Compression Test results? Need Help
4G4D Store
07-01-2005, 05:04 PM
I've got a couple 86-87 sedans and I'm doing compression checks on the engines. What kind of results should I see - the are both d15a2 engines. I've done one and got 135 and 155 - I can't seem to find these figures anywhere. If anybody could help me out with this I'd appreciate. I just need to know what kind of compression check results I "should" be seeing.
Thanks
Thanks
KrisSmithRocks
07-08-2005, 01:25 AM
well as far as my experience goes it isn't really the numbers that you get because i've noticed that as far as gauges go compression gauges are cheap pieces of s#@$ so i wouldn't trust their actual numbers but normally what i look for is uniformity. If all the cylinders are within like 10 or even 15 psi of each other i generally would think that there arn't any problems.
