View Full Version : Lumina
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. 1997 lumina 3.1 trys to start and stalls.
  2. please help
  3. Can 94 Lumina 3.4L Euro be towed on all four wheels?
  4. 93 Lumina 3.1 L wEngine won't run in reverse
  5. Dexcool...
  6. Brake light problem...
  7. exhaust crossover or exhaust manifold?
  8. doing mufflers myself: from wrecker
  9. Need Help with 1995 chev lumina Ls
  10. Replacing back brake shoes
  11. Ignition Coils and Ingnition Control Module
  12. It is Time! To PAINT!!!!
  13. 3800 3.8 L jumping caused a pop now terrible idle
  14. lumina 3.8 L 3800 idle eratic idle after jump start
  15. Idle Problem?
  16. UGH curse you anti-theft machanism
  17. ECT sensor
  18. 1995 Lumina Sedan Idle Problem, just replaced PCV Valve.
  19. '93 Lumina brake problem
  20. 1997 chevy lumina coolant flush
  21. 1995 lumina 3.1L TBI (FUEL PUMP)
  22. 97 3.1 engine swap
  23. Emergency Brake Ripoff - key warning
  24. 97 lumina still no start
  25. ABS brake sensor cable - a rapscalion to fix
  26. 1990 w/2.5L 4cyl - random rough running
  27. lumina loses all power and dies
  28. 1999 Spedo Stopped Working
  29. Added coolant = Screwed everything
  30. Adding Coolant --> Bleeder Thing
  31. 97 lumina transmission fluid black
  32. 1993 Lumina euro transmission issues
  33. Programming Keyless Entry Remote
  34. 1996 Chevrolet Lumina
  35. High pressure steering line,leak,replace
  36. Luminas for sale?
  37. Replacing a rear Brake Caliper...need some advice/help
  38. Used Lumina for parts: is this a good deal?
  39. The Lowdown
  40. Loosing Coolant "Oringinal Gaskets"
  41. Spark Plug wires...
  42. Rust on Fuel Line...
  43. 3.8 Water Pump
  44. Small Black Bar
  45. maybe you know?
  46. Full size tire replacing spare.
  47. total power loss while driving
  48. Factory Part Numbers
  49. Torque Ange Meter and Water pumps
  50. GM 3.1L lower intake manifold gasket problems
  51. 1997 chevy lumina 3.1L valvetrain rattle/noise?
  52. Spark Plugs...
  53. Engine Rev
  54. 98 lumina brake issue
  55. 97 lumina turn signal switch
  56. Where is the starter relay on my 97 Lumina that has anti theft system
  57. Ive a problem with the a/c on my 98 chevy lumina
  58. alternator
  59. 94 Lumina 3.4L: MAP sensor or MAF sensor system?
  60. Quick Question
  61. Stupid things that make you freak out
  62. 1997 lumina 3.1 oxygen sensor
  63. Any good retailers that do brakes?
  64. Lumina vs. Park Avenue
  65. Knock from the engine! :(
  66. OEM Keyless can I use this Module?
  67. Interesting Find On 93 3.1v-6
  68. Flasher issue...
  69. 97 Chevy Lumina brakes/Master Cylinder
  70. 1997 chevy won't pass smog code P1870
  71. Z34 Very hard to start SOMETIMES
  72. Key Stuck In Ignition
  73. Car knocks/pings when cold
  74. RPMs
  75. 96 Lumina Blowing ECM fuse
  76. 97 Lumina 3.1 leaking coolant
  77. 1990 lumina fuel delivery issue
  78. Gauge Help
  79. 97 Lumina 3.1 leaking coolant
  80. 1994 Z34 Lumina
  81. Cylinder 6 misfire
  82. Question about oil
  83. Driver's Seat Annoying cushion problem fixed.
  84. Front Corner Light Repair - How To
  85. Rattling Hubcaps 97 Lumina
  86. 1990 Lumina will not start, Just keeps cranking
  87. brakeline leads to broken springs?
  88. Safe to run SeaFoam?
  89. Flowmaster 40 muffler (dual out) + 2 cherrybombs?
  90. exhaust shield ??
  91. OEM Keyless Entry install
  92. My 1998 Lumina won't start
  93. 97 Lumina Volts Light
  94. Quick ? regarding replaced alternator
  95. 1997 Lumina "c1236 Low System Voltage"
  96. Starter ? on a 92' 3.4
  97. Can better Exhaust system give better MPG?
  98. Converting to E85/Ethanol or any mixture of Ethanol/gasoline
  99. 91 lumina hunting idle and dieing
  100. '96 front strut cartridge problem
  101. Replaced trunk and glove box locks on Lumina
  102. who is better?
  103. Are cooling fans using to much electricity?
  104. HHO Hydrogen fuel suppliment for better MPH & savings
  105. Neither Fan Turning? is that normal in summer?
  106. Install an overhead light switch: 3 good reasons!
  107. Saving old battery as spare: EDTA reconditioning...
  108. 2nd Alternator in place of AC unit?...
  109. Trunk release button revisted
  110. 1991 lumina
  111. Keyless Remote with universal?
  112. Can these Sparkplugs save 10% of my gas (MPG)?
  113. AC Problem
  114. 1990 Lumina 3.1 Overdrive Transmission Apple Coring/Reluctor Drive Shaft No shift
  115. Not another problem!?!?! 92' lumina z34
  116. Which fuse did I pull??
  117. OEM Keyless entry
  118. Lumina 1998 3.8L RKE Receiver
  119. '96 rear brake drum stuck.....
