View Full Version : '97+
Pages : 1 2 [3] 4
  1. Trip Computer resets after 2 hours
  2. IPOD on My passat 1998
  3. No Turn Signal / Hazard Lights
  4. engine is dieing on every intersection
  5. brake pad changing trouble
  6. '02 PASSAT Trunk lock
  7. 2000 Passat
  8. adding satelite radio antenna
  9. '98 1.8L I4...possible broken timing belt? What else could go wrong?
  10. '00 misfires, check engine light after 80k service
  11. Type of Coolant?
  12. W8
  13. Dip stick
  14. 2003 passat 1.8
  15. Passat 1998 owner 's manual
  16. ~~Load Knock from TOP of Engine~~
  17. Technical bulletins
  18. Check engine light
  19. 97 vr6, loud top end?
  20. chirping sound from engine
  21. cd changer
  22. 02 Passat Power brake loss when cold?
  23. Alarm Problems
  24. 2000 Passat Horn Location
  25. Power loss and stalled on interstate
  26. 2006 TDI starting problem
  27. A.I.R. Pump Relay #323 Location 01' Passat
  28. Overly active ABS
  29. Euro tail lights
  30. Universal Oxygen Sensor Replacement
  31. 99 Passat GLX steering problems
  32. electrics prob draining battery - help
  33. Adjusting headlights on 2001.5 Passat
  34. Indicator Column change? Passat TDI 98 MY
  35. Need help w/ '00 Passat 4motion suspension
  36. 1999 Passat - Front Rt Caliper Locks Up
  37. 1998 Passat tie rod removal
  38. standard alarm in a passat
  39. control cruise
  40. 2006 Passat hesitation
  41. 2000 Rain leaking through the pollen filter
  42. Check engine light 2000 1.8T
  43. Tires worn too soon - 2000 1.8T Passat
  44. synthetic oil only & timing belt
  45. 2000 passat hood release
  46. misfire codes.
  47. F into C
  48. rear wiper and window cleaner problem on 99 passat wagon
  49. I'm stunned!!!
  50. Repair bill went from $275 to $1700 in less than a day
  51. altenator change
  52. exchanging a MAF sensor between years
  53. Loud clicking on right side
  54. Trunk Release
  55. Problems with Tiptronic after installing new battery
  56. Electrical problems
  57. 99' 1.8T Headlight Lense
  58. 2006 passat
  59. 2001 passat problems
  60. Tiptronic kick in transmission when downshift
  61. 99 Passat hood won't open
  62. harsh shifting.
  63. Check engine light
  64. possible starter problem
  65. door panel
  66. Sluggish Shifting Gears-99 Passat Automatic
  67. 1.8L turbo burns oil
  68. abs module test ?
  69. Passat Remote Battery Change/Reprograming
  70. Loss of engine power at 3k revs in '97 1.9 TDi
  71. 2000 Passat rear window regulator
  72. chipping a 2003 v6 30v 2.8 passat?
  73. reset airbag light
  74. Door Lock Activates a Pump/Motor
  75. Odd musty smell in my 97 Passat VR6
  76. check engine light
  77. Door lock switch?
  78. VW diesel engines/vehicles
  79. Removing Door Panel 99 Passat Wagon
  80. do your vaccum lines
  81. repairs help
  82. turn signals do not blink 2000 passat
  83. 01 1.8Lturbo, O2 sensor code
  84. Front end rattle
  85. replacing power mirror switch
  86. power steer fluid loss
  87. Radio Problem
  88. fuel pump secondary circuit??
  89. o2 sensor, CEL
  90. Steering rack question
  91. oil/transmission fluid
  92. ABS MODULE TEAM! hELP guys
  93. gas level, check engine, emission
  94. Another problem!!!
  95. Throttle position sensor
  96. Oil Smell
  97. passat 1.9tdi loads of vibration on start and white smoke.
  98. Heated seats
  99. 99 1.8 turbo LOTS of Probs! HELP!!!!!
  100. Vibration on Acceleration?
  101. CD changes "No Magazine" message
  102. IS 1998 passat wagon is turbo bad?????
  103. conversion of F to C on Climate Control
  104. Clunk While Breaking/Accelerating (99 Wagon)
  105. Turbo for passat
  106. wiring code
  107. Alternative suspension found, need advise and need reliable transmission control
  108. 99 series passat
  109. Turbo (or lack thereof) question
  110. Passat wont unlock and alarm sounds please help
  111. Oil in coolant overflow??
  112. Bad Cruse Control
  113. 1998 Passat Needs New Engine
  114. immobilizer system
  115. 2000 Passat Driver Door Alignment
  116. Code Reader Scaner Connector
  117. 1999 1.8T Passat and OBD codes
  118. Passat V6 4 Motion won't start
  119. vr6 parts?
  120. noise around 40mph
  121. 1999 Passat 1.8, problems with the Turbo
  122. 99 Passat Losing coolant
  123. Air Filter Baffle
  124. turns over but wont start
  125. 1998 Passat??
  126. 2000 Passat 1.8T Automatic Shifting Problem (Tiptronic)
  127. DTC 18223 , P1815 What does it mean?
  128. Passat 2002 - Brake Lights out! Replaced 2 bulbs
  129. Transmission Module Issue...not sure?
  130. Headliner replacement?
  131. '03 VW Passat V6-Tiptronic?
