How much for Transmission Repair!!!
tboImpala
12-11-2013, 10:46 AM
I have a 2006 Chevy Impala LT 3.5 V6. About 6 months ago I would sometimes have a issue shifting into reverse during intial start up. That went away. Yesterday I started it up and notice the engine was reving really high at 10mph. It finally got up to 35mph and I got on the highway. Everything was fine I was doing about 75mph. Got off the expressway and noticed the high revs again. Later that night I could not get the car into any gear PDN321. I cut it off and tried again. This time it moved but when I got to a stop sign it stopped again. parked it and had it towed to a Transmission shop. Is this trans shot? It sucks because I just paid the car off in April.
j cAT
12-11-2013, 05:08 PM
fluid/filter replacing is required with these at the 40,000mile mark. the use of the dexronVI is required. make sure these lube /tranny people use the correct fluid "NOT DEXRON III "............
THE OWNERS BOOK SAYS 100,000 MILES that is GM b/s !
for a rebuild 1800 would be about right if a basic one . make sure you get a 1 year warranty and make sure after 10,000 miles you have them replace the fluid/filter again.
Tech II
12-11-2013, 05:31 PM
First, the fluid level and condition should have been checked......
Next, powertrain codes should have been read....
Were there high revs in park or neutral, or did the high revs happen when in gear, as if the tranny were slipping?
tboImpala
12-12-2013, 02:26 PM
The car reved up when I press the accelorator pedal. I never felt the trans slipping or anything other than a couple of times when I was going in reverse after intially starting the vehicle
tboImpala
12-12-2013, 02:51 PM
This guy says it will cost 3000.00 because it is completely destroyed. He claims that there is metal in the fluid and broken metal shredded the gears and it's unsalvagable... He also says that he is putting in better parts than the original trans and that this will be a far better trans... I'm not the one to trust mechanics.( Have a lot of friend that are and I hear the stories) I'm 50 miles outside of Chicago and you have to have a car to get around.. So basically I was screwed...
Tech II
12-13-2013, 07:39 PM
Your other option is a low mileage tranny from a junkyard......
j cAT
12-14-2013, 02:06 PM
if the transmission is with chewed up gears I would get a used transmission and have a repair shop rebuild the scrap yard replacement.
I would not repair the transmission you have in the vehicle if it is totally destroyed.
make sure they clean out the radiator and the transmission lines to from radiator for the fluid cooling.
Blue Bowtie
12-15-2013, 09:52 AM
If the case is damaged, I'd agree that a good salvage yard transmission may be a better choice. If you can find a 4T65-HD as a donor that would be the best place to begin.
I'd also suggest you speak with your transmission shop and discuss what is being done to improve the unit. A new separator plate (Sonnax - NOT a GM plate) and valve body rebuild with a lower pressure TCC relief valve are essential. Ask them about installing the aftermarket long seals in place of the original THM designs.
waterkeeper03
12-18-2013, 07:30 AM
I just had s complete trans rebuild on my 2004 3.4 for $2100. So that price doesn't seem to far out of the park for a newer car. You should look into s low milage used replacement, might save you a thousand bucks.