  120. 97 check engine light problem
  121. 95 lumina rear noise
  122. Cabin air filter
  123. Intermittent problem with Lumina97
  124. 99 Lumina a/c clutch wont engage
  125. 1997 lumina 3.1L Coolant in oil?
  126. Cracking Tire
  127. 91 Lumina Ignition switch problem
  128. Ran then didn't..
  129. 97 Lumina 3.1 High RPM after thermostst change
  130. Spare Tire Replaced with Full Tire
  131. 98 Lumina Will Not Start
  132. air filter
  133. waterpumps
  134. Wires cut coming out of passenger front wheel well and down...
  135. Yet another issue
  136. 1990 Lumina Stalls After Exiting Highway
  137. 93 Lumina Chime Issue
  138. 1996 Lumina starting problem
  139. 1999 lumina turbo
  140. 1991 lumina problems # 2
  141. 95 Lumina A/C Inop
  142. Tie Rod Ends: What torque for castellated nut on steering arm?
  143. What ECM and EPROM should my /94 3.4L v6 be running on?
  144. What Thermostat and Eprom gives best mileage?
  145. How to rebuild your own alternator in 10 minutes!
  146. Where is the DLC on a 99 lumina?
  147. 99 lumina driving me crazy
  148. Mmmm fresh cold AIR!!
  149. Where is "illumination delay relay" for dash lights? /94 lumina
  150. battery draining overnight - dead, 3 problems
  151. Lumina not charging, please help.
  152. Compressor wiring bad?
  153. loosing coolant
  154. A few questions about the z34
  155. 1999 lumina
  156. Getting tired.... Engine Tick.
  157. 1990 Lumina Euro 3.1 Overdrive Automatic Transmission Problem
  158. 96 z28 engine /98 Lumina swap
  159. Spark plug wires - what's good?
  160. crazy mult. problems
  161. 1993 Check coil packs.
  162. 98 Lumina, groaning fuel pump?
  163. 2000 Lumina Needs Your Help
  164. A new A/C issue
  165. Knock and the loss of power
  166. Another 92 Euro 3.4 A/C question
  167. K&N Air Filter (Worth it?)
  168. 92 Lumina Euro 3.4L ABS Brake Problem
  169. ICM, ECU? How do I determine which one?
  170. question for the pro's
  171. Idle issue with 94 Lumina 3.1 V6
  172. Install a Trunk release button
  173. AC only on drivers side?
  174. ‘96 Lumina 3.1 with a rough idle
  175. Speed Sensor Shift Issue 1990 Lumina Euro 3.1
  176. Need a slim jim...
  177. 97 Check Engine Light
  178. 1993 code 42
  179. 3.1 overflow hose part number?
  180. Horn Location in 1999 Lumina
  181. New fuel filter = hard starts?
  182. no a/c no shift check engine light on
  183. engine makin funny noise
  184. Knocking noise
  185. how goes it?
  186. 98 Runs great but starts hard.
  187. Drivers side door lock stuck ('97)
  188. '97 Fuse Block
  189. 95 lumina security lite is on on
  190. 1993 starts then dies. Possible ECM problem?
  191. A/C Problem
  192. Knocking noise from under car.
  193. 94 lumina swap question
  194. Can't find?
  195. 99 Lumina brake lights
  196. 98 lumina ltz
  197. Yeh, 97 Lumina starts again
  198. What Controls the speedometer?
  199. 97 Lumina Won't Start
  200. 92 Lumina Z34 Shifting Issues
  201. Posting Rules
  202. 92 Lumina Diagnostic Error Code List
  203. Pics/Profile
  204. Another question about my 92 z34
  205. 1993 Lumina Z24 Blinker Issues.
  206. 1999 3.1 blows fuse every time i hit the brakes
  207. New Problem: Stiff/Hard Gear Selector
  208. A oil cooler
  209. 97 Lumina 3.1 Front bumper
  210. Sequencial Brake Lights
  211. where does the antifreeze go
  212. 92 lumina 3.1
  213. Mechanics
  214. 97 Lumina wireing
  215. lumina 1992 3.1 problem
  216. heater motor
  217. looseing coolant
  218. Insurance Question
  219. Strange thing with AC
  220. Whats a PVC Hose
  221. 92 Euro brake problem
  222. One more post for Maaco paint Good or Bad
  223. forever lights? 92 z34
  224. Lumina 98 3.8 L Cooling water...
  225. 92 lumina z34 Knock sensor?
  226. Anyone have Engine Codes for Z34 3.4L???
  227. 1992 3.4 Liter Chevy Lumina Euro getting HORRIBLE gas mileage
  228. hydraulic lifters-3.1 L 97 Lumina
  229. where to get diagnostic help.
  230. low coolant light
  231. Dash Lights / Parking Lights don't work
  232. My Lumina is getting too hot! Please help and see if there isn't something cracked!
  233. 90 lumina a/c problems?
  234. 1998 Lumina Speedometer cluster
  235. 1995 Chevrolet Lumina 3.1 (M) Motor>>>>Runs rough at idle and under acceleration
  236. 1992 Lumina tail lights
  237. 93 Lumina 3.1 TCC replacement
  238. Inner tie rod replacement, 1996 Lumina
  239. Car won't crank to start
  240. 1990 Lumina Euro 4 speed automatic transmission
  241. 93 Lumina 3.1 cranks, no start, no spark
  242. Check Fix, Surging, Wanting to die, Service Engine Light
  243. 1991 lumina PROBLEMS
  244. Transmission - Rough Shifts and Whine
  245. Air Intake for Lumina
  246. lumina transmission
  247. hello im new to AF
  248. 98 fuel pump ?
  249. Side Window Lights
  250. 1992 Chevy lumina Euro 3.4 Liter getting terrrrrribble gas mileage