  132. Blue Smoke!
  133. upper strut brace
  134. Brake pulsation
  135. Trustworthy mechanic in Stamford, CT area
  136. Exhaust Emmisions Warning Light
  137. Preformance Issues With 98 Passat 1.8t
  138. Emblem
  139. Factory alarm issues
  140. 2001.5 Passat question
  141. headlight adjustment?
  142. 97' passat Vr6 GLX... Weird noises
  143. vw dealership misleading customers
  144. Help! The dog ate my dashboard!
  145. Passat V6 (in Eurovan) stalls/idles rough
  146. Wanted Passat TDI
  147. 1999 V6 Passat Belt Squeling
  148. 2000 being returned to dealer...Need advise....and FAST!!!!!
  149. passenger airbag N 131
  150. aeb 1.8t stock starting problem please help
  151. passenger airbag
  152. trans oil level
  153. help trouble codes p1136, p1250, p1475!!!
  154. Looking for 02 Passat fuse panel diagram
  155. Cylinder 3 misfire issue
  156. 97 passat driver door problems
  157. Have i "lost" my chip-tuning during service?!!?
  158. Fuel Cap stuck and no gas !
  159. girlfriend's 98 passat is totaled...should she buy it back and fix it?
  160. tiptronic "bump shift" quit working
  161. Passat TDI PD 130 judder / shudder
  162. 99 passat window and door lock problem
  163. Passat B4 VR6 exhaust options
  164. ABS relays/Location?
  165. Airbag light on
  166. Oil leak? Please help!
  167. replacing oil pump
  168. CAM Adjustment
  169. Side Marker Lights
  170. Passat 2001 water leaking in
  171. cam chain noise or valve noise?
  172. 2000 Passat 1.8t P0411
  173. 01' Passat Won't start
  174. Steal my car!!!
  175. Hi, need advice on maintenance and cost..
  176. 97 passat-vr6. trans.problem.
  177. Problems with the 1.8t :( need help
  178. 98 1.8 turbo
  179. Comfort Control Module Location
  180. 1998 Passat Electrical Issues
  181. 97 Keyless Entry
  182. 99 Passat Sputtering then dying
  183. 99 Passat - Break-light is on and head lights won't come on
  184. Keyless remote reprogramming
  185. first time driving a passat
  186. Oil Leak - Cam seal replacement
  187. Malfunction Indicator Light
  188. '98 Passat Won't Start
  189. cd changer check magazine error
  190. Monsoon sound system problem
  191. New '97 Passat GLX vr6 owner- Questions
  192. Thinking of buying a Passat!
  193. 98 Passat TDI's exist?
  194. Passat error code 411
  195. 99 passat 1.8t abs/break lights problem
  196. No start after engine dies
  197. 2000 passat temp gauge
  198. 2001 Passat battery or electrical problem
  199. 98 Passat Electrical Problems
  200. 2001.5 Horn won't work
  201. 99 Passat floor mats
  202. loud noise when turning
  203. Drivers door panel
  204. I need 1998 passat 1.8t keyless entry directions please
  205. 2001 Passat 4-Motion Wagon 3 Repair Questions
  206. AM/FM Stereo
  207. Air conditioner blows fan motor fuse
  208. weird electrical problem - one for the books!
  209. 2000 Passat - Sounds like an exhaust leak but not sure
  210. Lead for cd changer
  211. Air intakes 99 passat
  212. 2001 Passat turn signals don't work
  213. Remove Dashboard for cd changer!!??
  214. 99 Passat STEERING PROBLEMS!
  215. 17'' on 99 passat
  216. Synthetic Oil REQUIRED for Turbo Passats?
  217. 2003 1.8 Liter Turbo Passat Temp Gauge
  218. 2003 1.8 Liter Turbo Passat Power Steering Fluid
  219. 2003 1.8 Liter Turbo Passat Spark Plugs
  220. 2003 1.8 Liter Turbo Passat Brake Fluid
  221. 2003 1.8 Liter Turbo Passat Rear Brake Pads
  222. Oil Pressure
  223. how good are fuel injector cleaners
  224. Headlight Washer or are they Sprayers???
  225. Replacing starter
  226. rear passenger door wont open
  227. computer codes
  228. Fan Pulley?
  229. Check Engine Light comes on when Low Octane Fuel Added?
  230. Fuse Question!!
  231. i just bought a new passat...
  232. grrr....noise problems
  233. Wheels, Tires, Air Intakes......
  234. I guess no one know??? READ PLEASE!
  235. Rear passenger footwells are wet
  236. Boschmann....ANYONE!
  237. Does ANYONE know???
  238. need 02 passat engine
  239. Help on 00 - 02,03
  240. passat inner tierod change
  241. is there a big difference in power with the vr6 gti n passat
  242. Antenna amplifier problem?
  243. Passat Skid Plate. HELP!!!
  244. 2001.5 Headlight Switch/Harness Installation
  245. Brake dust problems anyone?
  246. No Oil Pressure
  247. Blown Turbo? Please help!!
  248. 97 passat 1.8t 20v high emissions and fluctuating rev counter
  249. Location of air filter on '99 V6???
  250. Experiences with 6-yr old 1998 VW Passat
