. power steering vs. altenator
  38. 90 Lumina front right window won't go up.
  39. Help! Lumina overheating!
  40. front end noise
  41. pcv valve
  42. Shaky car
  43. a/c help
  44. lumina 1999 LTZ cuts out
  45. Ciggy lighter burn out on 95
  46. 94 Lumina APV intermitent Start... help
  47. 93 Lumina Won't Start
  48. Fuel Question
  49. 3.8 vs. 3.1 {Again Please}
  50. Changing rear drum brakes?
  51. 91 Euro 3.1 ignition module
  52. Wierd Tranny Shift
  53. 91 Lumina Euro 3.1 Crank Sensor
  54. M38A1 Solex Carburetor
  55. Need Some Help!
  56. 93 lumina.. weird.. just read :)
  57. Stop the Stalling ! !
  58. Stupid car!
  59. ignition control module
  60. 90 lumina 4 door, cd wiring problem
  61. 95 Lumina - Brake lights won't work when left turn signals on
  62. starving for gas
  63. 93 lumina
  64. Are Lumina heaters known for poor peformance?
  65. 93 Lumina dies
  66. Where's the fuse for door locks on '99
  67. Maybe I'm not looking hard enough
  68. Recalls?
  69. Back gate to van doesn't close correctly
  70. changing a 98 lumina serpentine belt
  71. 93 Lumina No start
  72. My Lumina Starts the shut off right after!!! HELP!!! Please!!!
  73. car lacks power
  74. paint recalls??
  75. 1990 Lumina is the ECM my problem?
  76. why luminas suck
  77. Electrical messages
  78. How to remove distributor block off plate 3.1 1993 Lumina Euro?
  79. Van revs like crazy when first started
  80. Help, my entire fuel pump assembly bent 90 degrees..
  81. engine swap
  82. 96 lumina security light always on & intermittent no start
  83. Timing Belt and or Chain Locations
  84. 96 Lumina Service engine light????
  85. stalls for the 1st 15 minutes of driving
  86. possible short in steering column
  87. Lumina Running REALLY Rough
  88. sensor problems?
  89. 93 rear end sag
  90. front struts
  91. Keyless remote receiver
  92. Lumina SS?
  93. Z34 oxygen sensor location!
  94. Bad Coil send an Error Code?
  95. sound stystems wires
  96. alternator removal
  97. Cooling Fans will not turn on unless hardwired.
  98. 1996 lumina ls Timing belt
  99. 1990 Lumina Climate Control
  100. AC going out
  101. 92 Chevy Lumina Wont Start
  102. Rear End Sits Lower, Any Way to Raise?
  103. rear brake rotors
  104. engine shampoo
  105. 95 Lumina APV
  106. wont run
  107. Changing of air filter?
  108. For Sale: New KYB Rear Struts
  109. Intake manifold pitted from leaking coolant
  110. Anyone have seatbelt problems?
  111. Lumina Seat belt light on
  112. twin duel cam V6
  113. Aftermarket deck in 90 lumina
  114. Oil Leak
  115. Trouble Codes Question
  116. 1993 lumina van 3.8 stalling problem.
  117. valve arrangement 3.1
  118. Dashboard display light problem!!
  119. 1995 Lumina Fuel Injection
  120. PCV Valve???
  121. Brake light ? 96 Chevy Lumina
  122. '98 Lumina 3.1 crank sensor
  123. Replacing Rearview Mirror
  124. I think i want to sell my lumina
  125. 92 Lumina Getrag Tranny.
  126. 3.1L 98 Lumina oil leak
  127. GM 3.1, 3.4 and 3.8 Coils
  128. Water pump on 1999 Lumina
  129. Body Kit For 95 Lumina Ls
  130. new ECM on 1993 Lumina car and still stalling
  131. 95 lumina steering
  132. Foamy powersteering fluid
  133. 3.8 vs 3.1??
  134. Somthing Wrong With Me Signals
  135. Clean, Clear, and Under Control....not really...
  136. e brake
  137. New to this forum
  138. Transmission 3.1 95 Lumina Sedan- Hard Reverse
  139. 3.1 jarring miss
  140. lumina sometimes starts other time just clicks?
  141. Air
  142. Body Kits?
  143. got any ideas?
  144. 1998 cheverolet lumina breaklight trouble
  145. Custom Guages!!!!
  146. ABS...Real brain teaser.
  147. what gas mileage do you get?
  148. hey! help bad torque converter clutch solenoid??
