tuneup?
candp
05-26-2004, 09:08 AM
on obd2 1.0 engines,what contitutes a good tuneup?what is a good list?
geozukigti
05-26-2004, 01:21 PM
spark plugs, plug wires, distributor cap and rotor, fuel filter, and a bottle of fuel injector cleaner in the tank.
candp
05-26-2004, 02:22 PM
so aside from what has been mentioned...what does emission check,air fuel mixture,sensor check fall under? how did the 96 1.0 get the highest ratting mpg 50-60 when it came out?best i have been able so far 40..41.How do you guys check your air fuel mixture on these year motors?thanks
geojim
05-26-2004, 03:32 PM
I would add a PCV value, EGR value cleaning, check of all vacuum hoses, and air filter to the tune-up list. Plus a shot of carb cleaner down the throat of the throttle body.
geozukigti
05-27-2004, 09:12 AM
A/F sensor or what we call an oxygen sensor is not generally a tune-up piece. They're general maintenence. Like a timing belt. You can get an air/fuel ratio gauge on Ebay for about $40.
