View Full Version : Impala | Impala SS
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15
  1. My 01 Chevy Impala Making Humming Noise
  2. Coolant Temp
  3. Won't idle on its own. 02 Impala 3.8
  4. Radio Stays On
  5. clean egr pathway
  6. How much for Transmission Repair!!!
  7. Remote starter quit working '09 Impala
  8. 2000 Impala wiring diagram?
  9. 2000 Impala front end shimmy
  10. rearview mirror doesn't always dim and the map lights not always working
  11. Oil Leak
  12. Tire pressure info center Re-program
  13. To Buy a New Car or Fix the One I Own
  14. thermostat
  15. How to replace the positive battery cable on 2009 impala?
  16. 07 Impala 3.5 No Crank
  17. + - Buttons below cruise control on steering wheel.
  18. 2010 IMPALA Front Sway Bar R/R 3.5 litre
  19. '04 Impala speedo from kph to mph?
  20. side mirrors defroster not working right?
  21. Impala 2004 3.4, harsh vibration in my brakes, non ABS, HELP!!!!
  22. 2004 Impala, intermittent extended crank time
  23. '04 Impala Gas Gauge Bad
  24. '08 impala, strange thing happening with heating
  25. Thank you
  26. 2005 Impala LOW Brake Fluid Warning, TRAC light, BRAKE light
  27. Location of OnStar box
  28. Program 2012 Impala keys
  29. 2012 Impala LS, no key reminder chime
  30. 2002 impala squealing
  31. Evaporator stink, how to get rid of it?
  32. Flickering dash guage
  33. runnability problems 02 impala
  34. 2008 ss a/c trouble
  35. Pleasehelp/SingleMom/Terrified/2002 impala problems?
  36. 2006 Impala gas issues
  37. 2005 impala,got to press the gas to get started
  38. 05 Impala will not Crank Over
  39. late 70s early 80s 4-door
  40. Rusted jack points
  41. 08 impala cluster change
  42. aftermarket Transmission Cooler
  43. 2002 Impala-trans. shift hard
  44. 2003 Impala LS cruise light
  45. how to clean EGR
  46. Heater not working suddenly
  47. Seat belt light and air bag light
  48. Locked keys in my car and I think the tow truck company damaged my door
  49. Could I put a 06-09 Impala Radio in an 04?
  50. Tach Fluctuations----Bad Tranny??
  51. 2004 Impala 3.8 stalling?
  52. 07 Impala p0142
  53. Suspension Noise
  54. 2010 base LS Air Bag Removal
  55. possible new engine time...
  56. 2004 add mini plug audio in?
  57. new to me 2007
  58. Good Scan Tool for ABS Monitoring
  59. trying to locate oil sender on 3.5L 2006 impala
  60. 01 Impala 3.8L Hesitation stumble
  61. Check engine light reset.
  62. 2004 Chevy Impala
  63. 2005 Impala 9C3 (Police) 3.8 cold starting issue
  64. 2004 3.4 no heat, overheat and sudden cool off
  65. Heat issue - weird moisture on window?
  66. Does 07 Impala 3.5 have an EGR Valve?
  67. 2000 Impala 3.4L idle problem
  68. 2003 impala cooling system problems (HELP)
  69. flasher
  70. oil pressure low; stop engine???
  71. 2008 doors locking
  72. 2001 Impala on board computer
  73. Coolant leak from 2000 impala
  74. Car doesn't get warm in winter
  75. brakes thumpy sometimes?
  76. Side view mirror
  77. Serpintine belt keeps breaking?!
  78. Problems with heat on driver's side
  79. Transmission slippage going into Overdrive
  80. 07 Impala lost all keys
  81. '10 chev imp 3.5L flex fuel thermostat location
  82. 02 impala abs, traction control not working
  83. Engine power reduced???
  84. 05 Impala transmission
  85. 2001 chevy impala blinkers
  86. Workaround for hot/cold actuator fail
  87. LIM repair recently, but something not quite right?
  88. Fender louver
  89. Engine overheating/Head Gasket questions
  90. trunk wont unlatch
  91. Freeze plug locations impala 3400 2000-05?
  92. 2001 Impala BCM re-programmed still problem
  93. Is there an glove box light in 2003 Impala
  94. Is there an glove box light in 2003 Impala
  95. 2003 Chevy Impala BCM Issues
  96. Service traction control and error code
  97. Evap purge
  98. Sway bar, Front
  99. 2000 Impala dash lights go out at night
  100. 2009 Impala door lock problem
  101. Crank position sensor question
  102. aftermarket hub covers 5 lug 115 pattern
  103. my 2003 Impala 3.4 is over heating!?
  104. water leak on 2000
  105. 01 impala key wont turn in ignition
  106. Spark plug change - hot or cold engine?
  107. 2010 Impala - Scary Stalling Issue at 55-60 mph
  108. 2000 impala unplugged wire
  109. Big big problem
  110. Check Engine light came on while driving.
  111. 2008 SS power door lock actuator
  112. Coolant Change
  113. 2004 Chevy Impala won't start with new battery
  114. Brakes squeaking, now fluid is visible.
  115. Keyfob remote only works if I'm next to my car?
  116. 2002 Impala LS Electrical trouble
  117. Loud Clicking Noise under passenger side dash behind the glove box. Need Help!!!!!
  118. 01 3.8 harmonic knock sensor removal
  119. 01 3.8 harmonic balancer removal
  120. please help im stumped...