  149. Help Asap
  150. Van won't start...fuel drips out of injectors.
  151. 92 lumina power steering problem
  152. Help,turns over but won't run
  153. 90 lumina fuel pump
  154. Where is the Idle Screw to SPEED it up..
  155. Help with thread below this ASAP
  156. HELP PLZ!!!! 93 Lumina apv
  157. No power to the fuel pump relay circuit
  158. 96 lumina,does'nt shift into gears-HELP!!
  159. 3.4L Lumina miss
  160. Can some of You please answer my Threads Below
  161. Freeze Plugs Leaking
  162. hood release
  163. How to Speed up my Idle?? (90 euro 3.1)
  164. Flooring my 1990 3.1 Euro.. Is it Harmful to the Car??
  165. I hate this car....Z34 Lumina, one thing leads to..
  166. 3.1 miss fires
  167. Lumina, how much you think i could get
  168. Typical Lumina Problems?
  169. Coolant Temp Sensor Replaced
  170. oil pump!!!
  171. Lumina APV cruise control n/w
  172. Brakes
  173. Sun roof problems
  174. PCV hose broke
  175. Best Spark Plugs and Wires?
  176. 98 Lumina 3.1, 105,000 mi, brakes vibrate/shake sometimes when braking over 40mph
  177. How do I know if the fuel pump is bad?
  178. 93 Lumina 3.1 horrid noise on braking
  179. Speed Dometer doesn't work 97 Lumina
  180. Instructions for Head Gasket Replacement by a Novice
  181. Brake Noise
  182. 97 Lumina Turn signal don't work
  183. Service Engine Soon - 97 Lumina
  184. Idling/ Stalling problem
  185. Fans run only with coolant sensor unplugged
  186. 94 3.1 Lumina battery drain
  187. 3.1L to 3.8
  188. Coolant Temp Sensor?
  189. Transmission Tune Up
  190. removing parking brake
  191. Brakes
  192. rear brake problem on 90 3.1
  193. EGR valve
  194. sudden over fueling, raw gas, black smoke
  195. 97 Coolant Issues
  196. 93 Lumina APV 3.1 Electric Window Motor replace.....
  197. Strange Noise in Rear
  198. Help
  199. 95 Lumina 3.1 bad temperature gauge?
  200. Possible Battery Drain
  201. car radio 99' lumina
  202. Help replacing rotors on 93 Lumin Euro?
  203. RPM Question
  204. Missing cylinder in 93 Lumina
  205. Lumina temp problems
  206. replacing fuel pump
  207. Coolant system mystery
  208. Locations, locations. 1999 Lumina.
  209. 94 lumina euro 3.1 wont start
  210. Tail lights for a 95??
  211. Engine skips at high rpm
  212. Engine/Tranny overhaul and upgrade...HELP!
  213. 92 Lumina Euro cooling system
  214. 92 Lumina
  215. 92 chevy lumina v6
  216. can't change defroster setting
  217. 1990 Lumina Stalls
  218. Flushing out 99 lumina
  219. 92 lumina won't start recent engine rebuild
  220. Please Can SomeOne Help Me
  221. Please Can Some One Help Me ?
  222. 94 Lumina Z34, Trying To Sell But Irratic Idle!!! Help Please!!
  223. Crankshaft Sensor
  224. Why Do My Brakes Suck?
  225. Can some one help me Please
  226. 94 Lumina 3.1 v6 stalls out when put in drive
  227. 2001 lumina ECM
  228. 92 Lumina 3.1-Battery or alternator?
  229. Electronic ignition module location
  230. 1997 Lumina-front license plate mounting/bracket?
  231. 96' Lumina:Dash out/Tail lights out, brake lights work
  232. 94 Chevrolet Lumina Runs For About 10 To 20 Min's Then Stall Out After Its In Drive
  233. Replace fuel filter: release pressure?
  234. climate control not working
  235. Lumina APV wiper fluid leak
  236. 92 Z34 for Sale
  237. Remotes
  238. starter motor
  239. IDLE problem
  240. Possible oil pump problem????
  241. Squeaking and sqawking
  242. "97 Lumina Struts/Shocks
  243. 1990 Lumina blowing power door lock fuse
  244. Can I get check engine codes without a scan tool?
  245. OBD 1 or 2
  246. 99 lumina-Tune Up?
  247. 92 lumina speedometer sticks
  248. HELP Please!
  249. transmission problems
  250. what is the egr and what does it do?
