93 lumina electrical ??
bksixer
04-29-2007, 05:49 PM
Started a thread earlier on fuel issues.. Don't think thats it... Changed filter and tested pump.Its working. All fuses replaced... Checked plug on #6 cylinder.... Gap .085 ...Could there be a coilpack problem based on gap width???? 152,000 miles last tune up at 80,000... Help!!!!
maxwedge
04-29-2007, 06:39 PM
I'd replace the plugs first, here.
bksixer
04-29-2007, 06:44 PM
Planning on that tomorrow. Along with wires... Post results tomorrow.. Thanks for the ideas and help
jeffcoslacker
04-29-2007, 10:46 PM
You put a good plug on a wire and ground it, give it a crank and see if it's sparking at all?
bksixer
04-30-2007, 10:44 AM
Did that with a plug and nothing... Changed all plugs.... Still nothing .. What next??? I have a bit of mechanical knowledge but am stumped here
maxwedge
04-30-2007, 02:48 PM
Get a scanner on it and see if you have cranking rpms, if not suspect the crank sensor or ign. module, the module can be tested at Napa or Autozone. PITA to get it off, though.
bksixer
04-30-2007, 07:02 PM
Thanks... pulling ign mod. tomorrow , testing it @ autozone...