  121. Not good being hot in summer
  122. P1810 code after trans swap
  123. 2005 chevy impala/overheating promblem
  124. 2001 3.8 Impala LS idling issue
  125. 08 Impala 3.5L Trans Leak (First thread Dissapeared)
  126. 08 Impala 3.5L Trans Leak
  127. 2003 Impala New BCM Will Not Program
  128. BCM Will Not Accept Program
  129. 2003 3.8L Impala Transmission - P0742
  130. Impala Passlock Issues - A Solution?
  131. 2003 Impala LS w/6500 miles_popping noise in steering column
  132. 4T65E Transmission Question
  133. Grinding noise from water pump area
  134. 06-12 impala black pillar cover by carboncovers
  135. Battery Light and exterior lights blinking
  136. Road noise between 35-60 MPH have changed wheel Bearings
  137. Rim for my car is cracked.....
  138. What's your age?
  139. 4T65E Trans whining after freeway run
  140. P0440, P0405/0404, MIL insconsitently on
  141. Installing a New "Boss BV9155B in-dash double din" stereo
  142. 2003 3.4 P0420 Post intake coolant leak
  143. ABS Diagnostics - ELM327 help!
  144. 2002 impala electric door locks
  145. 2005 Impala vibration drivers side
  146. 2003 Ls 3.8
  147. New Tire Time
  148. 03 Impala LS not starting
  149. Cant go over 30 mph!
  150. How do I get at my throttle body flapper?
  151. Tach Question
  152. 2008 Impala SS engine hesitation/shudder
  153. 08 Impala Trans Slip
  154. Daughters 2000 Impala
  155. Should I replace the head gaskets when I replace the lower intake gasket?
  156. "coolant loss-protection system" question
  157. Can't get rid of 301 code
  158. 03 Impala making a thumping noise
  159. OEM Rotors are problematic for newer Impalas - Any Quality Replacements?
  160. Battery Issue/Question - High Output Alternator Installed
  161. 2010 impala more problems
  162. 2002 impala 3800 crank no start
  163. Why so many fan control fuses?
  164. 04 Impala- Where is the heater fan resister located?
  165. 04 Impala- AC/Htr Fan not working
  166. 2001 impala 3.4l
  167. 08 Impala Power Steering Whine
  168. 2004 impala 3.8 rear head removal?
  169. 2004 Impala - Transmission issue after fluid change!
  170. 2009 impact heater not working on idle.
  171. 2002 impala losing radiator fluid
  172. 2002 Impala won't shif into 2nd
  173. Need help understand sparkplug wire ohms?
  174. Need help understand sparkplug wire ohms?
  175. 2002 impala floor leak FIX.
  176. AC Fan went out - where is it?
  177. 07 impala Leak?
  178. 2004 Chevy Impala
  179. Washed motor, no juice to battery now
  180. 2000 Impala Trailer Wire Harness
  181. brakes are thumpy... sometimes
  182. 2006 Impala keyless entry not working
  183. Dash Bulbs
  184. ORIGINAL Key Fobs do NOT work - NO STOCK RADIO - Please help!
  185. Dead heater blower
  186. 2010 impala interior lights
  187. door ajar & lights on after changed door lock
  188. engine oil
  189. Low Oil Pressure Indicator
  190. Dash lights turning off at night
  191. program a keyless remote
  192. 2001 Impala intermittent no start
  193. Powerdyne Supercharger kit 90's Impala
  194. 2003 Impala 3.4L loss of power/miss only at high speed
  195. 2004 impala stalls
  196. 04 Impala LS everything vibrating as driving at cruising speed
  197. 2007 Impala P0172 code solutions?
  198. 2009 impala ltz purchase
  199. 04 chev Impala randomly every 30 day no stater engagement.
  200. 2006 Impala 3500 Massive oil leak when cold and water pump leak's.
  201. Goofed somewhere!
  202. 2006 impala check engine light
  203. heat bypass hose
  204. Impala high pitch whistle when step on gas
  205. '02 Impala: No Start, Then Brake Pedal Start
  206. 08 Impala rear door locks not working
  207. Driver door actuator
  208. hid lighting
  209. 2004 Impala no start
  210. 09 Impala problems
  211. '01 Impala Steering Rack
  212. cruise control
  213. RPM's bouncing between 2000 rpm to 1500 rpm
  214. Outside ambient air temperature sensor
  215. Adding Bluetooth
  216. 04 Power Steering - Any way to make it into a dipstick?
  217. Would appreciate speculation on my ABS issue
  218. Serp. belt help......
  219. 2000 Impala starting problem
  220. 2003 3.4 impala vibrates (not shakes, vibrates) at low RPMs
  221. oil everywhere
  222. 2001 Chevy Impala P1404 Code.. EGR ?
  223. 2003 impala ls
  224. 2011 Impala LT Engine Decals
  225. Muffler Rattle?
  226. 03 impala misfiring problem
  227. 3 Codes...are they all tied together?
  228. Ignition code?
  229. A/C Charging: In Progress...
  230. Resetting programs
  231. Any common coolant leaks on p-side of 3.8?
  232. 2002 Impala w/police package cant find key fob ecu harness in dash
  233. Factory Radio
  234. key wont turn
  235. 2005 Impala 3.8 L leaking transmission fluid
  236. 01 Impala Not starting, No lights whatsoever
  237. 06+ Charging System Question.
  238. Warm Weather Power Loss
  239. Dead Blower 05 Impala
  240. 07 Impala - How to change Evap Solenoid?
  241. 2003 Impala stalls and ABS/TCS light is on
  242. Subframe bushings
  243. 01 Impala 3.4L
  244. '03 Impala LS ABS/TCS Issues 3.8L
  245. 2003 3.8L Engine VIN Location
  246. 2001 chevy impala headlight problem
  247. Temp slider light out
  248. 2003 impala front bearing hub assembly
  249. 2000 Impala Running Rough
  250. Control arm bushings
